Anyone know how to make my G3-300 print to a shared printer on a Windows network. Ok, the printer is actually on a machine running RedHat8, but you procedure should be the same.
I would wonder about your HP4 driver... unlike in Windows, networking printing is driver-related; for instance, I've got an HP PSC950 all-in-one... it prints fine using HP's driver when it's connected to my Mac, but that driver won't let me print when it's connected to a PC.
HP says 'it's not designed to be a network printer'.
When I installed Gimp-print (and Ghostscript, available on the Gimp-print site), I found that my model was listed as 'unsupported' but reported to work using the Gimp-Print HP Deskjet 900 driver... and it works fine-- because that driver (and all the Gimp-Print drivers) is designed to allow network access.
So select Unknown Network Device (SMB) if you have to, pick Printer Model: HP, and in the long drop-down list, scroll until you see HP Laserjet 4 series, CUPS+GIMP-print v. 4.2.4
See if that works for you!
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on Printing to a Windows network:
Solution #2
posted on Aug 01, 2007
2Pansy - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
Yeah, I did that but it says Unknown Network Device (SMB), nothing about Windows Printer. I'm beginning to think the problem is SAMBA related on my Redhat box. I don't know if it is allowing access to the Mac. Then again the Mac.log file on the print server shows no attempts from the Mac at all. All the windows machines in the house can print, but the mac just starts, then stops. It's hard to tell where the problem may be. Let me give you the settings that I should've started all this out with. I'm running a Beige G3 300 with 256 MB RAM running OSX 10.2.4 In the address box, I have smb://redhat/oki and the driver is set to HP4 (that's what the Okipage 14e emulates) I am able to transfer files to and from the other machines, both Windows and Linux, over the network. Oh, and for fun, I went ahead and installed the lastest Gimp-Print. I don't know if that is what made the Unknown Network Device (SMB) start showing up or if I just missed it before installing. And that's all I can think of to tell you.
I don't know what else to do.
Thanx again.
Solution #3
Melissa - usenet poster
yeah, good luck with that ;)
I still can't print to my Windows printer. It will pull a page thru, and that's it. Then the computer needs to be restarted again before the printer works.
/tommy
Solution #5
Phoebe - usenet poster
I followed your HTTP page, but after hitting add and advanced, Windows printing via SAMBA was not an option. There was nothing between USB and Zeroconf printers. Thanx for your help, by the way.
ArcherB
Solution #6
OSX or earlier?
If OS 8.6-9.2, your best bet is to try out Dave (# there's a free 30-day trial download); classic Mac OS has nothing built-in for that.
With OS X 10.2, you can do it, but you need a printer-driver for your printer that has network features built-in. Your best-bet (in that case) is to check out Gimp-print #
See my article on Gimp-print on low-end-mac:
