Question about Hitachi Deskstar® 7K250 Hard Drive
My hard disk drive has been sh.cicuted .
Inspite of having warranty period of 3yrs, the shopkeeper can,t able to replace it.
    President:
  • 2,110 Answers
Try to contact nearest hitachi service center..there they can replace it easily......
Posted on Feb 16, 2009
Hard disk failure
Check if your hard drive is still in warranty period so you could ask for replacement from the manufacturer. Otherwise, simply buy a new hard drive and move all your data from the old one to the new drive.
SMART always predicts correct hard drive status and probably this time, you need to change it ASAP.
Hope it helps!!
Dec 07, 2012 | Western Digital WD Scorpio Blue WD2500BEVT...
I am facing problem with my samsung hard disk it gives error of s.m.a.r.t command failed and hard disk is in warranty period
The SMART monitoring software analyzes information from the drive to determine if some component is not functioning within spec. The system is not 100% accurate and often failures are detected when there is no failure. However, if your drive is in warranty and you wish to avoid data loss from a failure you will want to backup your data ASAP.
If the drive is within its warranty period you should start making arrangements to RMA the drive and receive a replacement.
After you have backed up data that you can not recover elsewhere contact the drive manufacturer or the store where you bought it, if it is within the return period, to obtain an RMA number and the required information for return
If the SMART error is preventing you from booting the computer or using the drive you can disable SMART monitoring within the bios. This will eliminate the monitoring which will eliminate the error message.
Jul 15, 2010 | Computers & Internet
Boot device
your hard disk has upto 3 years warranty from the day of purchase
May 26, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
My Maxtor Athena 20GB hard disk is in error
delete the entire partition and do a quick format....
then do partition according to your requirement and try formatting...
if it still says error, then use any disk formatting utility like partition magic and try one more time....
still problem then you should take it back for replacement if it comes under warranty period....
Apr 20, 2010 | Maxtor Hard Drive
How to check the warranty period of a hard disk drive
To check the warranty of your Seagate drive go here:
http://support.seagate.com/customer/warranty_validation.jsp?form=0
Mar 24, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
My external hard drive is not working. It makes a short, periodic buzzing sound and the power supply has a very high pitched but quiet ring to it... any thoughts?
If it still is under warranty, exercise the warranty, and get a replacement.
If the warranty has expired, disassemble the case, and extract the disk-drive. Connect that disk-drive as a "slave" disk-drive in some desktop computer, and see if the disk-drive is still functioning, and if the files on the disk-drive are still readable.
Mar 04, 2010 | Western Digital 250GB My Book Pro-External...
Hard Disk Replacement
Hi, google Hitachi - the info you require is on their website.
Jul 20, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Hard Disk Problem
Likely the drive has failed. First check the cabling, and settings in BIOS. Is the drive being detected by BIOS during bootup? Next see if Samsung has a drive diagnostics program which can be downloaded and run. This will usually tell you what is wrong with the drive, if anything.
You can do the process of elimination- Install a known good drive in your computer, take the suspect drive and install it in a spare or a friend's machine.
If it is bad, replacement is required. Any data on it is probably toast unless you wish to employ the expensive services of a data recovery business.
Jun 18, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Hard disk drive replacement
ur harddrive could be loose or damaged.If it's under warranty period its good to take it back,
Mar 09, 2008 | LG X-Note LM50 Notebook
Hitachi Deskstar® 7K250 Hard Drive Logo
65 people viewed this question
Top Hitachi Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
