Question about Jet JWBS-16B 708749B 16-inch Bandsaw
Tire keeps rolling off
16'' jet, almost new tires top and bottom, new 1/2'' blade after about 15 sec the tire shifts ans takes the blade with it. seems to be in line tried using a bit of rubber cement to hold tire
  • 285 Answers
I'd say you have the wrong size tires, or at least defective or poor quality ones. They should be pretty tricky to get onto the wheels, requiring some leverage as you work them on, but they should be a very tight fit which will prevent them from moving. Sounds like the tires are too lose to me.
Posted on Mar 03, 2009
Just put new tires on my 2008 dodge ram1500 now low presure light is on no sensors in velvestems how do i get light off
Hi
1: set the tires pressure ( including spare tire) according to the sticker on the door side,
2: drive for 10 minutes at speed more than 15 MPH
3: park and keep the engine running, press the button ( light load) to reset the tires pressure and hold it for 10 sec.
Good luck
Aug 15, 2014 | Cars & Trucks
Will i have a problem installing 225/60/15 winter tires on my 1999 chevy tahoe
I pulled up your vehicle information in our fitment guide and tires in the 225/60/R15 and 225/60R16 sizes are not load rated for your vehicle. They are also quite a bit smaller than the tires that came on your Tahoe when new. Running a tire that is too small (even if it was load rated) will have an effect on your vehicles performance. We do not recommend installing either of these sizes for safety and performance reasons.
If your Tahoe came with 15" wheels we would recommend looking into the 235/75R15 size.
If your Tahoe came with 16" wheels we would recommend looking into the 245/75R16 or 235/75R16 sizes.
If you are still searching for some winter tire options please feel free to shop our website at www.discounttire.com or contact one of our local Discount Tire or America's Tire stores. We would love to help you find a great winter tire that will fit your Tahoe correctly and help keep you and your passengers safe.
Dec 14, 2013 | 1999 Chevrolet Tahoe
The front tires of my tractor do no appear to be installed properly. When making a turn, the outside tire turns further than the inside tire to the point where it gets "caught" because it has turned too...
yhere shulb be a bar linking both wheels together to keep alighnment correct.is there 1 on yours and is it wore out or broke.good luck hope this helps
Oct 29, 2013 | Cub Cadet Garden
Tire comes off wheel
Are you using new tires? Urethane or rubber? Make sure the adjustment are correct or probably you need to replace the
tires. I am using ulta blue urethane tires because it lasts longer and it doesn't need gluing. Urethanes are more durable
than rubber. I got mine on http://bandsawparts.com/ultra_blue_urethane_tires.cfm .
Jan 31, 2013 | Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4...
I have a new JET JWBS-10OS. I bought it rather than a scroll saw because it is more versatile, but I do need it for scroll work. I purchased a 1/8 inch blade and had trouble with the installation. The...
I'm not a Jet tech, just a bandsaw owner.
First, when you are adjusting the tracking knob, are you turning the wheel by hand for several revolutions to be sure which way it is running before making another adjustment? After tweaking it, you should turn it a bit to let it settle in. Also, be sure to tighten the adjustment knob down before turning it on.
The bearing guides have more adjustment places than just the finger adjusters. On mine, a Steel City, I can move the entire guide holders back and forth, and can also move the entire guide set up back and forth. The guides are there to keep your blade from having too much movement while cutting. They are not supposed to actually touch the blade though. I adjust mine with a dollar bill between the guide and blade. If you have one guide that isn't exactly perfect, don't worry about it. The blade guard will also keep the blade from wandering.
I've never used my bandsaw for scrolling work, so am not familiar with the 1/8 inch blade. Should work if you can get your tire adjusted correctly.
Good luck.
I hope this helps. If it does, I'd appreciate a vote or comment. Thanks,
Handie Andie
Apr 03, 2011 | Jet 707200 10Inch Band Saw
Can i go bigger than 215-70-15 215 dont seem tall enough ? if i go to 16 inch will it effect the speedometer?
Hello, I can tell you about my 2002 Gran Marquis LSE wheels and tires. On my car which had the 16" Wheels, Mercury wanted a low rider style for all chassis, including Police cars. They used "60" Series tires and when parking mine, the front concrete curb stops would consistently allow the front bumper cover or the air dam underneath the car to hit. ( Partially from the settling of the Air Suspension.) Even snow covered roads would scrap the car bottom. I bumped my tires up to a 65 Series which seemed a good compromise and it helped. A 75 Series may do you good on 15" rims.
I started looking for taller tires to raise the body. I found a good Website in DiscountTires.com, which when you plug in different tires OR rim sizes will give you the Speedo error for a few preset speeds. The site also lists Alternative tire sizes normally used for YOUR car and Level 1, Level 2, wheel upgrades which is tire jargon known to some.
You can get some Speedos Electronically recalculated for the different tires or wheel sizes. Just make sure the new wheels need the same thickness of studs as are on your car. You need to watch the clearance at the front tires' back wheel lip and the inside of the tire by the frame.
You can ask a tire store to pull 1 tire in your size and roll out a few other sizes and stand them side by side to see the difference in height. I hope you have found my solution very helpful in making your choice.
Mar 24, 2011 | 1997 Mercury Grand Marquis
Tire comes off top wheel almost all the time. Tire comes off bottem wheel sometimes. Don't know how to set up this saw.
My jet bandsaw did same thing only fix was new tires .Tires are supposed to be tite on wheel .get wood dowels between tire and wheel and roll new tire onto wheel. If desperate could glue on with weather strip adhesive.put bandsaw blade on both tires spin wheels with power off till blade is running in center of wheel by adjusting top wheel in or out. When done adjust blade guides to blade and bearings to back of blade .This is top and bottom of cutting area
Jan 16, 2011 | Delta Woodworking Delta Rockwell 14 Inch...
RAV4 spare tire cover seems to be hard to uncover and put back. Want to check air puressure of spare tire but hesitant because of this. Any advise for smooth work for this cover ? (mine is hard plastic...
These covers seem to shrink with age. One of the best solutions I've heard is to keep the cover conditioned with one of the many products available at your local parts store. Also wiping the tire down with silicone helps alot too.
Dec 01, 2010 | 2008 Toyota RAV4
Blade is walking off the tire.
There should be a tilt adjustment on the TOP wheel, this is what adjusts the tracking (centering of the blade) on the wheels. Watch the tension adjustment too, not enough will allow the blade to walk off
Mar 30, 2009 | Saws
Jet JWBS-16B 708749B 16-inch Bandsaw Logo
216 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
