Question about Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher
Water keeps running
I turned on the dishwasher before I went to bed last night and woke up to the sound of water running in the dishwasher. It is coming from the built in hole on the left hand side of the dishwasher. I tried pushing buttons, opening the door, and the water runs with the door open or shut.
Please help!
  • Anonymous Mar 13, 2014
    Frigidaire dishwasher keeps stopping. Error code ER/up. If you open the door and then close it will start again and run for a while then stop again
  • 121 Answers
Check electro-valve must be broken,you must
change it.
Posted on Feb 16, 2009
  • 134 Answers
Hi
Sounds like the inlet valve has failed. You need to replace the part that the inlet hose is attached to
I noticed just as going to bed last night that our dishwasher appeared to be making a strange noise (dull buzzing sound), opened door to check and the display has the number 3 flashing, several fault codes...
check the very bottom of washer; look for something jamming the garbage cutting blades. it can be something very small stock half way in the drain causing the blades to stop turning and therefore keeps it from draining water. just an idea
Dec 16, 2014 | Hotpoint-Ariston LFT 228A 23 in Builtin...
I have a ffus2613lp. Yesterday the alarm started going off with the doors closed. The inside temperature raised to room temperature. I pulled it out, cleaned everything, including compressor/coils. ...
Good Afternoon Friend,
I understand the Hi Temperature alarm was going off on your Frigidaire refrigerator, model# FFUS2613LP, and the temperature was room temperature. I also see that you pulled out your appliance and cleaned everything, including the compressor and coils. You turned your refrigerator back on and it froze a cup of water before you went to bed. However, when you woke this morning, your refrigerator was back at room temperature. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why it keeps warming to room temperature. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Refrigerators
It won't turn on. It worked last night and I plugged it in before I went to bed, and when I woke up it was black. It won't turn on now or make any type of sound.
battery could be gone..also you could check wire connections to battery. Even better measure if the battery has a charge with a voltmeter.
Jun 13, 2010 | Samsung Behold Cell Phone
THe Dishwasher just keeps Washing And Rinesing
Turned Fridgidaire washer on last night before going to bed; this morning, it's running (at least making sounds) but did not wash; 4000 Series Frigidaire; display says Washing Drying Er Clean S; and two lights are flashing - Ultimate Scrub and Rinse only.
I tried turning off the breaker and restarting the machine but that doesn't work.
Sep 05, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher will not turn on. Last night I started
You need to measure with a voltmeter for 115 Volts at the electrical box under the washer front. Breakers can fail, yet look ok. This will check the breaker output and all of the wiring in between. There may also be a local circuit breaker that tripped.
Aug 18, 2009 | Dishwashers
Lost Power
Replace the thermal fuse inside the control panel.
Part #3376359
Mar 11, 2009 | Whirlpool DU960PW Dishwasher
Nothing in instruction about water tap
Yes you need to turn the tap on and leave it on. Otherwise you will burn out the pump.
May 22, 2008 | Danby 22 in. DDW396 Free-standing...
It fills, but doesn't kick in to spray/wash
Main pump not running?...then it will either be the program controller or the main pump itself.....I would guess the pump first.
Jul 17, 2007 | Kenmore 15522 Built-in Dishwasher
Indesit Dishwasher
disconnect the drain hose and lower it into a bucket if no water comes out there is a blockage in the hose/pump.
Jan 25, 2007 | Indesit 24 in. D63S Free-standing...
Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher Logo
176 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
