I broke the exterior door glass and need to take the oven door off to take it in to replace glass
SOURCE: Our GE Profile Oven is not heating up (stove works)
Please check here for possible troubleshooting steps:
http://www.repairclinic.com/0088_13_1.asp#Level1_2
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: replacing glass top on stove
its not too bad.kill the power.then under the frount of the top where the top meets the oven door .under there are screws remove those and the top lifts up as on hinges.their is a ground screw wire to loose and unplug the the wire harness that connects the burners to the rest of the stove.then all is disconnected so lift entire top off from hinged area and set upside down on table.transfer all burners to new top thats nexted to old one upside down also.when done reinstall.ive done lots wont be bad.please dont for get to help me with my rateings.God bless ,tom
SOURCE: GE Profile Oven does not work although stove does
Check and or replace the glow bar ignitor.
SOURCE: GE Profile Electric Stove, no heat, looks like it needs a reset
my oven doesent work and my key pad is locked
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
If you look down at the hinge arms, there should be a hole in each arm. Put a nail in each arm, then lift the door up so the nail rests against the door frame and locks the hinge arm from closing all the way.
Once the nails rest, the door can then be lifted off.
Let me know if this works for you, or if not (does for 90% of the ovens manufactured in the US.). If not, I will investigate further.
By all means, DO NOT REMOVE THE NAILS until the door is reinstalled.
