Question about ASUS Eee PC 1000H Laptop
Blue Screen Im booting from an external cdrom with WINXPPRo SP2 The system starts to load the drivers then it comes up with blue screen ***STOP :oxoooooo7e (0xc0000005,0xf75de0bf,0xf7a2a208,0xf7A29F08) *** pci.sys - Adress F75DE0BF base at F75D7000, Datestamp 3b7d855c
    President:
  • 2,110 Answers
Try disabling PCI-Express in BIOS setup
Posted on Feb 16, 2009
Blue screen compaq presario windows xp sp2 cq40
Did you just install a new program or a piece of hardware, update a driver, install an update, etc.? If so, there's a very good chance that the change you made caused the BSOD:
Startup using Last Known Good Configuration to undo recent registry and driver changes.
Use System Restore to undo recent system changes.
Roll Back device driver to version prior to your driver update.
Scan your computer for viruses. Some viruses can cause a Blue Screen of Death, especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. Most Blue Screens of Death are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return hardware settings to default in Device Manager. Unless you have a specific reason to do so,the system resources that an individual piece of hardware is configured to use in Device Manager should be set to default. Non-default hardware settings have been known to cause a Blue Screen of Death.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
If this doesn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of blue screen
Oct 10, 2013 | Compaq Presario Notebook
Blue Screen windows 7 PC closes with a Blue Screen and Restarts
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
  • Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
  • Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
  • Update Windows - missing updates, including service packs can be a source of stop errors.
  • Check your system - run a virus scan and spyware scan after updating your definition files.
  • Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
List of STOP Errors Causing BSOD:
  • Stop 0×00000003 UNSYNCHRONIZED_ACCESS
  • Stop 0x0000000A IRQL_NOT_LESS_OR_EQUAL
  • Stop 0x0000001E KMODE_EXCEPTION_NOT_HANDLED
  • Stop 0×00000023 FAT_FILE_SYSTEM
  • Stop 0×00000024 NTFS_FILE_SYSTEM
  • Stop 0x0000002E DATA_BUS_ERROR
  • Stop 0x0000003F NO_MORE_SYSTEM_PTES
  • Stop 0×00000044 MULTIPLE_IRP_COMPLETE_REQUESTS
Here are 2 solutions:
Solution #1 Scan your registry for errors.
A Registry Cleaner scans your computer for errors in your PC's registry. Your computer's registry contains information about your Windows XP operating system, including driver, printer, software information. Over time, your computer's registry may start to contain obsolete data. A corrupt registry will easily slow down the speed of your computer because applications and drivers are loaded even though they're not in use. Fixing your registry of errors will not only prevent the Windows XP Blue Screen Of Death, it'll allow your computer to boot faster, open up multiple folders quicker. A listing of registry cleaners can be found here.
Solution #2 Process of Elimination
When the CPU calls certain functions from the RAM, or Random Access Memory, and the data rests in a faulty section of the RAM, this will cause the blue screen to appear. I recall a time whenever my computer booted up and started loading the Norton Anti Virus program, the blue screen error message would appear. This happens because the CPU is accessing data from faulty locations within the RAM when loading the anti virus software.
This method involves having 2 sticks of RAM. Remove 1 stick of RAM and wait to see if the blue screen surfaces, do the same for the other.
Through process of elimination, you'll find the cause of the Windows XP blue screen of death error.
Because getting into the hardware can be a little techy for computer hardware "adverse" readers, a simple 2 step plan is to first clear your PC of any registry errors. Then if the blue screen of death goes away, we would have saved ourselves the trouble of having to open up the PC casing and touching the hardware components
Dec 08, 2010 | Computers & Internet
Blue screen error
The most frustrating blue screen computer errors are basically caused by some physical faults such as faulty memory, power supplies, overheating of PC components, or hardware running beyond its limits, device driver conflicts etc.
If you see the blue screen and halts occur in boot process, and also notice some specific error message appear on your screen, this indicates a serious issues most probably due to inappropriate device driver or firmware .Blue screen is really an annoying issue and creates a lot of trouble to the end user.
Follow these steps to fix a Blue Screen in Safe Mode
Once booting start, select "Safe Mode" from the boot menu.
Scan your hard drive by running your antivirus software . If the program locates an infection, move it to your vault or follow the on-screen instructions. After program completion, if a virus was removed, attempt to reboot your computer and see if this clears up the problem. If not, restart your computer in safe mode.
Restore your computer to a previous point. Click on the "Start" button. Select "All Programs", "Accessories", "System Tools" and finally "System Restore". Choose a restore point on or before the last day your computer worked without error. Finally Reboot your computer to see if it loads correctly.
Aug 27, 2010 | Microsoft Windows XP Professional SP2
My aspire 5315 has a startup problem. It loads untill the acer loading screen then the screen will go blue with a little bit of white random writing. After 1-2 seconds the Computer will keep on rebooting...
It sound like the laptop is booting up and then BSOD (blue screen of death). If you press F8 on bootup and try booting in safe mode, or load a restore point (depending on your recovery options). This will help to determine the problem.
Try installing you windows disk or recovery disk you can try doing a repair ( you might have to access the bios and going into CMOS setting and changing bootup order CDROM first) but you will probably end up reloading windows (this will format the HDD and you will loose any data on it).
If this doesn't work then it probably is a hardware problem.
This unfortunately happens a lot, back up you data on to an external hard drive or make an image (various software can do this) and keep it safe for when it does happen again. Good luck!
Aug 07, 2010 | Computers & Internet
When you first start your computer how do get it to read the disc first?
You go into Boot Menu, and set the - first boot device to CDROM.
The computer will then read what is in the optical drive, first.
Computer off, press the Power On button. Watch closely for the blue dell logo.
Looking at the bottom of the monitor screen when the blue Dell logo comes up, you will see - F2 = Setup.
At the top right of the screen you will see F12 = Boot Menu.
This screen goes by F-A-S-T!
As SOON as you see the blue Dell logo press the F12 key.
If you miss this small window of opportunity, just wait for Windows to fully load, then click on Start, Turn Off Computer, and Restart.
If Windows is not loading, then press the CTRL, ALT, and DELete keys at the SAME TIME. (Not shouting)
This will restart your computer so you can try again.
Upon entering Boot Menu you cannot use your mouse anymore, you have to use the keyboard.
The Boot Device Menu has the devices listed, and each device has a number next to it.
At the bottom of the menu, type the number that is next to CDROM, then press the Enter key.
This is Dell Support, and the main page for the Dell Dimension 4700 Service Manual,
http://support.dell.com/support/edocs/systems/dim4700/sm/index.htm
Left-click on - Entering System Setup
Should you have any questions concerning this, simply state so in a Comment.
May 03, 2010 | Dell Dimension 4700 PC Desktop
Starts to load xp then goes to blue stop screen
Did you load the CD that came with the motherboard? It has the drivers for the motherboard. Did you go into BIOS Setup, and set the first boot option in Boot Order, to CDROM?
Apr 13, 2009 | Computers & Internet
Blue screen
Are you getting a splash screen at start-up? If so, go into BIOS and set the CDROM as first boot device. Insert Windows disc into CDROM drive and restart. If it boots from the CD you should have the option to repair or re-install the operating system. If you re-install, you will lose all data on the hard drive. Sometimes taking the coin battery out before you do this can help.
Dec 05, 2008 | E-Machines T3085 PC Desktop
Blue screen of death on DELL Inspiron 9300 WinXP pro SP2
Clean install windows xp :) or do a repair
Jun 04, 2008 | GE EasyCam Webcam
ASUS Eee PC 1000H Laptop Logo
516 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
