Question about Fuji FinePix Z10fd Digital Camera
USB power surge, now i/o won't work
HELP! I recently got a power surge warning on my USB port, and now none of my i/o peripherals will work. The board still powers up and I can hear the hard drive working, but the monitor, keyboard and mouse ports are dead. Is the board partially dead or am I missing something?
    Problem Solver:
This problem might be caused when there is short-circuit on board,but firstly before jumping into conclusion try troubleshoot all component on other related board,if it's function then the problem is fromm the board and if not it's surely means that it's the component that is bad and all you need to do is for you to replace all spoilt components, and if it's also the board the best thing is to purchase thesame type of board.
Posted on Feb 16, 2009
Power light off
Power surges are damaging spikes of voltage in an electrical systems, caused by lightning strikes, changes or problems with the electrical grid, or large appliances.
Power surges damage or destroy computer hardware by overheating circuit boards and other components.
Surge protectors and other devices are used to protect computers and other electrical devices from power surges.
If damage occurs to a computer from a power surge, a process of trial and error is used to replace the damaged components.
Replace the surge protector or power strip.
If neither was attached to the computer, it is highly recommended that one be used.
Follow the user's manual to open the computer.
The computer manual may have shipped with the computer in book or CD form or may be found online.
Examine the system and make note of any visibly damaged components.
Damaged components may show visible burn damage or no damage at all.
Follow the user manual to remove the power supply.
You will need to unplug the power connections to each device in the computer as well as the system board.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Removal is generally achieved by removing the holding screws and lifting the power supply out of the system.
Follow the user manual to install the new power supply.
Plug the power cables into the computer components and the system board.
Close the case.
Do not re-insert the screws.
Plug the power cable into the computer and attempt to power the computer on.
Replace the power cables to the monitor and computer.
Examine the monitor.
If the monitor does not power on, it will need to be replaced.
Determine if both the monitor and computer power on.
If the monitor powers on but the computer does not replace the system board.
If both power on but there is no video signal, replace the video card.
Boot the system into Windows.
Go to the "Control Panel" and double-click on the "System" icon.
Click on the "Hardware" tab.
Double-click the network card, sound card, and other peripherals that are listed in the hardware tab.
If you replaced the system board, ensure that the device drivers are in place for the peripherals. Replace any peripheral that is still non-functional.
Computer Repair Tutorial Help and Tips
http://www.thepcmanwebsite.com/computer_repair.shtml
Dec 08, 2013 | Dell Vostro 410 Desktop Computer
SE-084C Won't work on mac is there a soultion to this?
According to the samsung website the SE084C it can be used with a mac see http://www.samsung.com/ph/consumer/monitor-peripherals-printer/optical-disc-drive/dvd-rw-drive/SE-S084C/RSPN/index.idx?pagetype=prd_detail
Are you using it via a usb hub or is it plugged directly into the usb port of the mac. As it is powered via usb, on the hub it may not have enough power getting to it, so plug it directly into the usb port. If you already have it plugged into the usb port change the usb port and finally check that the usb cable is working, if it isn't change it. Hope this helps.
Jan 08, 2012 | Computers & Internet
I had a power surge over the weekend and now none of my USB ports are working and I keep getting a popup message that my USB hub has had a power surge. Those on the rear of my board as well as those...
One option is to install a board into your PCI slot. It will give you a few USBs in the back, and most models have internal connector so you can reconnect the front ones to the PCI card instead of the mobo.
Mar 01, 2010 | Foxconn Computers & Internet
None of the USB ports on my Compaq Presario R
Hi there!
Have you tried checking your BIOS? Pls make sure that the on board USB setting are enabled...this should fall under the integrated peripherals...
Hope it helps!
Feb 23, 2010 | HP Compaq Presario R4000 Notebook
Message showing usb hub port power surge but there is no usb connected this message pops up every time
check all of your usb ports to make sure none of the contacts are touching each other and none have broken
Aug 11, 2009 | HP Compaq nc6120 Notebook
USB ports conduct power but do not let attachment (eg mouse) work.
Since you know you have power and I am assuming none of the USB connectors pins are broken or shorted then what is happening is that another driver is stepping on the USB driver. Check Device Manager for erros. If none then at the run prompt type SFC/scannow. Have your original operating system disk ready because if it finds problems it will need to install the corrections. The original disk IS NOT the recovery disk (this won't work). If this does not correct the problem the operating system needs to be repaired. Email me for further info.
May 30, 2009 | Toshiba Computers & Internet
Usb port power surge and has failed to work. How do I reset it in the (dialog??) box???
You can disable this (in the device manager) but this will likely disable the USB ports on the whole machine. To add USB functionality you could install a peripheral add in card, which usually add about 4 ports for $15. This is the way I would go if it were my computer and replacement of the mainboard were not an option.
Dec 23, 2008 | Computers & Internet
USB Peripheral Switch
do not use Front usb connection. try to use cpu backside USB port it wil work.
Feb 27, 2008 | Belkin BLKF5U201 USB Peripheral...
Power surge to usb port when installing cd
Delete all the USB ports in the device manager
Restart the computer to let XP install all the USB ports again.
Go to the first USB port and right click on it and go to properties. Then on the advance tab click on do not show warnings.
This should resolve the issue.
Is your PC a Dell by any chance?
If so there is a patch available to fix this also.
Please let me know how you get on.
Feb 26, 2008 | HP PSC 1210 All-In-One InkJet Printer
No power.
Hi there try a different power socket in either your surge protector or on the wall. If this doesn't work I think something is blowing the power board of the printer check your electrics.
Thanks J
Feb 04, 2008 | Lexmark P315 InkJet Photo Printer
Fuji FinePix Z10fd Digital Camera Logo
158 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
