Question about Hisense LCD1504 15 in. Television
Tv will not come on red light blinks - Hisense LCD1504 15 in. Television
  • jperk1819 Mar 07, 2009
    I have a similar porblem ,the tv starts to turnn on, power led goes to blue, then it goes to red, and then blue, and then red...
    its like the tv is trying to reset it self over and over?
    ANy thoghts?
  • Hisense Master
  • 19,396 Answers
If the TV goes off completely, then is usually a faulty power board.
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Apr 19, 2009
When the TV is plugged in the screen is black,little red power light bottom right corner blink 5x then you hear the sound of power on pause then power off. This continues to repeat and no picture.
Repairing Flat Screen TV - Blacked out with blinking red light
? 12:00
https://www.youtube.com/watch?v=3GmtBthpzDk
Mar 15, 2012 - Uploaded by n1bpd
Repairing Flat Screen TV - Blacked out with blinking red light ...Capacitors are little cylinders with a flat top with an X. If they have failed the X .... picture, no sound, totally black just the red power light blinking on the corner ... hello i have a dynex dx-lcd42-09 the red light blinks as soon as i plug it in i opened ...Missing: 5x
comments on EASY HOW TO FIX SAMSUNG TV- NO POWER
https://www.youtube.com/all_comments?v=hgcmWO7mqmo
Dec 16, 2015 | Samsung 55" UN55D6420 3D LED TV Smart TV
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Tv wont turn on, just red light blinks
From the owner's manual of that model:
If a red light is blinking on the front of the TV, the set has entered protection mode. If this happens it usually means you simplyneed to reset the TV. Unplug the TV for 60 seconds. Then plug the TV in and try to switch it on. If the light is still blinking red,call the Customer Care Center at 1-800-531-0039
Dec 08, 2011 | Philips 55PL9524 55" Rear Projection...
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Tv turns on but no picture just a red blinking light stays on
Red light blinking means there's a problem in the TV....
What kind of tv is it?
Feb 10, 2009 | Televison & Video
TV blew out
if the lamp light is flashing u need to replace the lamp. u should have instructions on the set or in the manual
Dec 07, 2008 | Televison & Video
Where can I find a Samsung repair center?
LG DLP PROJECTION TV (RU-44SZ63D) Tv light is off (with red light on). When I hit the power on button the red tv light starts blinking. Light continues to blink red then stops blinking and goes back to off (red light on).
Jul 12, 2008 | Televison & Video
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Hisense LCD1504 15 in. Television Logo
1,560 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Paul
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
