Question about Samsung HCM5525W 55" Rear Projection Television
I'M REPLACING THE IC'S ON MY SAMSUNG HCM5525W
THE PROBLEM THAT I HAVE IS THAT THE TWO IC'S ARE STUCK TO THE ALUMINUM HEAT SHIELD. AFTER REMOVING THE TWO SCREWS THAT HOLD EACH IC, I STILL CANT BREAK THEM LOOSE. ANY ADVISE?
  • Mark Egan May 11, 2010
    Are you certain that the legs of the IC soldered into the circuit board are not holding the IC's tightly to the heat sink? Usually all that is there is heat sink paste, and the cooling fin of the IC can be moved away using a thin bladed screwdriver, assuming the IC legs are not stiff enough, and positioned in such a way so as to cause the fin to be pressed.
  • Samsung Master
  • 5,138 Answers
Have you unsolder parts from board if so take flat head screw driver and tapp on top of it to get ICs lose from heat sinks.
Posted on Feb 16, 2009
Replacing the LED strips on my Vizio TV and the reflective shield got a couple of tears in it while removing. How can I repair without replacing?
Are you talking about the metalized tape that they put on? If so its not a huge deal, its there as a RFI shield, just try to smooth it down the best you can and if it wont stick just use a little tape over the top of it to hold it down. Another thing i use a lot to fix the shielding tape is the aluminum heating duct seam tape, its not duct tape, its an actual metal aluminum tape with adhesive on it for sealing up heating ducts. Most home repair stores sell it as premium aluminum duct sealing tape.
Jan 01, 2018 | Vizio Televison & Video
How to remove the DMD shield on Mitsubishi wd65733
Don't know why you are removing it; if you are replacing the bulb I suggest you use the bulb replacement that is complete with new housing already.
Nov 28, 2014 | Mitsubishi WD65733
MY SAMSUNG TV MODEL HCM5525W 55 IN IS STUCK IN TIMER MODE AFTER IT WAS UNPLUGGED. DO YOU HAVE ANY SUGGESTIONS TO FIX THIS PROBLEM?
You need to reset the tv to factory mode by pressing a code with the tv off,,,, mute--182--power and wait to see the menu appears on screen chose *reset to factory* press ok and wait until process done, them turn it on .
Dec 18, 2010 | Samsung HCM5525W 55" Rear Projection...
Getting a blue shadow on figures
convergence try customer convergence settings to try to resolve prob. if not the convergence ic is bad
Feb 03, 2010 | Samsung HCM5525W 55" Rear Projection...
Samsung HCN5529W rear projection TV has no picture but has sound
More likely its one of the Video output ICs which are located on the three CRT drive boards. I have seen that happen when one of the ICs fail they are TDA6111Q heres what they look like they are attached to the aluminum heat sink on the drive board617d21d.jpg
May 11, 2009 | Samsung HCM5525W 55" Rear Projection...
03 Mountaineer AWD Premier V8 rattling noise under vehicle
If its the heat shield against the underside.its install with fender style aluminum rivets( if you do it be very careful not to drill into a harness) If its the heat shield around the CAT then you should replace the cat. You can try to repair it with a pair of long hose clamps but I don't advise removing it. In the wrong environment the heat could cause a grass fire. or ignite trash that may get caught or blown underneath. Good luck.
Apr 28, 2009 | 2003 Mercury Mountaineer
Replacing the ic's on a samsung hcm5525w. ic's are stuck
The aluminum plate is a heat sink, there should be solder joints to the board on it. Unsolder them and remove the heat sink to make it easier to remove.
Feb 16, 2009 | Samsung HCM5525W 55" Rear Projection...
Removing starter heat shield on 2000 Passat 4cyl Turbo
I am not sure if I have the right engine but this may help and give you a better idea of what you are doing.
2-Wheel Drive (2wd) Models (2wd) Models
2.2L Engine
  1. Remove or disconnect the following:
    • Negative battery cable
    • Front exhaust pipe, if necessary for access
    • Starter heat shield, if equipped
    • Brace rod from the front of the engine and the bell housing
    • Drivers side wheel to access the starter motor wires and the starter motor attaching bracket-to-engine bolt through the opening in the wheel well
    • Wires from the starter solenoid
    • Attaching bracket-to-engine mount bolt
    • Starter-to-engine block bolts. When removing the last bolt, be sure to support the starter to keep it from falling and possibly injuring you.
    • Starter and shims (if equipped) from the vehicle
    • Bracket from the starter assembly, if equipped 0900c15280096824.jpgStarter motor and related components—2.2L engine
To install:
  1. Install or connect the following:
    • Bracket to the starter, if removed. Tighten the bracket nuts to 97 inch lbs. (11 Nm).
    • Starter and shims (if equipped) into position in the vehicle and thread one of the retaining bolts to hold it in position.
    • Bracket-to-engine mount bolt (loosely), if equipped
    • Starter mounting bolt, then tighten all mounting fasteners to 32 ft. lbs. (43 Nm)
    • Wiring to the solenoid
    • Brace rod and tighten the retainers
    • Front exhaust pipe and tighten the fasteners, if removed
    • Driver’s side wheel, if removed
Nov 27, 2008 | 1999 Chevrolet Tahoe
Samsung HCM5525W 55" Projection Television Conversion Issue
If you ever need any parts or service info just go to this link, you will be glad you did. They will save you alot of money and frustration.
http://servicemanuals.vstore.ca/
May 20, 2008 | Televison & Video
Replacement convergence chips
I you give me your complete STK number such as STK392-010 as an example I can tell you what you can upgrade to also it does not require any resistor change when you upgrade but send me your complete IC number that you have and I can tell you what to upgrade to thank you
Apr 26, 2008 | Samsung HCM5525W 55" Rear Projection...
Samsung HCM5525W 55" Rear Projection Television Logo
83 people viewed this question
Jerry Greenberg
Jerry Greenberg
