Question about Lakewood 5101 Oil Filled Radiator Heater
Switch light up, but no heat up?
When plugging in to the good outlit, the on off switches both light up. It dosn seem like it is trying to heat up. Im wondering if it is the heating element? I cant see how to take apart to fix it, or even if it is still under warrenty(just over a year old) Thanks for your help,its cold!
It,s the same problem i have. It is the thermal unit that opens up when unit over-heats. I'm an electrician, and was able to take my unit apart. So far i can't find the part to fix it. One place on the internet says that Lakewood has filed chapter 7 . I could make heater work, if i jump out the part, but would be unsafe if a overheating problem acurrs.
Posted on Oct 26, 2009
  • 34 Answers
Visit this page for service center info and parts: http://www.lakewoodeng.com/html/parts.html
Posted on Apr 18, 2009
My new wind shield wiper motor wont work
Voltage may be dropping through corrosion or resistance in the wiring.
Sep 08, 2017 | Cars & Trucks
It is plugged in but i press the power button and it wont turn on
Well it might be the outlit that its plugged into I remeber one time i tried to plug my
sega into one of the outlits in the basement and didn't turn on so it turned out to be that the outlit was turned off for the fuse or the adapter might be causing the mayhem.
Jul 28, 2011 | Sega Genesis Console
Nothing happens it turns on thats it
Check the outlit that you are using switch it to another outlit then. Or the ac adapter might be breaking.
Apr 04, 2010 | Sony Playstation 3 (PS3) Console
Unit fails to turn on/ bad AC or blown fuse? Hp 5470c scanner
If its plugged into a power bar, try plugging in directly to an outlit. If its in an outlit try another.
Mar 25, 2010 | HP Scanjet 5470c Flatbed Scanner
My plug outlite is about 1/4 inch deep to fit the cover properley after i tiled the wall
you can get some spacers from any big box store, they are made by Gardner Bender, and are usually bright green in color, found in the electrical aisle.
Mar 12, 2010 | Leviton 15 Ivory Switch Plate Outlet...
I tried to start it and it wont start it isnt the outlit Please help
Internal switch may be too tight to toggle and became disconnected from plastic mechanical slide mechanism. Replace switch for $20.00 and you should be good to go.
Jan 15, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Bike stalls when riding
hav u done a tuneup-chec plug wires n batt-wat about an inspect of wiring thru bike-they can hide alot-giv carbs a physical too
Aug 16, 2009 | 1993 Harley Davidson FLSTF Fat boy
Brother MFC-420CN All-In-One Printer no power
If its plugged into power bar, try plugging direct to outlit, and try another outlit. You can try holding down the on/off switch for 10 secondes. If doesnt come on, its a problem with the power supply.
Jul 29, 2009 | Brother MFC 420CN All-In-One InkJet...
Wii console is plugged in put won't turn on or power up...the thing is only four months old.
If you are using a muti-out lit device, unplug and use only wall outlits, if it is plugged into the wall, then plug in a working lamp to that same outlit to make sure the outlit is working. If you roll up the power cords alot or pull from outlit from the cord and not the base of the cord, you might have damage the cord internally. If you have a friend who owns a working WII then try using there cords on your console.
If nothing works, then possible the wii overheated. For further help on that, go to www.nintendo.com and go to support link.
Apr 30, 2009 | Video Game Consoles & Games
Lakewood 5101 Oil Filled Radiator Heater Logo
202 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
