I have windows vista home premium on my computer.when I try to burn a dvd of a recorded tv program on windows media center i get a message "program not responding"then "burn failure".I have followed different instructions but get the same results
  • jjw1929 Feb 16, 2009
    computer came with application already installed dell dimension e520
  • jjw1929 Feb 20, 2009
    process for burning with nero or roxio thanx for tolerating a nubie to computing
  • 58 Answers
Try ImgBurn it's free burning utility
http://www.freecodecs.net/fc/ImgBurn_2.4.2.0.zip
1. When you open it, choose write files/folders to disc
2. In next window choose browse for folder (yellow icon with folder), select necessary file
3. Insert disc and press Build (big icon with folder and disc)
And that's it
Posted on Feb 20, 2009
  • 2,794 Answers
You need a DVD burner program to do it. Nero should work. If you get the right version you can put the DVD menus on there as well.
  • 564 Answers
http://support.microsoft.com/kb/927814
http://support.microsoft.com/kb/942375
Here is what you need. Just click the Link Above. Please Rate My Response! Thanks!
PREM
  • 51 Answers
Well it says "Burn Failed" so that pretty much means either the burn drive is bad, the software you are using is corrupt, or you were burning to quickly and the burn failed because of a speed issue.
I would suggest downloading a free program like CDBurnerXPPro from this link
http://www.download.com/CDBurnerXP-Pro/3000-2646_4-10409087.html
When it prompts you whether to run or save hit run. The program will download and ask you to install. You can just click next to all of the questions. Once you are done installing there will be a shortcut on your desktop to the program. Open the program and put together a disc and then hit burn. If you can't burn out of this program then you can't burn out of any program :)
  • 217 Answers
Use another burning software vista compatible
http://www.cdburnerxp.se/ this is free.
Disbale the Vista DVD burning:
disable the internal vista DVD burning software
The procedure to burn DVD using vista with built in DVD burning prog.:
1. Open DVD Maker
* Click Start, click All Programs, and then click Windows DVD Maker.
2. Add items to the DVD
* On the Add pictures and video to the DVD page, click Add items.
* Locate and select the video files, pictures, and Windows Movie Maker project files that you want to include on your DVD, and then click Add.
* To arrange items and specify the order that the different items will play from the DVD, click the video, picture, or slide show that you want to move, and then click Move up or Move down. You can also move items by dragging them up or down in the list.
* To remove an item from the DVD, select the item you want to remove, and then click Remove items.
3. Choose DVD Burner and provide DVD title
* If you have more than one DVD burner installed on your computer, on the Add pictures and video to the DVD page, select the DVD burner that you want to use from the DVD burner list.
* If you want to set different options for your DVD, you can set them by clicking Options.
* Click the Disc title box, and then type a title for the DVD.
4. Change Menu Text for the DVD
* Once you’ve added all of your files and chosen the burner and title, click Next.
* To customize the text for the DVD menu, click Menu text, and then do one or more of the following:
o Click the Font box, and then select the font for the menu text.
o Click the Font Color, Bold, or Italics buttons to select the font color and formatting.
o In the Disc title box, type the title you want to use for your DVD.
o In the Play button box, type a label for the button that plays your DVD.
o In the Scenes button box, type a label for the button that will display the different scenes on the DVD.
o In the Notes button box, type a label for the button that will display any notes you enter for the DVD.
o In the Notes box, type any notes that you want to appear on your DVD.
The Notes button and Notes page only appear on the DVD if you include information in these fields.
* Click Change Text.
5. Change Menu Style of the DVD
* To customize the menu style for your DVD, click one of the DVD menu styles along the right side of the screen, or click Customize menu and then do one or more of the following:
o Click the Font box, and then select a font.
o Click the Font Color, Bold, or Italic buttons to select the font color and formatting.
o If you’ve chosen a menu style with both foreground and background video options, near Foreground video, click Browse, locate the video that you want to appear in the foreground, and then click Open.
o To have a picture or video appear as the background for the main DVD menu, near Background video, click Browse, locate the video that you want to appear in the background, and then click Open.
o To add a digital media audio file to play as background music while the menu is displayed for your DVD, near Menu audio, click Browse, locate the audio file that you want to use, and then click Open.
o Click the Scenes button styles box, and then select the shape for the scenes buttons on your DVD.
o If you want to see the menu as it will appear when you play your DVD, click Preview.
* If you want to save the customized DVD menu settings as a new DVD menu style, click Save as new style. In the Style name name box, type a name for the customized menu style, and then click OK. You can then choose to use this customized DVD menu style for the current DVD and for other DVDs you create using Windows DVD Maker.
