Question about Samsung Audio Players & Recorders
No sound on my computer
My computer has no sound,and it appears on screen no sound device,need to install but i don't have the cd sound device installer. All of a sudden, no sound on my computer. Speakers are properly connected. How can I get sond back? no sound on my computer
  • 265 Answers
Hi There,
Do you know the sound card you are using? if so look it up in google with the make and model number for the devices, or respond and ill find them for you.
many thanks
Posted on Feb 16, 2009
Music management rca th1100
The Music Management CD that comes with your player contains all of the necessary software components you need to make your player work properly.
These components enable you to transfer files from your computer to your player.
Inserting the included CD into CD drive:
Turn on your computer and place the Music Management CD that came with your player into your computer.
Important: Don\'t connect the USB cable to the PC or the player before or during the CD installation.
If the setup screen does not appear, double-click My Computer, double click your CD drive icon, and double click Install to run the installer.
Dec 28, 2013 | RCA Th1100a Usb Audio Player -white
I am using my headphone but there is no sound at all. i tried checking the master volume in the control panel and its not on mute.
If your Master volume is mute or showing disable its mean your sound card driver is not installed properly. Please install your sound card driver properly. to intall your sound card driver properly please follow these steps
1. keep your system driver's CD in your cd rom
2. on desktop write click on my computer and select the last option of "Properties"
3. a new window will appear select the 3rd tab HARDWARE
4. and now select the first tab DEVICE MANAGER
5. now a new window will appeared on your screen in this screen you can see a mark on the sound driver cross X mark or question yellow mark ? its mean you have any problem in your sound card driver
6. now right click on mark and select update driver
7. select your cd rom and click on next
after installing finish button will appear click on that and restart your PC your sound is enable now.
Jul 16, 2011 | Computers & Internet
I uninstalled my sound device. How to restore it?
Hi michellem769 ,
If you have uninstalled your sound device you can resintall it following the below instructions :-
  1. Insert your motherboard's cd in the cd rom drive.
  2. An autorun program will come up which will have an audio driver installation option
  3. Select this option and complete the installation of the audio driver.
  4. Restart your computer and you would have your sound driver/device back again.
Hope this helps...:)
May 10, 2011 | Computers & Internet
soundcard-drives.com
scroll down through company list driver should be there
please let me know
the asus website is in repair
please let me know if this has solved
Feb 16, 2009 | ASUS Computers & Internet
Control Panel - System - Device Manager - Sound adapter
instal driver. Go to manufacturers website to find the correct sound driver. You do not need a CD driver, just a sound card driver.
Feb 15, 2009 | AMD SEMPRON 2500 Processor - OEM (AMD2500)
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
60
Feb 13, 2009 | Intel Motherboard
Install bluetooth
Normal 0 Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard) this allows Windows to see the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth Keyboard
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if you make a mistake, you can backspace.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back and click Next again.
Once the Passkey is entered, the Keyboard should be connected to the computer.
Finish and follow any on screen instructiond.
Hope this helps. Bud
Jan 11, 2009 | Logitech MX5000L
Go to Dell's Support site and enter your Service Tag. This will produce a list of drivers for your machine. Download and install the latest audio driver for your machine. The audio may be integrated on the motherboard, so you may need to install the chipset driver as well.
Jan 03, 2009 | Dell Dimension 4600 PC Desktop
you could try a number of things:
1. try to go into control panel and look for your sound device under hardware, make sure it's "enabled", and try to update the drivers for your sound card.
2. go to control panel, click on sound speech and audio devices, then click on adjust system volume, and then check the box that says place volume icon in the taskbar
3. If neither work try using the system restore feature and restore your computer back to a date where u know that the sound icon was still showing in the taskbar.
Nov 13, 2008 | HP Pavilion DV5234US Notebook Laptop
CD rom can't read CD XP
yes i think the cd rom is the problem ,use external cd drive for the re installation or you can use a flash disc
Jul 12, 2008 | Acer Aspire 4315 Notebook
209 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
