Question about Zanussi Refrigerators
Zanussi freezone not working after removals!?
Jusy moved home now fridge freezer won't work.lights up and makes 'freezer' sounds but is not freezing.we bought it secondhand and it was working fine before move. we have no instructions with it and cannot find what looks like a model num. we do have these however; 222010302 GL80AA9920 ZEM R134a 0903212 cod.2237432-22 it has 3 shelves in fridge part and salad drawers, and 3 metal shelves in freezer,no drawers. on door has Zanussi Freezone. can anyone out there help please?????? much appreciated,tony
  • 1122 Answers
SOURCE: How do I change the
first you have to see if you have all the same fitting on the other side,top and front,let me know and we can go from ther,mike
Posted on Sep 12, 2008
  • 15 Answers
SOURCE: air conditioner
you are leaking refrigerant and need to have it leak checked by a professional
Posted on Feb 04, 2009
rylee_smith
  • 8619 Answers
SOURCE: item is secondhand and i was not given the book
Hi!
You can download the manual from this link, the manual is of a similar model---
Zanussi User manual
Please click on the above link and click on the link that says zanussi manual(150k)
Please ask for further clarifications.
Please rate this solution as fixya if found useful.
Thanks
Rylee
Posted on Mar 03, 2009
  • 193 Answers
SOURCE: zanussi freezone fridge freezer
well asuming you already thought to turn the thermostat down, i would check to see if you have a freon leak. with the fridge running, paint the coils with soapy water untill you see bubbles. mark that spot and dry off the area around it. generously apply electronics grade solder to the area where the leak is. (be sure you don't melt the copper and unplug the fridge first) then continue untill you have checked the entire length of coil. when all ieaks have been stoped recharge with recomended freon.
Posted on Aug 17, 2009
  • 713 Answers
SOURCE: why does the fridge part of my zanussi freezone
Hi,the problem you are encountering is as a result of the fact that the thermostat which regulates the cooling temperature in the fridge/freezer is bad hence there is no regulation of the cooling temperature in the fridge/freezer section, hence the food in the fridge freezes up.
The solution is to replace the thermostat of the unit,here is how you go about it;
1.You have to disconnect the fridge from the power source.
2.Locate the thermostat at the bottom of the unit,at the top left corner above the condenser.
3.Now you need to locate the wire ends or wire harness and unplug them.
4.Replace the thermostat,reconnect it back,put the back cover back and you have completed the job.
Take care of yourself
Posted on Jun 24, 2010
Zanussi freezone fridge freezer
Try adding freeon made for refrigerator. Can get at any hardware store. Hope this help.
Sep 09, 2013 | Microwave Ovens
Zanussi freezone fridge freezer model number zfc 50/17 freezer working fridge not
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 27, 2011 | Zanussi Refrigerators
Why does the fridge part of my zanussi freezone fridge/freezer, keep freezing the food?
Jun 24, 2010 | Hoover HCA390FFK Bottom Freezer...
Aug 17, 2009 | Refrigerators
Fridge on Zanussi ZX56SI has stopped working but freezer fine
check in your frezzer on the back wall if its all frosted up u have a defrost problem u can unplug and let thaw fgor 4 or 5 hrs plug back in and wilkl work till u can have it serviced if no frost u might a bad fan or a damper control
Mar 18, 2009 | Zanussi ZX56 / 4 Bottom Freezer...
Zanussi refrigerator/freezer model ZX99/5
I had the same problem...it was a defrost problem in the freezer....mad i know...fridge doesnt work but freezer does...so its the freezer problem right!!!
This is how i solved it....there is fan behind the freezer compartment....you need to remove all the freezer draws then the plate at the back of the freezer compartment(everything is accessible from inside the freezer only) once removed you can put your hand up inside the gap(make sure power is off and unplugged) just in reach is the fan which you should be able to rotate with your fingers...mine was covered in ice and not able to move as a result the cold air couldnt be blown up into the fridge(the only thing controlling the air into the fridge is a flap and depending upon what fridge setting you have this determines how much cold air its letting in.)
If the fan has been frosted up you need to defrost the freezer....and source a new defrost sensor.
hope it helps.
Feb 24, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Fridge making a purring sound then stopped working
Yes, I think you have a problem that can be fixed easily by a repair technician. The sound as you described it could have come from the air circulation fan in the freezer compartment striking ice. As the ice builds up it could have stopped the fan from rotating and air flow to the refrigerator compartment.
Nov 27, 2008 | Zanussi Freezers
The freezer is working but the the fridge
same here. have the znb 4051s refridgerator. freezer works fine but fridge does not. there is no sound eminating from the fridge either...any ideas? its 1 year old!
Apr 13, 2008 | Zanussi ZEBF277W Bottom Freezer...
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Refrigerators Logo
131 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
