Question about GE Refrigerators
My fridge is not cooling
I have cleaned out the coils and have had no power outages. I am wondering what I should test before going out and buying a new condenser...can I replace the part myself?
  • 3 more comments
  • guymaltese Feb 16, 2009
    I was not able to find the defrost timer below the door would it be located somewhere else? Is it just a screw? would it go into defrost mode by itself?
    The model # is TPS24BICG BS thank you for your help...
  • Mark Egan May 11, 2010
    The defrost timer is located in the compartment where the refrigerator light is located, right hand side of the refrigerator.
    Give me the model number of the refrigerator and I will locate it for certain.
    The defrost timer is about 3 inches square and will have 4 wires leading to it. It usually initiates it's cycle based on a temperature sensor mounted on the cooling coil in the freezer.
    The "screw" will be about 3/8" diameter, usually will be plastic, and sometimes have a turn-out on either side to prevent you from turning backwards.
    Make certain that it is not stuck in defrost mode.
    There will be a defrost timer located somewhere on the unit, usually on the bottom left below the freezer door, behind the floor grill.
    There will be a screwdriver slot in it that you can turn to advance the defrost mode. Note if you can rotate it around to a detent, or if, when you start rotating, whether it is at a detent or not.
    Please reply if you hear the compressor trying to start at all, or if it is warm, or what you see/hear, and we can help you more.
huuum
  • 750 Answers
SOURCE: fridge/freezer not cool.
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
I believe your problem is an old thermostat or compressor !
How old is it?
My advice is do not put good money into bad!
A new fridge will pay for itself in a few years by using a lot less electricity!
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please remember to leave me a rating before you sign off!
Thank You, HUUUM
Posted on Sep 29, 2008
  • 363 Answers
SOURCE: maytag mff2557hew fridge not cooling. Freezer ok.
Sounds like the Freezer Fan is wearing out or is worn out. This fan problem is very hard to detect. The reason is that when the motor is starting to wear out the fan will spin, but at a much lower rpm. This is enough to keep the freezer cold. but will not ciculate enough air thru the freezer and the refrigerator to prevent freezer from and refrigerator from cooler. The cost to repair/replace this fan is a minimum of $300.00
Posted on Jul 28, 2009
Testimonial: "Your solution was right on the mark! The fan was spinning but not fast enough (according to my repair guy). Thanks again!"
  • 14 Answers
SOURCE: Amana arb2557cw condenser coils freezing, fridge not cooling
There are a few things that it could be. Do you mean the evaparator coil? This would be the coil on the inside of the freezer, the condenser is outside the unit. If the evap. coil is freezing, you could have to much in your freezer blocking air flow. You could also have a evap. fan not running. Check the owner's manual for the location of the defrost timer, it could be bad. The thermostat needs to be checked and set so that it is at a reasonable level. One last thing to check would be the condensate drain. Make sure the drain is not plugged or the line is not plugged. Good luck.
Posted on Jul 31, 2009
Sea Breeze
  • 4655 Answers
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Posted on Aug 05, 2009
SOURCE: My Subzero Condenser fan runs constantly - but coils are clean
If it is similar to mine at home (Model 550) the condensor fan is designed to run continuously, even when both the freezer and refrigerator are shut off. There is no control or switch in the fan circuit, so it just runs whenever the fridge is plugged in to the wall. It uses about 56 watts.
Posted on Nov 21, 2009
I have a GE GSH25JFTA CC refrigerator and it is not cooling properly. What should I check or replace?
Depending how long the power was off you may have an ice blockage in the freezer. Normal cooling causes the freezer coils to build up frost and snow coating all over the coils. A normal defrost cycle melts that frost/snow off and keeps the coils clear so the fans can move air through the coils.During the power outage the frost may have started to melt wetting the snow. If the refrigerator then came on and re-froze the wet frost/snow into a solid block of ice, the normal defrost cycle would not be able to clear that solid ice out. So it may be blocking the air flow. Remove freezer back panel and see if there is ice back there. If yes--use something like a hair dryer to melt everything out until it is completely clear. Make sure the fans are running also.
Apr 14, 2015 | GE Refrigerators
Help? Top mount fridge not cooling?
many times there is a freon leak, and you have two choices. Go to a place like autozone and get a freon can with sealant (11 ounces or so) or take it into a hvac store and ask them to recharge. Many will test it for free and tell you whether it is good or bad. Usually not a thermostat problem but seals do go badk, and the sealant swells these up again.
Aug 21, 2014 | Refrigerators
I can't find Condenser Coil in Beko FN244 fridge
Good Afternoon GOODGIRL,
I see that you are wondering where the condenser coil and the cooling fan are located on your Beko FN244 refrigerator. I do see that your fridge is based out of the United Kingdom. I suggest contacting the manufacturer in the UK for further assistance. I have been able to locate a telephone number, of 08445 613 613, for your convenience. Hope this is helpful.
-Best Regards-
WP
May 07, 2014 | Frigidaire Refrigerators
Kenmore trio freezer and fridge not cooling. we used to have problems where the fridge would be perfect but the freezer was always too cold, sometimes causing the freezer door to freeze shut. but we had a...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 19, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Power outage. Now two days later and still no ice. How Do I restart?
Possible that the power outage has damaged the compressor but we need to check the system as a whole to confirm the fault. So if there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off. If not the auto defrost timer, or the thermostat must be checked.
The ventilation fan that circulates the COLD air from the evaporator coils could get clogged with frost and so could be jammed. Also the wires to the fan can be worn out due to the frost. If so check if the defrost timer works to switch the heater to remove the frost. Also the check if the compressor is shut down by the timer /thermostat . If the heaters are not working, check continuity of the heaters.
So attempt to test using a multi-meter / clamp tester from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Thank you for using Fixya.
Sep 02, 2011 | Samsung RS2630SH Side by Side Refrigerator
We had a power outage now freezer and fridge aren't cooling. No Ice build up anywhere and fan and lights are working. General Electric PTS25SBMARBS Top Freezer Model
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Jan 27, 2011 | GE PTS25SHPBS Top Freezer Refrigerator
I bought a frigidaire refigerator in March, 2007, noticed recently it was getting warmer inside. Pulled it out to clean coils and saw a date stamped on back of fridge with the words fix 06 beside it. What...
It should be OK and not 06 as you mentioned. Please have a look again and reconfirm it. It says that the unit is tested and in good working condition a certification from the final check point of the unit at the factory.
The failure of cooling is due to refrigerant leak and I wonder whether you have moved the refrigerator from the original place of installation. During moving the fridge the condenser coil would have been touched and resulted in refrigerant leak and resulting in poor cooling or no cooling at all. This also would have taken place over a period of time and not instantly on a fine morning. By recharging the refrigerant your unit should cool perfectly.
Jul 14, 2009 | Refrigerators
I have a 8 year old amana fridge model #SQD23VE we had a power outage about 1 week ago and the fridge has not been cooling properly since i hear the fans running but no ice is being made and things are not...
hi thanks forr the question so you cleand the coils inside the freezer and at the back by the compressor and was the compressor running . if it was and still not cooling you have a compressor problem
Sep 26, 2008 | Refrigerators
Burning Smell
sounds like the motor is fried or seized up, which would explain that smell.
Feb 17, 2008 | Refrigerators
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
