Question about Sharp UX B700 Plain Paper Inkjet Fax
Black lines on sent faxes
What would I use to clean the parts in the fax? I have used a multi-surface wipe. My husband said to use nail varnish remover ??!!
  • 2,120 Answers
Open up the document feeder and clean the scanner glass.
Only use soapy water or alcohol for cleaning
Acetone will melt rollers and plastic parts.
Posted on Feb 16, 2009
Black lines appear on documents faxed
Black lines generally mean a dirty glass plate. Clean the glass with a dry cloth and try again. If this doesn't work use something like a 'wet-wipe' and lots of elbow grease. The glass may look clean but it just takes a bit of dirt that you can't see to make the lines appear. This solution applies to all faxes/scanners.
Jan 13, 2014 | Ricoh 3310LE Plain Paper Laser Fax
Line appears on scans and faxes
Do you use the document feeder when faxing and scanning? If so, the line is likely some paper dust, white-out, or other dirt on the thin piece of glass to the left of the main platen glass. Wipe that glass strip with a lint-free cloth, and if that doesn't work try using a little bit of alcohol.
If the line persists, or it occurs when you don't use the document feeder, it's probably dust somewhere in the optical portion of the unit, underneath the glass. If you want to take it apart, you can blow some compressed air around down there to scatter the dust or try wiping down the mirrors with a lint-free cloth.
May 05, 2010 | Brother Multi-Function Center MFC-240C...
Black lines in copies and fax's Brother MFC 7420
If the black lines comes when using the ADF (top feeder), try to see if you get the same problem when using the scanner glass or receiving faxes. If you don't, you simply have to clean the glass strip to the left of the a4 sized scanner glass. Wipe it with a dry cloth piece, no paper and no water/alcohol. If you see some dirt there that you're unable to simply wipe off, try to use a cotton wool to "rub" it off.
Jun 14, 2009 | Brother MFC-7420 Printer
Two black lines printed on sent faxes
Clean the glass onder the cover where the document feeds in.
Apr 24, 2009 | Canon FAX-L1000 Plain Paper Laser
Black vertical lines on the sent copies when faxed on Sharp UX 510
Lift the document feeder cover, and clean the scanner glass.
Please rate solution
Mar 31, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
Black lines printing out on sent fax
If you make a copie and the lines are on the copie then the optics's are dirty, white out, ink or fourn oblrct on glass.
If you have clean the optics and the lines are still there then the C,C,D, needs to be replaces the part that reeds the documents.
more then what the fax is worth sorry.
Feb 16, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Black line through sent faxes
Jan 05, 2009 | Brother IntelliFAX 885MC Plain Paper...
Lift to open the document cover and use a soft cloth to clean the glass were documents are scanned.Also clean the white plate on the upper side of the scanner.You identify the scanner by observing the direction documents faces while faxing.The scanner reads the document.
Nov 20, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Poor Print quality - black lines appear on page
If you see black lines on the drum, it is very likely that the drum unit is bad. Replace the drum unit and rest the drum counter. If you wait too long, you will cause toner build up in the fuser and will cost yourself several hundred dollars to get it replaced. More in labor than parts.
Use a soft cotton or very soft paper towel and wipe the excess toner from the drun. If there are lines worn in the surface of the drum, then replace it ASAP.
Nov 15, 2007 | Sharp FO 4450 Laser Fax
Sharp UX B700 Plain Paper Inkjet Fax Logo
42 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
