Question about RCA 3-Device Universal Remote with Dedicated DVD Menu Key
RCA DVD/TV remote not working
This is a RCT 110D A1. It's not new but don't use it that much. Just doesn't make any connection we have to do everything by hand w/ DVD. Have checked & changed batteries still is dead. DVD works but remote doesn't. Any suggestions? Last time we used it it was fine & that was a couple months ago now nothing.
    President:
  • 814 Answers
You may have corroded battery input terminals in the remote control. Try using some electronic contact cleaner to clean the contacts. If that does not work try putting in a new set of batteries. If this does not work, you will need to get a new remote control.Having it repaired will cost as much as getting a new one. I hope this information helps you with you problem with the remote control. Thank you for using FixYa and have a nice day.
Posted on Jun 22, 2009
How do I enter my Sylvania tv code into my RCA 110D A1 remote ?
The codes are stored in the remote. If your RCA remote is programmable, you can use its "code search" feature to find a suitable code to operate your Sylvania TV. If you search through all codes stored in the remote and do not find one that works, you may have to try another programmable remote.
Sep 13, 2014 | Televison & Video
My GE universal remote for RCA Scenium tv doesn't work the DVD part
If this is a combo unit (TV with DVD built in) you need the original remote---Universals almost always are missing key features the original remote had as most companies have someone else make the unit and put their name on it.
Mar 21, 2012 | RCA Scenium D40W20 40" Rear Projection...
We had our ps2 hooked up to an old rca tv and was using the satelite remote for it channel had to be on 00 for the ps2 to work. We got a new tv and hav moved the rca and ps2 to another place but don't...
New tv's don't use dead channels like 00 anymore for there inputs.. They use sources to change from different inputs.. Make sure you have your ps2 hooked up into input plugs on the tv and then turn it on the ps2 then look on the new controller for the tv & find a button saying source .. Press that until you see your ps2 on the screen. If not check your connections try again.
Feb 03, 2012 | RCA Televison & Video
I have an RCA TV converter box, model DTA800B1. I don't have the box or instructions, I am attempting to conneect it to an RCA TV with a built-in DVD player. I would appreciate the code that the TV...
There are a lot of possible RCA TV codes programmed into the DTA800B1 remote.
Try the following three digit codes: RCA 000, 001, 005, 072, 073, 074, 075, 076, 077, 078, 135,
138, 140, 144, 150, 156, 159, 162, 163, 169, 171, 178, 229, 246, 249, 260, 274, 275, 293, 302 in order.
To program the remote. Turn on your TV manually and press PGM (to the left of the zero in the number pad section). The LED should light and stay lit. Type in the first 3 digit code and press OK (in the center of the arrow keys near the top). See if the gray volume up/down keys work to change the volume. If it doesn't work press PGM again and enter the next code.
Note that the converter box remote will only turn on and off, switch the input from Channel 3 or 4 to AV in, adjust the volume and mute the TV. It will not control any of the DVD functions. Your original TV remote will not control the converter box.
The manual for the DTA800B1 is available here: http://www.1800customersupport.com/productdocuments/DTA800B1_RCA.pdf .
I hope this helps.
(who has the DTA800A which is the model without the analog pass-through.)
Sep 17, 2011 | RCA Televison & Video
I have a sony xav-622 in a new rv camper. Everything works except the connection to the sony tv on the dvd only plays in black and white. This is connected with a yellow cable with no place to put s...
try cd/dvd cleaning lens kit of your XAV-A1. if still it doesn't work, try opening you XAV-A1 and clean it with a cotton buds with a cleaning solution from the cleaning lens kit. if still it doesn't work, have it change a new lens from a certified technician.
Apr 25, 2011 | Sony XAV-60 Car Video Player
User Guide for RCA DVD RCR 110D A1
The manual for this remote control is embedded in the operating manual of the DVD Player DRC 220.
icon_arrow_download.gif RCR 110D A1.pdf
Apr 16, 2009 | RCA (DVDCP33) Media
HOW TO PROGRAM THE REMOTE TO CONTROL TV FUNCTION
you need to have an rca ge or proscan tv if you have one of these then all you do it turn the tv on and point the remote at it, push the tv button and then push the off button according to the manual if your tv turns off the remote works with your tv
Sep 09, 2008 | GE DGE100N DVD Player
Input Selection without a Remote
On either the front of the TV or a universal remote (which I assume you have already programmed) hit the MENU button. Go to option 4 "Channel". Go down to "List and Labels." Hit the CH up or down key until you see "FRNT" come up under the channel # heading. If your DVD is connected and playing, you'll see it playing now. Exit the menu to watch. You'll have to reverse the process to get back to watching TV, but there doesn't seem to be any way around this if you don't have your RCA remote. This process is guaranteed to work on an F27442 and will probably work on some other RCA models.
May 24, 2008 | RCA F27442 27" TV
RCA 3-Device Universal Remote with Dedicated DVD Menu Key Logo
162 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
