FixYa.com
Tags:
OKI OKIPAGE 6w Led Printer
My okidata okipage 6e printer won't print
By Reynolds - usenet poster
I am running rh6.0 on an intel al400lx system with an okidata okipage
6e led printer.
Ican't get the printer to print. I set up the printer using printool
(as an hp ljet 4) .
The printer light just blinks and nothing is printed. I tried adjusting
all options for the ljet4 (send EOF supress headers etc)
(under printool) ; nothing seems to work.
I also tried directly dumping text to the port.
Any help would be greatly
appreciated
Yosef
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Pasty
Pasty - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Yes. Note, however, that someone reverse-engineered the codes and has
produced a driver kit for the 4w. It is unclear if any other *w
printers work with it; I'd guess not.
A fine tip; the article in Linux Today about this printer only
mentioned setting PCL from the control panel.
Apparently this PCL setting stays until someone sends a non-PCL job.
If you have no Windows clients printing at the 6e it should stay
happy.
For more information all the printers discussed here, see the
compatibility listings at the Printing HOWTO URL below.
Grant Taylor - gtaylor@picante<dot Cellphone information: #
Libretto information: #
Linux Printing HOWTO: #
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Charlie
Charlie - usenet poster
Rating: 0%, 0 votes
The OKIPAGE 6e printer supports PCL (The OKIPAGE 4w, 4wPlus, 6w and 8w
printers are Windows only.) If you get just a blinking LED, the
probable reason is that it is not being set to PCL mode before sending
the PCL data. (The OKIPAGE 6e also supports 'Hiper-W' mode). You can
do that by adding the sequence " %-12345X@PJL ENTER LANGUAGE=PCL" at
the start of the job, where the square character is an escape character
(0x1b).
Hope this helps,
Alan
Sent via Deja.com #
Share what you know. Learn what you don't.
Solution #3
Not Rated (0)
Gary10
Gary10 - usenet poster
Rating: 0%, 0 votes
Is this perhaps a Windows only printer? I think it might be .. since it is
Oki PAGE .. I believe it uses a Windows GDI driver to create the output. Can
you boot in straight DOS, not DOS shell, and use the PRN command and it will
print? If it wont print then ... then you may have a printer that needs
Windows as a host to actually print.
Solution #4
Not Rated (0)
Bouncy
Bouncy - usenet poster
Rating: 0%, 0 votes
Hmmm.
Have you loaded/installed a parallel printer driver.
Or try to set you lpt mode to SPP.
maybe it helps.
CU
HORK
Solution #5
Not Rated (0)
Rogers
Rogers - usenet poster
Rating: 0%, 0 votes
Sorry for not being specific. The blinking was slow and was due to the printer
recieving data. I did wait for the warmup cycle to be completed before
attempting to print. My printer works fine under win 98 (both as an okipage 6e
and as an hp 4).
I tried the above settings, it
still won't print.
Any additional help would be appreciated
Yosef
Solution #6
Not Rated (0)
Grant
Grant - usenet poster
Rating: 0%, 0 votes
1. Try printing to the printer under Windows, if you have it
available, to rule out a hardware problem.
2. Could you please be more specific about the blinking? Has
the printer finished its warmup cycle? Is it in the non-blinking
light stage before you attempt to print? Is the blinking fast or
slow? Slow is about once per second, and indicates that the
printer is receiving data. Fast blinking is noticeably more than
once per second, and indicates a problem. For me, the most
common problem has been the out-of-paper condition. Other than
that, I've had one paper-jam and a couple of instances of my not
having closed the paper drawer completely.
I used the Red Hat Linux Print System Manager to configure my
printer under RH5.1 and RH6.0. Here's what I used to get it
running:
Spool Directory: /var/spool/lpd/lp
File Limit in Kb: 0
Printer Device: /dev/lp0
Input Filter: *auto* - LaserJet4
Supress Headers is checked.
On the Filter screen:
Printer Type: HP LaserJet 4/5/6 series
Resolution: 300x300
Paper Size: letter
Color Depth: default
Printing Options: 1 page per output page
Margins: 18 pts for each.
Gary Kahn
Can you Help with these Printers problems?
Printers
How do I setup a
How do I setup a VMB on a... Answer This...
Printers
Brother DCP-110C...
Brother DCP-110C... Answer This...
Printers
hp photosmart 8250
on screen displays pump motor... Answer This...
Printers
pump motor stalled
Printers
Purchased Lexmark X5435 at...
Purchased Lexmark X5435 at... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
