Question about HP Pavilion zd8000 Notebook
DVD R/W NOT ENABLED
I HAVE A PROBLEM WITH DVD R/W.WHEN I START MY LAPTOP THE DVD DOES NOT ENABLED PROPERLY.IF I OPEN MY COMPUTER IT IS NOT SHOWING ON THE SCREEN, ONLY HARD DISK PORTIONS ARE SHOWING JUST LIKE C D ETC .HOW CAN I SOLVE MY PROBLEM.
  • Quickfx PC Repair May 11, 2010
    How long have you had the DVD-RW installed in that laptop ?
    Is it a recent problem that happened suddenly ?
    Did it get dropped , knocked around while transporting it ?
    President:
  • 846 Answers
If its a newly installed DVD-RW
a.Not installed properly
b.Not compatible with that model of laptop
c.need the drivers for it
Factory DVD drive that came with it
a.May need the drivers reinstalled or updated
Please post comment back if you have any more info or any questions. Thank you for stopping by Fixya! Positive ratings are appreciated.
Posted on Feb 16, 2009
  • 61 Answers
Go to your cmos setup check if the dvd was detected. check also if it is enabled.
My pc does not see cd in uj-852
Open your chassis and blow out the dust with compressed air. Accumulated dust can make electronic components (like chips in a computer) heat up so much that they fail. Luckily, in my experience, after the dust is gone, the component will become functional once again.
Nov 21, 2017 | Toshiba Style Bay DVD-RAM Drive Kit...
No audio output device installed on my hp laptop. There is red spot with a cross in it. the sound has come back a couple of times. a friend advised that it could possibly be a loose connection on the...
Right click my computer then properties then hardware then device manager then see if the sound drivers are installed properly if not installed properly you will see a question mark if disable you will see red X id disable enable the if the driver is marked with yellow question mark then reinstall the driver if the driver is installed and no marks indicated go to the speaker icon in the task bear and open the volume control and see wether mute is enabled if enabled disble them
Sep 01, 2011 | Computers & Internet
Dvd not work
Sir,
is it your desktop or laptop.If desktop,just open the CPU and check the cables are properly connected.PLs check your drive is showing on My Computer.
May 23, 2011 | Microsoft Windows 7 Home Premium 64BIT...
My cd/dvd drive isn't showing up in "my Computers" and further more when I insert a cd or Dvd nothing happens. i tried downloading a dvd driver from dell but the problem still continues. What shall i do?
what is that? laptop or desktop, because laptop isn't easy to open and but in desktop you can change dvd drive.well, if you drive is not showing anything, that means either is disable or is not connected properly? have you seen that your drive's property?just right click away to check and any lighting indicated process, the LED light will start blinking if the computer is communicating with your drive. good luck,
Jun 21, 2010 | Sony DVD-ROM DVD Drive
My Laptop no longer recognizes that it has a DVD/CD drive
If you can, remove unit from laptop and start laptop without CD/DVD. It is usually fairly simple to remove. Maybe a few screws in bottom of laptop. Cut off laptop and reinstall. Restart and windows should find it.
Jun 28, 2009 | Acer Aspire 9300-5349 Notebook
DVD DRIVE NOT FOUND
Try going into your bios (accessed by pressing a certain key when the computer boots, usually Del, F1, F2, F10, F11 or F12) and checking to make sure that your DVD drive is still enabled. Make sure that all SATA and IDE devices are set to enabled or Auto function.
May 12, 2009 | Acer Aspire 5500 5570-2609 Laptop
Network center wont open no longer showing signals recieved
Check to see if your wireless is enabled on the laptop. Instructions can be found here: http://www.fixya.com/support/r1485609-wireless_network_not_working
Mar 16, 2009 | Acer Aspire 5315 Notebook
My Combo Drive is not visible
Please read to the end before atempting this.
Is this XP or Vista. In Windows based computers some times the High and Low filters get messed up in the registry. If the drive is still good and you had not had any issues with it not reading disks then the filter settings may be your problem. Try this:
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
Note: Vista doesnt come with the run command as a choice so just type REGEDIT in the search bar above Start..
3) Click on the plus signs (+) next to the following folders to open them.
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
(looks like same file name for XP and Visat?)
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
UpperFilters
LowerFilters
UpperFilters.bak
LowerFilters.bak
5) If you see any of the above keys, right-click on each of them and choose Delete
6) Close the Registry Editor
7) Reboot your computer
8) Click Start
9) Open My Computer and check to see if your CD or DVD drive shows now.
Open the device manager for your version of Windows and make sure the Rom Drive is showing and that it is not showing an exclamation mark. If you still do not see the Rom drive then your drive may be defective. Note: you migh have to reinstall some of your CD or DVD playing/burning software. Hope this helps... Dale
Feb 20, 2009 | Acer TravelMate 2300 Notebook
DVD DRIVE OF MY HP LAPTOP
Hi there:
If you know how to boot the computer into bios look for the boot section and check to see if the cd rom is there if not change the settings to show a cd rom and than save and reboot but i think you may have damaged the cd rom when you forced it open these are pretty delicate devices , force should never be used .
best regards mike
Feb 16, 2009 | Toshiba Satellite U305-S2804 Laptop
View cd
Go to the start button (xp), start orb (vista) ....select My Computer (xp) or Computer (vista). Right click the CD/DVD drive and select Explore.
A window will then open showing the contents of the CD.
Dec 12, 2008 | Toshiba Satellite 1715XCDS Cooling Fan...
HP Pavilion zd8000 Notebook Logo
51 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
