Question about Juki TL-98Q
GRACE STITCH REGULATOR PROBLEM
I HAVE THIS MACHINE WITH GRACE QUILT FRAME AND GRACE STITCH REGULATOR. I AM NOT SURE HOW THE STITCH REGULATOR IS SUPPOSE TO WORK. AS SOON AS I SLOW DOWN THE STICHES IS VERY SMALL. THE STITCH LENGTH DOES NOT STAY CONSISTANT WHEN GOING FAST OR SLOW. PLEASE HELP
dupina
  • 110 Answers
SOURCE: Tension issue
If you set the tension from 3of 4 to 1 you actually lowered the tension. To increase the tension you must set the tension to 6 or higher. Be carefull not the set the bobbin case tension to tight as this will also have negative results
If suggest the following: First lower the bobbin case tension, half a turn. Then increase the top tension to 6 and see if there is any difference.
If you do this systematically you should rectify your problem.
Good Luck
Posted on Jan 21, 2008
SewTechWayne
  • 186 Answers
SOURCE: Needle Thread breaking after about 30 seconds of quilting
Make sure the feed dogs are dropped (or feed dog cover is on - I can't remember which way this machine works). The stitch length on the machine has no function so ignore it. (I set it to zero so the machine doesn't have to work as hard). Hopefully this is all that's wrong. If not, use a shorter setting for the stitch length on the regulator, oil the hook and move slowly and smoothly.
Posted on Jan 31, 2009
  • 201 Answers
SOURCE: Skipped stitches & looping on the bottom of Quilt
Try a different needle. Use a quilting or topstitch or even a metallic needle - one that has a larger scarf than normal. The scarf is the groove at the back of the needle where the thread goes while the stitch is being formed. Quilting threads often need more "room" there. I have been told that the Inspira quilting needles are good because they have a thread groove on the front and the back of the needle. Not tried them personally but might be worthwhile for you to consider.
For the looping, you could fiddle with your tensions a little either loosening the bobbin tension or tightening the top, or both. Only ever do this in very small increments. But the good news is that even the "professional" quilters do not have perfect quilt backs - just have a look at them at quilt shows!
Pam M.
Posted on May 03, 2009
  • 4 Answers
Are you threading it correctly? I've had this problem twice, the first few times the thread was wrapped around different items (below the spool holder and then around the needle) the other times I threaded it wrong. Double check that the machine is threaded correctly with the manual. I've missed a step here or there and it does make a difference.
Posted on Jul 29, 2009
  • 1116 Answers
SOURCE: need help in using the grace sure stitch regulator
I would contact the Grace Company directly with questions.
http://graceframe.com/gfxoops/modules/sample_module_13/
Let me know how you like this accessory. I have one of the Grace frames and have not used it. The stitch regulator may change my mind.
Posted on Mar 04, 2010
I have the Mega Quilter and Quilters Cruise Control. My stitches are very inconsistent.
I agree to have the regulator check, & even having the whole machine checked wouldn't hurt.
May 15, 2012 | Sewing Machines
Machine sews fine when it is set up on a table, but when it is on the Gracie II quilting frame and operated by their stitch regulator, the stitch quality is very bad. It varies from fair to very bad - I...
Use a carpenter's level to level up your frame, and be sure to keep the quilt leveled up to barely above the throat plate on the machine, and level front to back. Check the connections on the regulator sensors. If even one is not making good connection, you'll have skipped or broken stitches.
Jan 24, 2011 | Juki TL-98Q
I'm using a Janome 1600 DBX on my Grace quilt frame. It keeps skipping stitches and breaking the thread. I put in a new # 16 Janome needle - made sure it was installed correctly, and tried 30 weight and...
The tension is not right and you are moving the machine to fast. Go back to your 50 weight thread top and bottom. Have you got a quilting foot on and the foot in the down position
Dec 01, 2017 | Janome 1600P-DB Mechanical Sewing Machine
Need help in using the grace sure stitch regulator of quilting
I am having irregular stitches on the forward/backward motion. I am using a Janome 16000 P on a Gracie II frame. (I purchased this as a used productin a private sale) Do I need a darning plate to effectively use the Sure Stitch regulator in a free motion mode or with a template?
Mar 04, 2010 | Janome Sewing Machines
Tension and missed stitches
It sounds like one of your clearances in the machine is off. When a machine skips stitches like yours is doing, it does so because the hook responsible for "catching" the thread from the needle is not close enough to the needle so it misses the loop of thread from the needle. If your machine was having a timing problem it wouldn't sew well on any fabric. A clearance problem shows up on certain fabrics at certain times. A few things you could do to try to compensate it would be to use a slightly larger needle and turn your top tension dial down to a lower setting. Move the machine a little slower on the frame or increase the speed of the machine. Either way a trip to your technician will be needed. Make sure you tell him to check the needle to hook clearance.
Sep 19, 2009 | Husqvarna Freesia 425
I have a Janome 1600P QC drags on a Little Gracie 2 frame
Sorry for your headache. It is the frame. If it is not level, balanced, you have hell to pay. Also it there is a nick in the grooves of the carriage tracks this will cause a machine problem. You may be able to repair the frame, or level it about the old level the table trick, put something under that part.
Good luck
Sep 06, 2009 | Janome Sewing Machines
Jan 18, 2009 | Juki TL-98Q
Juki TL-98Q Logo
619 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
