Question about Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum
Kenmore vacuum model 116.52450200C- beater bar not working
I had a jam with my vacuum and released the material, however now the beater bar won't work. How do I take off the plastic cover to see if the belt broke?
  • 1 more comment
  • joan_chalovi Feb 18, 2009
    Thanks somuch for your assistance. With a firm tug we were able to lift the cover over the light off and there were the scews. Sure enough the belt was torn and I was able to pick up a replacement today.. Our other problem was that the light bulb needed to be replaced and it would have helped if the light had been working.
    It was a little tricky to release the cover since it had never been off before and I think the dust had stuck it down a bit but our vacuum is back in business. Thanks again. Joan Chalovich
  • Mark Egan May 11, 2010
    Glad you got it working. Would appreciate a FIxYa rating on this one. Let me know if you need any additional help.
    Usually there are screws that are marked to tell you which ones to remove, on the bottom of the floor head.
reddevil6
  • 1673 Answers
SOURCE: Can't get the case off the beater bar assembly
Wish I had the complete model number, but you can go to sears.com and click on the parts link and enter your model number, a parts list and a picture diagram showing the breakdown will come up.
On some of the powerheads, you take out 2 screws, then there are tabs holding it together on the back and on each side, release them and the top comes off.
On some othere, the cover over the light comes off, depress te sides and back to release it, then there will be 2 screws to take out. Then using a flat blade, you will see slots from the bottom edge of the top cover, pry out from these slots and the top will come off.
Posted on May 20, 2008
  • 8 Answers
SOURCE: beater bar on Dyson upright won't turn when handle is lowered
you need a new belt and maybe a new brushbar.
Posted on Dec 23, 2008
SOURCE: bissell 6579-2 bagless vacuum. Beater bar siezed
1. Uing the appropriate sized drift punch, tap out the steel axle rod which passes through the beater drum.
2. Each end cap houses a 608ZZ ball brg.
3. Check each brg for freedom of smooth rotation. Replace both if either is seized.
4. Replace with either 608ZZ (dbl shielded) or 608 2RS (dbl sealed) brgs.
5. Inspect and be prepared to replace the drive belt since it may have been damaged in the seizure event.
Posted on Sep 07, 2009
Vac Belts
  • 701 Answers
SOURCE: The beater bar on my Dyson won't turn. The vacuum
The belt doesn't have to be broken to make the vacuum not work correctly. If the belt is stretched the vacuum won't operate the way it is supposed to. You can get replacement Dyson Belts here:
Dyson Replacement Belts
Posted on Dec 06, 2009
  • 231 Answers
SOURCE: Dyson vacuum DC17 beater bar won't turn
sounds like the brushroll motor has gone bad. disassemble the head and check the continuity on the brushroll motor
Posted on Feb 27, 2010
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
Kenmore intuition non-turning beater bars, beltless model
When you press the reset button does the vac motor start but the bars do not turn? If so the drive belt may be broken that drives the bars. If so you will have to replace the belt. If the motor does not start it is possible the belt could be jammed or the motor seized or burnt out. If it's not very old check to see if it's still under guarantee.
Dec 07, 2014 | Kenmore Vacuums
Dyson DC17 Beater Bar Won't Work. The beater bar starting to make a very loud grating sound then stopped working. I cleaned the entire area (there are no obstructions) and the belt is OK. The beater...
I'm sorry to hear that you're having difficulties with your DC17's brushbar. If it appears to have jammed completely, it's probably best if you get in touch with us directly so we can help - please call free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 15, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Caught fridge of a blanket in vaccum. Turned off and remove object. Now beater bar does turn. How to fix?
Sounds like the belt either just slipped off, or is broken.
It's normal when the beater gets jammed.
Can you spin the beater easily?
Jun 24, 2011 | Kenmore Progressive Upright Vacuum with...
I sucked up a piece of fabric and turned it off ASAP. Now the beater bar won't work, but the beater bar does turn. Help!
If the clothe is jammed in the power head you will need to clear it. Have the unit unplugged and manually rotate the beater bar to work the jammed material out. Sometimes a pair of pliers helps to grip the material while turning the beater bar. If there is no longer a jam then the drive belt may have been damaged and needs to be replaced. Usually when this happens the brush does not rotate. You can get a belt often at hardware stores such as ACE, or as a last resort, the dealer.
Nov 25, 2009 | Vacuums
Low suction
Hi, You can take care of both things at once. Here's how:
Unplug and flip your vacuum over, beater bar side up. Remove the cover base plate that surrounds your beater bar. It's held on with either clips or screws, and usually "hinges" toward the front of the vacuum to release when the clips/screws are undone. Remove the base plate. The beater bar sits in sockets where it fits into the vacuum. Pay particular attention to how it comes out as you remove the beater bar, so it will be much easier to put it back together. If your belt is good, it will want to come off with the beater bar, but will remain attached to the motor. If necessary, slip the belt off of the beater bar. Behind the beater bar, you'll see a cavity. This is where the vacuum pulls the dirt from the beater bar. Look up into the cavity; stuff almost always hangs up in there. Remove any debris that you can find. While you have your beater bar out, look at the ends, where it fits into the sockets. Hair and other material catches on the beater bar and winds around it. If it is in and around the sockets, it causes the vacuum to have to work harder to clean. Remove any debris that you find on either end. Get your new belt and place it on the motor shaft. Slip the beater bar into the belt, and install the beater bar and sockets back into the vacuum frame. It takes patience so don't worry if it takes a few tries to get it right. Once in, test your work by revolving the beater bar a bit with your hand. You should be able to feel the tension of the belt as it turns the bar and the motor shaft. Take one more look at the sockets, just to be sure that they are in the proper place, and that the beater bar is level in the frame. Reinstall the base plate. This should have you finished at this end.
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Aug 01, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Beater bar not working on Halo vacuum
Check the bar to see if there is a buildup of hair or string causing it to jam,
Jun 17, 2009 | Vacuums
The beater won't turn
Un-plug the vacuum.
Turn the vacuum cleaner over and pop off or unscrew the bottom plate. The most common things are broken belt, clogged beater bar (usually hair), bad beater bar bearings, or the beater bar and belt is just plain worn out and needs replacing. If the brush nubs are very worn, replacing the belt alone won't help much.
Clean as much debris, hair etc as possible out of the unit. If you have a can of air like the type used to clean computer key boards, blow out the area and the motor if possible. Do this in a ventilated area or somewhere where it will not mess up your house.
Mar 06, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
May 18, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum Logo
1,291 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
