Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Keypad will close the door but not open it
I have changed batteries twice. we just had a bad winter, but aren't these made for that. when the door is closing the enter button will reverse the door up and down,but once the door is fully closed the keypad will no longer open the door
  • Agwambo Feb 16, 2009
    I have exactly thesame problem and initially thoght it was the battries, but then it should not be closing thedoor either! (which it does without fail)
    Problem Solver:
  • 6 Answers
U have to push right side of enter button 3 to 4 times
Posted on Feb 17, 2009
I have a lift Master door and the remotes work fine but the door will not open or close using the wall button or the keypad.
Are you sure you aren't stating the facts just the opposite of what they are? That would be a fairly common complaint.
Aug 20, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Chamberlain Liftmaster Professional 1/3 hp garage door opener. I'm unable to find the model number, but it was made in April 2004 and has an orange learn button. It has been working fine since...
Do you mean the numeric keypad is no longer controlling the garage door? If so, have you changed the battery for the keypad? Frequently, if the battery is low, the keypad will stop working when the door is closed but works to close an open door. On most Chamberlain garage door openers, this is a 9V battery. You may need a small Philips screw driver to open the battery compartment at the bottom of the keypad.
After changing the battery, try the learn code procedure again. I've found it easiest to have two people involved when programming the keypad to the garage door opener. One handles the Learn button and the other types in the desired code.
I hope this helps.
May 22, 2017 | Vacuums
Everything on the opener works fine but the key pad will not open the door when it is closed but will close the door when oprn
Make sure the battery in the keypad is good. A weak battery will cause this problem. If it is good then your keypad is going bad.
Nov 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 hp opener won't open using the outdoor keypad. It will close when using the outdoor keypad but not open. Wall unit closes and opens it. changed battery in keypad, no difference
If your hand remotes work okay then the keypad has lost signal strength and needs to be replaced. If your hand remotes act the same way then your logic board is bad.
Jun 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster wireless keypad closes but won't open the door
If you are sure the battery is good you have a bad keypad. The signal strength is so weak it will not penetrate the door.
Aug 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wireless keypad will close door but open
WHEN YOU CHANGE THE BATTERY YOU NEED TO REPROGRAM THE UNIT.
IF THAT DOESN'T WORK YOU PROBABLY HAVE A BAD KEYPAD.
HOPE THIS HELPS
Apr 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener 1/2 HP
You may have a model that requires you to reprogramme your PIN after changing batteries...
Jul 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Wireless keypad will close door but will not open
If you are sure the battery is good than it sound like the keypad is bad and needs to be replaced. With a 6+ year old operator I would suggest a wired keyless entry (Donino GD-1) so if the operator has to be replaced you can use the same keyless entry.
Jul 04, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
63 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
