Question about Dewalt 18 Volt Compact Drill Kit
DeWalt DW911 cabinet seperation
I am having trouble seperating the cabinet on the DW911. I removed all the obvious screws, however, the seams appear to be welded or glued shut. Is this the case, and if so, does anyone have any advise as to how to seperate the 2 halves of the case?
  • 3 Answers
Go to www.dewaltservicenet.com
shearch by model DW911 loock the break bown
Posted on Feb 16, 2009
  • Joe Bayer
    Joe Bayer Feb 20, 2014
    It is glued together, so take a screwdriver between the cases (front and back at the seam) and pry with the screwdriver while hitting with a rubber mallett. I would suggest doing it at the bottom so you will not see the damage. Some suggest just tapping then hitting at the seam but mine was solid. so I resorted to the screwdriver method.
  • Joe Bayer
Cant seperate cover on leaf blower
Sometimes there is a cap, collar or other piece holding the two sides together that must be removed before you can seperate the halves.
Nov 29, 2014 | Garden
I have a DW958 18v drill and it runs and the bit spins, but if you put your finger on it, it stops. might be a gear problem? How do i fix?
These tools have panetry gearboxs to give maximum torque foe lightweight gearing. A common problem with the older DeWalt drills was the gear selector legs coming adrift. This is (potentially) an easy fix. First of all, the obvious stuff. Remove the battery and press the trigger to release any static/stored power. Undo all the screws and seperate the two halves. Try to keep all the internals in the back half like this... http://lib.store.yahoo.net/lib/mendingshed/DW958mainimage1.gif
Now check the metal legs coming down from the gear selector slide. They should be sitting through the sides of the gearbox, and located into the sides of a ring gear. They used to pop out of this gear which would stop it being pushed fully into position.
Nov 23, 2009 | Dewalt 18 Volt Compact Drill Kit
I'm having trouble removing the fuel filter. I have removed the Air Intake assembly so I can access it, but I cannot remove the hoses connected to it (I have loosened the clamps) and I cannot remove the...
Ihate those filters with the rubber hoses that seam like you dont need a clamp, the best thing to do if you dont have a hose seperator is twist the hose use pliers if you have to just dont damage the hose, you can also try very carefully sticking a a small flat head screw driver in the end of the hose to try and losen it up just dont poke a hole in it. Is there not a bolt to losen the hosing should be. Best of luck to you.
Jul 16, 2009 | Mazda 626 Cars & Trucks
DeWalt DW911 Dis-assembly Problem
look on the back of the radio theres two more screws by the mounts for the cage
Feb 18, 2009 | Dewalt DC011 AM/FM Radio
Feul pump leak
yes it is possible that the cold caused the adhesive to seperate. i would definitely replace it now as the new one wouldnt be as quick to seperate i mean the other one has lasted these years
Jan 23, 2009 | 1995 Yamaha XV 535 Virago DX
DeWalt DW911 Radio/Charger
the second fuse is behind the circuit board,in middle of the radio.
there are 4 screw holding circuit board. Still looking for 2 AA battery.
Oct 09, 2008 | Dewalt DC011 AM/FM Radio
Dewalt dw911 radio
I had the same problem with the case not coming apart after I took the screws off, but thanks to someone posting a suggestion on this website, I was able to take it apart and take care of the problem. Use a soft mallet and use it around the seam of the radio until it pops loose.
By the way, my original problem with the radio was that it would not get any power at all, whether using the power cord, or an 18v battery. I was able to fix the problem by replacing the fuse located inside the case (250v / 1AMP)......works great now!! Many thanks to all of you who posted suggestions on this great website!!
Jun 05, 2008 | Dewalt DC011 AM/FM Radio
Dewalt radio dw911
Have you changed the AA Batteries, this is often the fault, when they are flat they lock the radio out. HHM Dewalt Service
Nov 27, 2007 | Dewalt DC011 AM/FM Radio
DEWALT DW911
2 screws sunk in at the back left and right. no need to remove speaker screws.
Oct 27, 2007 | Dewalt DC011 AM/FM Radio
Dewalt DW911 jobsite radio
Got mine open.
There was a fuse inside - Replaceable - fixed the problem.
There were no hidden screws, none under stickers or in the battery box like suggested by others, and the 2 magic release screws not so. There are several deep screws requiring a long philips, but the entire seam is glued (why?) so to open the radio I had to hit the body near the seam with a rubber hammer to crack the seam loose once all the screws were removed, comes right apart. Put it back together without glue, just the screws, it will be fine.
Sam. DesertSolutions.net
Sep 06, 2007 | Dewalt DC011 AM/FM Radio
Dewalt 18 Volt Compact Drill Kit Logo
206 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