* If you did not save the style as a new style, click Change Style to save the changes you made for this DVD and to return to the previous page.
6. Burn the DVD
* When you’ve finished adding files and customizing your DVD menus, click Burn.
* After the DVD disc has been successfully burned, you can do one or more of the following on the Your disc is ready page:
o To make another copy of the current DVD, remove the completed DVD, insert a new recordable DVD, and then click Make another copy of this disc.
o To close Windows DVD Maker, click Close.
It;s not very good though so the best is to use some other application there are lot of other free softwares.
Posted on Feb 16, 2009
  • 265 Answers
i do belive there is a bug in the media centre, as for the XP version and the extender.
i can advise on doing a sytem restore to a previous date, and this should remove the updates.
or you could do a full system restore using your recovery disks, this is how i managed to sort mine out, and it worked a treat.
Hope this helps
    President:
  • 2,110 Answers
  • 6,487 Answers
Better if you try to use some other burning software because sometimes the burning software that came with a microsoft are not working , try Nero or Roxio......
  • 13,433 Answers
Try burning with a another program, nero for example.
http://www.nero.com/eng/index.html
attempt to burn a disc with it, what are the results?
you can burn the recorded tv show with nero if you know where the file is.
    Brigadier General:
  • 3,614 Answers
better try to re install again your burning application.
btw.. may i know the application you are using.
  • micromaster
    micromaster Feb 16, 2009
    try to use another burning utilities/application, like NERO.
  • micromaster
    micromaster Feb 20, 2009
    may i know if its working now? or are u able to burn a cd there?
    Let us know.
  • 19,396 Answers
Try using different dvds or cleaning the lens.
How can i change my wallpaper? i had samsung n150pus.. i tried to look up in control panel setting i coud'nt see or find it!o
Hi fforinas,
Welcome to FixYa! How are you doing?
Are you using Windows 7 Starter Edition? If yes, then you cannot change the wallpaper.
Windows 7 Starter has limitations:
Windows 7 Starter does not include:
* Aero Glass, meaning you can only use the Windows Basic or other opaque themes. It also means you do not get Taskbar Previews or Aero Peek.
* Personalization features for changing desktop backgrounds, window colors, or sound schemes.
* The ability to switch between users without having to log off.
* 64 bit version
* Multi-monitor support.
* DVD playback.
* Windows Media Center for watching recorded TV or other media.
* Remote Media Streaming for streaming your music, videos, and recorded TV from your home computer.
* Domain support for business customers.
* XP Mode for those that want the ability to run older Windows XP programs on Windows 7.
I suggest that you upgrade your Windows 7 Starter to Windows 7 Home Premium.
Hope that helps. Thank you for using FixYa.
Apr 28, 2011 | Samsung N150 Notebook
Cant burn movies
how long have you been using the burner? does it burn data and audio completely? try cleaning the lens with lens cleaner and check the CD/DVD you are using to burn your movies. also try using another burning program
Jun 01, 2009 | Microsoft Windows Vista Home Premium with...
Windows media centre will not burn dvd from recorded tv. get error message CLR20r3. media centre crashes
Hi stephenbarne
Download and install the latest drivers for your video(graphics) card from the manufacturers website.
Does this help?
May 13, 2009 | Microsoft Windows Vista Home Premium...
When i click on burn from the windows dvd maker an error message comes up indicating that my blank media is not recordable. I have tried using dvd-r and dvd+r.
Try to use different program to burn your dvds, try to use Nero, but this msg also means that Your DVd drive is not burner double check from the device manager if its says read only this means it cannot burn, it has to say write too.
Mar 14, 2009 | Microsoft Windows Vista Home Premium with...
Windows media center file issue
Some premium channels have DRM locks so that they aren't able to be copied or played on other players, which is most likely what's happening here.
Dec 25, 2008 | Microsoft Windows XP Media Center Edition...
A DVD burned with Studio 10.8 plays on our stand alone DVD player, but it won't play on our computer.
check what mode the cd video is you may have to burn another one with the correct mode for pc
Right click program on cd go to properties check video name plus what is after the . ie home.wmv as you need to burn cds with a general code
Try VLC Media Player on computer this plays all my video media
Jul 22, 2008 | Pinnacle Systems Studio AV/DV Version 9...
PARENTAL CONTROLS WINDOWS VISTA MEDIA CENTER
Hi, I recently wrote a program to easily crack ANY Windows Media Center Parental Control Access Code. On a fast enough computer this can be done in under a minute. The program can be downloaded at http://www.mediafire.com/file/uzfzwmmuinf/MCPC-Bruteforcer.exe -- Enjoy!
May 09, 2008 | Computers & Internet
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
