Question about Gaggia Syncrony Espresso Machine
Gaggia Synchrony - we need a new boiler.
Electrical fault caused by leaking boiler. Where can we get these spare parts from?
  • richard158 Mar 27, 2009
    Wil be useful as the m/c gets older. Boiler has eventually been found from Gaggia - but they are terribly slow and disorganized!
    Many thanks
    Richard
  • royzee May 11, 2010
    where in the world are you?
Http://www.cafeparts.com/dynamicIndex.asp This site has parts.
Posted on Mar 27, 2009
I just got a new Gaggia Synchrony Logic RS from amazon and it only leaks water when we turn it on?
brand new --out of the box-- still covered by warranty --don't fix --contact your supplier and ask for a return of defective item and a refund or a new unit as replacement
Jul 28, 2016 | Gaggia Synchrony Logic RS
My Gaggia Synchrony is leaking - If I remove the water catch basis, I can see a drip. We have used this machine every day for years - can the problem be fixed easily?
HI
There is a panel behind the brew unit, that has 2 screws. Remove it and clean the coffee residue behind it. That is what drains the pressure relieved after brewing, and has coffee residue that can build up and cause the leak. It should leak into the drip tray though, except when you rremove it.
Oct 23, 2010 | Gaggia Syncrony Compact Coffee...
I was descaling my machine (gaggia synchrony- 3 years old). After it ran thru the first cycle & I refilled it I can't get it to heat up again & it shows a light indicating there's no water- when...
Make sure that the sensor in the water tank has not stuck IIRC it's on the right hand side as you look at the machine from the front. Then run some water through the steam nozzle, it could just be that following the descale there is no water in the boiler and you just need to fill it as you did when it was new.
Hope this helps.
Aug 17, 2010 | Gaggia Syncrony Compact Coffee...
Electrical short
Replace the top boiler. Top part with the elements.
Mar 20, 2010 | Gaggia Classic Espresso Machine
Who do you decalcify your synchrony espresso
I assume yours is not the digital, here are some instructions for properly descaling your machine.
1. To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Once it is dissolved, place the tank back on the machine, and then turn the machine on.
2. If you just open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. Longer is better. It is very important that the machine does not remain on to heat the boiler anymore than necessary.
3. Repeat step #2 for your machine. Do this until you have consumed the entire water tank of solution (approximately four to five cycles). (I do it at night before I go to bed and let the last cycle set in the boiler till morning.)
4. Remove water tank and rinse it with fresh water.
5. Refill water tank with fresh water and place it back on the machine.
Repeat step #2 to rinse the machine, only this time use the entire water tank at one time, and there is no need to let it set.
Remember, it is better to descale more often than not enough.
Nov 20, 2009 | Gaggia Synchrony 90101 Espresso Machine
I need to replac steam valve for gaggia syncrony compact, where can I get the parts?
I get parts for my Synchrony from Cerini.
http://www.cerinicoffee.com/Gaggia_parts.asp
There are a couple of different stram valves. Call them to get the right one.
Nov 14, 2009 | Gaggia Syncrony Compact Digital Espresso...
Gaggia Synchrony wont work after decaling
Check the thermostats on the boiler and the boiler element?
Jul 14, 2009 | Gaggia Syncrony Espresso Machine
I have a Gaggia Synchrony compact. I recently decalsified it and it stopped working. The low water light is on and nothing works except, for the water pump. It will flow only cold water through the steam...
If it leaks from the steam wand then you need to get a new steam valve assembly. For the heat you will have to open the machine it is possible that the steam boiler is damaged or that the thermostat on there is bad, use an ohmsmeter to check thermostats and element. There are 2 screws in the grinder, 2 behind the water tank and about 2 or 3 in the front behind the door.
Jun 09, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia Synchrony Compact Digital Problem
I think you have get air in the system, try to find a bellows pump or similary. Fill it with water, open the steam knob and take of the water tank, put the pump in the water inlet and press. When the water begins to flow, close the steam knob and put the water tank back.
Best regards
/Mirran
Nov 01, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia Classic out of storage
What is the model?
Exactly where did it leak?
Mar 16, 2008 | Gaggia Classic Espresso Machine
Gaggia Syncrony Espresso Machine Logo
321 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
