Question about Whirlpool Laundry 22'' 2.1 Cu. Ft. Capacity Stainless Steel Wash Basket - LCE4332PQ
Whirlpool compact washer won't drain
Model # LCE4332PQ1 won't drain correctly
  • Anonymous May 04, 2009
    would this make the lights stay on. All of them
  • 130 Answers
Check the pump, usually has an item that is lodged into the impellers
Posted on Feb 16, 2009
May be this can help you with a Whirpool LCE4332PQ compact machine full of water who can't drain. :
Unplug the water hose from the faucet and place it in the washing machine. After move the washing machine near a bath. Place the water hose in the bath. The washing machine will drain the water completly.
Hope this help you !
Posted on Mar 19, 2011
My portable/compact Whirlpool washer drains, but won't spin water out
Check on Youtube for removal of the pump clips and motor clips. It really only takes a flat screw driver for each clip and a 1/4 socket too for the motor clips, as you tilt the machine back to get at the parts.
Feb 20, 2014 | Whirlpool Washing Machines
This washer machine is about 4years old it's a whirlpool model # LCE4332PQ1 and the problem that I'm having is that it's making this loud noise when it's rinsing in on the finally rinse it don't drain
Almost sounds like a bearing going out, but that wouldn't address the no drain situation. My bet is a sock has lodged itself between your basket and tub. They usually end up covering the drain whole. Sometimes they work their way down into the hose between tub and pump. There they often work themselves against the propellers of the pump. Check that the hose is clear and pump functions correctly before attempting basket to tub disassembly. Also look really closely with flashlight at the drain holes at bottom of basket, you may be able to see it if it's between basket and tub. If you can see it try to move it towards drain hole with a straightened coat-hanger. If you can get it there i think it is just a matter of removing the hose from the tub end on your model and grabbing it with some needlenose pliers. Keep in mind i'm going from 20 sec. of video here, so i could be way off base. Hope this helps.
Dec 30, 2012 | Washing Machines
Whirlpool top loader model LSQ9010pw6 won't spin but does drain.
Sounds like you need to replace the Clutch Assembly- Complete clutch assembly for direct drive washing machines. Comes with brake cam driver. Includes blue spring for large capacity washers and black for compact washers.
this video should help
http://www.youtube.com/watch?v=tVc6SZ2DD4U
Aug 13, 2011 | Washing Machines
Whirlpool washer LCE4332PQ1 leak underneath.
it sounds like that a pipe as become loose or corroded or the pump housing as perished you could take the back off and watch what is happening but mind your hands as the washer machine has many moving parts and elec parts as long as you don't put your hands anywhere near it when the back is of you will be fine but always unplug the machine before you do any work
Dec 07, 2009 | Washing Machines
PORTABLE WASHER LCE4332PQ1
did you fix this? i have the same problem.
Apr 06, 2009 | Whirlpool LCE4332P Top Load Washer
Advice on compact front-load washing machines
If you can get a whirlpool lhwoo5op They had less problems with that model then the other 2:)
Mar 28, 2009 | Whirlpool LHW0050PQ Front Load Washer
Kenmore 44722
You need a new circuit board. Sorry, no way around it, the board needs replaced. You didn't mention how old your machine is.
Jul 22, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Washing Machines Logo
817 people viewed this question
Dan Webster
Dan Webster
Sal De
