Question about Whirlpool LER5636P Electric Dryer
Dryer starts on it's own - won't shut off
Whirlpool electric dryer, with the door closed, will start on it's own accord (without pushing the start button) and run for hours - until I open the door. Sounds like a timer malfunction but could be a switch. Any ideas? I'd hate to change the timer and still have the problem. Most problems I see is won't start or won't heat... Mine is the opposite. Oh, this doesn't happen all the time - one of those every now and then problems.
    Genius:
  • 1,122 Answers
TRY DISCONNECTING THE START BUTTON WIRES AND SEE WHAT IT DOSE WITH THE DOOR CLOSED,IF IT DOES NOT START IT YOUR START SWITCH-MIKE
Posted on Feb 26, 2009
My Fisher & Paykel ED56 dryer will not start.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com Kenmore Whirlpool Dryer Won Start Easy Fix
Jan 13, 2017 | Fisher Washing Machines
Kenmore he2 dryer, model: 110.c87561602 beeps twice, wont start and is not showing any error messages
Jan 03, 2017 | Kenmore Dryers
Samsung dryer DV42h5000ew won't power up
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Jan 02, 2017 | Samsung Dryers
GTWN4250D1WS WON'T START. CHECKED THE POWER CORD, ALL IS WELL. WONDER IF THERE IS A FUSE OR SOMETHING ELSE TO LOOK FOR.
Troubleshooting Why Your Dryer Won Start PartSelect com Electric dryer no start does nothing
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com
Jan 01, 2017 | Dryers
It will not turn on. When I unplug it and plug it back in the start light is constantly blinking. I checked for error codes and the 4 lights blink 9 times and the start button blinks 14 times.
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Nov 09, 2015 | Kenmore Dryers
Kenmore dryer model 110.74994300 push start does not stay on
Jul 01, 2014 | Kenmore 62602 Electric Dryer
Kenmore elite sensor smart electric dryer Model 110 65066500 I have power but won't start
Jun 24, 2014 | Kenmore Dryers
How can I fix my HE4 Gas dyer it will not start
Jun 21, 2014 | Kenmore 659 Electric Dryer
My Kenmore Dryer model # 110.65942401 will not start. The door switch seems fine. When I hold the start button in I can here the timer clicking, that's it. Any suggestions? Thanks!
Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Apr 29, 2011 | Kenmore 659 Electric Dryer
Dryer wont start - no lights
Dryer door does not think it is closed. There is a sensor on the top of the door that is probably not making contact with the door. Trying pushing the top part of the door and holding it then press the start button.. if the unit starts running then you know what it is. I just had one of these dryers delivered today and had to find out about this by myself tonight!!
Apr 30, 2009 | Whirlpool WED9500T Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
116 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
