Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Poulan Wild Thing starts great but as soon as I try to cut it die
Starts great and Idles fine but as soon as I try to cut with i t the engine will die unless I continuously pump the gas trigger.
Ted
  • 1 more comment
  • tedandjoanne Feb 18, 2009
    Thanks jqwhomeequip. Which way do I adjust the low setscrew out or in and how many turns or quarter turns at a time?
  • hhhh819 Mar 19, 2009
    starts fine then idles really high then dies
  • Mark Egan May 11, 2010
    Sounds like you need a new diaphragm in the carburator and carburator rebuild.
Also, increase the amout of oil you're putting in your gasm sometimes if it's too little it will cause stalling
Posted on Mar 06, 2009
    President:
  • 1,902 Answers
The carb low idle needs to be adjusted this is fairly common among the Poulan chain saws. Once you adjust the low idle from factory setting it will work
Posted on Feb 16, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 18, 2009
    You will have to play with it and see. Adjust it in 1/4 of a turn if it still dies then back it out 1/2 turn and just keep doing that. Every machine is different another thing that you can do is try to get it running semi ok, you can give it little throttle and adjust the idle. Also just to make sure, do check your chain tension you should be able to see the teeth on the bottom of the chain. But this doesnt sound like a chain tension problem
Poulan Pro Wild Thing will only run with choke out. Carb has been fully rebuilt and new lines added. As soon as throttle is pulled and choke pops off, engine dies. Any recommendations/suggestions? Thanks,...
If not already done replace the fuel filter in the tank, it is obviously fuel starvation, if no better increase the the fuel mixture on the H and L screws ( turn anti clockwise 1/4 turn on each to start with)
Feb 27, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My poulan wild thing chainsaw has 3 tuning screwes h,l,t and they have all been messed up how many turns out do they all need to be from all the way in
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. T is the idle speed screw and not critical--just back off about two turns CCW at first. Turn H and L jet screws CCW from stops 1-1/2 turns each--this should allow the engine to start and run. Start the engine and allow to warm up--if the idle speed is too high or low, adjust the speed screw so that the engine continues to run, but the chain is not trying to turn. When warmed up, pull the throttle full on and adjust H needle CW until the engine starts to speed up. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L jet screw CW until the engine idles fairly well, but still allows the engine to 'follow the throttle'. If adjusted too far, the engine will 'gasp' when throttled. Set the idle speed screw to obtain the above conditions. Hope this helps!
Jan 22, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain won't stop when throttle pressure is released.
Start the engine and allow to warm up. Turn the idle speed screw (not the jet screws) CCW to reduce engine speed until the chain stops even hinting at running. If you get it too low, the engine will tend to die when it idles. Hope this helps!
Nov 25, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
The engine sputters and dies when it heats up. Is this Vapor lock? On cold start it works great and idles just fine but as it heats, the engine starts choking and soon dies out. If this is vapor lock, how...
sounds like the reason it starts and idles fine at start up is your choke is functioning... as your vehicle warms up.. the choke starts to kick off... Inspect your throttle body and idle control motor.
Aug 05, 2010 | 1986 Ford Bronco II
Poulan Wild Thing will not restart after 15 min.
Try venting the gas cap for a moment and attempt restart. If it starts, check for a plugged tank vent which should be a bronze disk set into the tank casting and located above the filler cap under the left side cover. When you changed the plug, was it wet with fuel inside? Also, check for spark at the plug when it won't start. You may have ignition problems that occur with engine heat. Hope some of this helps!
May 20, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Wont stay running when you let off the gas???
Sound like the carb was never adjusted right. Unfortuatley, the carb adjustment screws require a certain tool that's not available to the public. (EPA thing) You'll have to take it to a shop to get it adjusted. That should solve the problem.
May 25, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
New Stihl ms 180 idles but will not accelerate
sounds like you may have a broken throttle cable. take the top cover off and inspect to see if this is the problem. let me know if this is it or if you need more assistance with this.
Mar 01, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan chain saw after carb rebuild.
Is thereadjustment somewhere on the saw
I think there is 2 .
Feb 03, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poor performance at hi revs on poulan 3314
Try turning the high idle screw out 1/8 to 1/4 turn refer to your manuel for the location of this screw.
Dec 10, 2008 | Poulan Garden
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
1,647 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
