Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
Water Dispenser I have had this refrigerator for 2 years and ever since I bought it the water comes out really slow, to the point where we don't even use it because it takes way too long to fill a glass. I have also replaced the filter thinking that might be the reason but it didn't help. Any suggestions?
  • maguileramd Mar 06, 2009
    same as above, and now even after replacing filter, no more water coming out.
  • Mark Egan May 11, 2010
    How strong of flow do you get from the wall valve?
    Is the wall valve at least half way open?
  • 423 Answers
The water does come out slow on these models. I know you said you replaced your filter with a new one and it is still not any faster.
I own a Kenmore Elite #596 73503 201. I have not changed my filter for approximately 18 months and when I timed how long it took to fill a 2 Cup measuring cup (liquid measure) it took: less than 45 seconds. Can you test yours and post back how long it takes with your fridge?
Posted on Apr 13, 2009
  • 74 Answers
SOURCE: Water dispenser getting slower and slower and at
Check water filter.
Posted on Apr 01, 2009
farfield
  • 462 Answers
SOURCE: water from dispenser slows down while filling cup
If your water is slowing down the screen on the water valve may be stopped up or the filter (if it has one, when was it last changed?) or line feeding the refrigerator may be stopped up or the water valve its self may not be opening all the way and staying open.
To eliminate 3 of the external problems take the water line off the fridge and run some water into a pan and open and close water like at your kitchen sink and see if the water slows or speeds up noticeably while running into the pan. If so the problem is in the water line. While you have thew line off remove and inspect the water inlet valve screen and replace the hose washer (if so equipped) this brings your problem if you have not found it yet to the inside of the fridge. Usually on the corner of the door hinge the water line makes a turn up to the dispenser inspect it there and see if its twisted or kinked. Also there is a water resiviour inside the fridge look there for the same thing and possibley where food may have been forced agianst the line.
If you still dont find it by now I'D have to know what you did find and where.
If this helps you please rate me with as high a rating as you can and thank you for using fix ya.
Posted on Apr 20, 2009
Sea Breeze
  • 4654 Answers
SOURCE: My Maytag side by side refrigerator's water dispenser won't stop
Below is a picture of the fountain parts. I believe the controls inside the fountain are defective and will need replaced. Temporarily disconnect the control valve to the Fountain control plug this will allow the ice maker to continue to work. Let me know if you need more help and assistance to solve this problem. Below is a link to my site, email and a photo of the parts. Thank You, Sea Breeze appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://www.servicematters.com/maytag_library/docs/16010154.pdf
Posted on May 31, 2009
  • 441 Answers
SOURCE: Samsung Refrigerator side by side water is
Change your water filter, you should change your filter at least every year or it will start to grow bactria. If you still have the bypass (little plastic cap) you can us that in the mean time to get better water flow, it goes where the filter goes
Posted on Jul 07, 2009
SOURCE: ge profile refrigerator slow water dispenser
you have a seperate valve for ice maker and water dispenser, though it is possible both could have debris preventing proper water flow, i would check the water pressure you have going into the valve solenoid housing. turn off water to fridge, disconnect the line at the fridge, not in basement at saddle valve. place end of tube in bucket, turn on water. how is pressure? good or slow? if its good, then you probably do need to replace valve solenoid housing. You can NOT clear debris out of these, they must be replaced.
If your water pressure is still not good, either y ou have a kink in plastic water line. Despite having changed saddle valve in basement, if the stem of saddle valve is mounted on bottom half of pipe, debris from pipe is getting into water line and so on. You can reply here or send me a question from my website: www.FixMyFridge.net
Posted on Mar 15, 2010
Why would the water be coming out really slow in my refrigerator
your water filter or lines to and from the water supply to the filter and to the dispenser can be plugged with lime,also if you use a saddle tap from the water line in the house feeding the dispenser hose they can plug up with lime also
Apr 08, 2013 | Frigidaire Refrigerators
Slow water flow from the water dispenser
If it was fast at one point there are a couple of things that come to mind. Make sure your water line is not kinked at any point behind the frig. Also, when was the last time you changed your filter? Dirty water filters can cause low water pressure. Let me know if I can help further, good luck! :D
May 29, 2010 | Whirlpool GS6NBEXR Side by Side...
The water from the door of my GE Profile fridge doesnt work consistently. Sometimes it does and sometimes is does not provide water. It has started dripping inside the freezer leaving icicles.What to do???
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Dec 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator about 5 years old. stopped dispensing water twice in last 12 months. Ice and crushed ice works perfectly. No water for last 2 months. Whats up?
Nov 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water flow is slow checked lines to fridge and replaced filter what next
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
There is also a screen filter in the water supply where it connects to the water inlet valve. It may be stopped up with sediment.
Oct 05, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser will not dispense water. I have replaced the water filter and held the dispenser down for 2 minutes as suggested in the operation manual - still not working
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. If it's slow here there is a valve our water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Sep 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water & ice dispenser problem
Ensure there is proper water pressure and volume to the unit....replace the water filter....all should be fine.
clarkco
Apr 29, 2009 | Refrigerators
Water is dispening to slow
check for proper flow and pressure on water supply line
Feb 23, 2009 | KitchenAid Superba KSCS23IN Side by Side...
Water stopped running in the dispenser
I had a simular problem! I tried multiple things to make it work!
- bought new filter
- open back of the fridge... (dual outlet water valve)
Finally, I went to a different forum and found a unique idea.
First at the very bottom of the fridge theres a cover remove the cover and you should see the water hose running to the door from the back. In the middle of the hose there a coupler where the hose was spliced by the manufactuer. Now this valve once you separate it will not work correctly, unless you buy a new coupler (4$)... I'm el cheapo, I bought teflon tape for 50 cents (from previous project)... Wrapped around about half dozen times and made sure it wasnt leaking...
Secondly, when you disconnect the coupler no water should shoot out, until you press the water dispenser arm. If water shoots out of the hose on the bottom then you problem is really, really, really easy. You have simplely ice/ or another item blocking water hose to the actual dispenser.
I turned off the frezzer left the door open for an hour or so. I also used my wife's blow dryer on hot, and put it where the ice comes out of the ice maker. I would press the arm peridocially to see if the ice blockage melted yet. REMEMBER: door must be closed for pressure to push on the ice blockage. Thinking back, I might have been finished sooner... I was thinking the water dispenser would work with the door open.
If this doesnt work, then you have other problems... Bad water dispenser selonoid (you can hear this little motor turning even without water), dual water outlet valve maybe broken... Going outside my knowldege level at this point.... But i guess you computer board maybe going bad. Not sure if this computer has anything to do with water dispensing....
Hope this helps! My wife left me alone for about a day or two while she enjoyed the water dispenser...And she broke the vaccum.
Dec 23, 2008 | GE GSL22JFPBS Side by Side Refrigerator
Water button not work
You can check the site again on how I fixed the same problem. GE also has a recall on many refg. with this same problem. Probly a frozen line inside dr.Quickest way to isolate is to disconnect line at were it enters bottom of dr. and press dispenser tab. If you have water to this point it is about 99% sure a freeze in dr. No water means probly selenoid or the switch or something else. Ice and water line do not feed off same line , ice will dispense even if water does not.
Dec 24, 2007 | GE GSH25JFR Side by Side Refrigerator
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
349 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
