Question about Cell Phones
Music i did do a folder my music still no luck it reads the card as empity help please its the a88
    Guru:
  • 832 Answers
Hi there!
I suggest that you first try to reformat your memory card thru your pc or laptop. Or from your phone itself.
Posted on Feb 16, 2009
Wont play music on sd card
its just a simple problem! the phone player reads the music files only in the MUSIC folder so, u must have put the music directly to the card which will be there on the card but outside. move the music in the folder named MUSIC and then try refreshing your phone playlist it will find all the songs!!!
reply and rate!
Jul 15, 2010 | Samsung SCH-U450 Cell Phone
Downloaded mp3s from amazon and now can't find on phone and says memory on phone is full
You must move the music files to the appropriate folder on your micro card. move all the music to the "sounds" file. Your phone is not set up to read the entire card, just the folder associated with the application being used. If this doesn't work out, then copy the entire card to your desktop and format the card while inside your phone from your phones menu. Now insert the card and select, open to view files. you can now locate the appropriate file and paste the songs you would like to have on your mobile device.
Good Luck And
PLs Rate This Post!!!! :D
P.S. Look carefully at the layout of your card from the "view folder" option when your computer recognizes it. You should see one called DCIM........open it and you will see a folder for the other options in your phone. You MUST place the files in the folder that your media player reads from. It will be either "Music", "Sounds", or some other name that is related to music or sound.
Feb 12, 2010 | Lands Phones
My music player dos not recognise mp3 songs in memory card and in phone memory it shows no music files found but there is music files
Good Luck And
Remember to spend the 15 secs it takes to click-through the folders in your microSD when you first connect it to your computer by selecting "View Files IN Folder". This will make it easier for you to see where to place the files. And if you have a song that DOES play, you can search the card for its file name and simply move the files to that same folder.
Feb 12, 2010 | Nokia 3110 Cellular Phone
I downloaded my music files to the micro sd and went into my music and it had no content exists. music is on the micro sd though can you help me step by step
Access your card from your computer and take note of the files.......your cell phone creates different folders for different menu options.
The folder should be music, but depending on your carrier could be labeled as sounds.....all files should be moved to this specific folder....so 1: access the media card 2: mover the media contents to the appropriate folder 3: your ready to go :)
another option is the copy the entire contents of the card to a folder on your desktop and format the card from the settings menu in your phone..............now you can look through the folders that the device creates to determine the one used for music......
geeeze.....hope i didnt lose you there
GOOD LUCK!!!! & Please Rate This Post!!!!!!!!!
Oct 02, 2009 | UTStarcom Cell Phones
MicroSD does not contain supported music files
1. Install the sd into the phone.
2. Go to Menu > Settings > USB > Mass Storage
3. Connect the MotoVE240 to your PC via USB
4. Under My Computer open drive (E:).
5. Find the folder that has your music in it. Example: My compter made a folder called Music.
6. Drag music from that folder to the my_music folder. (the phone will only read music that is in this folder.)
7. remove your phone from the usb
8. press the music note on your phone and enjoy your music
Jul 13, 2009 | Motorola Cell Phones
My cect i9 phone won't read the sd card
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Jun 19, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Downloading music to my mp3 player.
I had this very same problem with my LG mobile. it seems LG hate music transfers well actually anything to do with memory cards. to get your music to play on your phone 1# connect your phone to your pc using the cable 2# open up my computer and open up your phone folder. there may be 2 bu try each one and you will see which one is your memory card 3# choose your music and copy and paste it into the memory card folder in the music folder. if its not put in the music folder your phone wont bother tryng to read it from off your card. one other thing you may find is that when you try and safely remove your phone through the proper way it may come up saying that it is still being used by a program. this always comes up weather it is or not, best thing to do is make sure it isnt and disconnect the usb end of the cable. aswell as music the same goes for pictures and movies, just copy and paste into correct folder
Jun 04, 2009 | LG KG290 Cellular Phone
Memory card inserted not downloading music to the player
try putting a folder on the sd card name it Music then put your music on that
May 29, 2009 | iLO MP3 Player
A88 phone
return it, best thing to do, made in china! so do not hesitate.
Apr 03, 2008 | Cell Phones
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
