Question about Indesit W 123 Front Load Washer
Washing machine will not empty
Pump is not blocked. Filter and pipes are free.
  • Anonymous Mar 15, 2009
    WONT DRAIN FEED UP :(
  • 121 Answers
Check electric connection on the pump and check pump electro motor.
Posted on Feb 16, 2009
AEG lavamat wont empty. Error code C2
I expect you will find the impeller is blocked in the outlet pump.
Apr 14, 2017 | AEG Washing Machines
What does the code "F 3" mean when pausing on front loader washing machine hisense 7.5kgs?
"F03" displayed on screen The washer is not emptied. The washer stops the program being executed. Shut down the machine and disconnect power supply. Check: • Drain pipe is knotted or not. • Filter in drain pump is blocked or not (refer to the cleaning of filter in drain pump) Hisense Washing Machines User Operation Manual Page 7
Feb 08, 2016 | Washing Machines
I have LG Washing Machine and the water does not drain whilst the machine is washing. What can be wrong?
problem is with main board MOSFET ,FET or Transistor , that are not switching your drain pump at right time , if your'e pump is fine, , you should check drain pump separately by giving it separate supply. ( see its data sheet for power )
Dec 22, 2014 | LG Washing Machines
What is error code F2 on my AEG washing machine
I believe that this is a "Pump Blockage" error. You need to locate and clean out your empty pump filter (Probably behind a little door on the bottom of the machine. You may also need to check the empty pipe and the drain it goes into are also clear. 99% probability of a blocked filter
Jul 01, 2011 | AEG Washing Machines
Wasing machine fills with water during washing and wont pump out filling the drum...
1. Empty the drum via the filter / trap at the front (there is sometimes a drain pipe near the filter - otherwise be prepared to use lots of towels to soak up the water).
2. Check / clean the filter.
3. Ensure that the drainage pipe is not blocked.
4. Check that the pipe from the pump to the waste water pipe is not kinked / blocked.
5. Check that the pipe from the drum to the pump is not blocked.
6. Does the pump sound like it's trying to work? If not, it could be that the pump is dead. Pumps can often become blocked with fluff / slime from the machine.
Jan 13, 2011 | Bosch Washing Machines
Please help the washer fills up and turns the
Seems like a blockage or maybe pump worn out. Fill machine and take grey outlet pipe on rear of machine. Place this pipe as low as possible into a bowl. If water flows free from this pipe then your pipes are not blocked and most likely you will need to change your pump. Before you try this just put machine onto spin and ensure this will work when machine is almost empty
Mar 12, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Wf 860 error code f05 psi switch jammed on full - machine had not emptied water. Is this faulty switch or blocked pump etc?
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Check for blockage first.
Feb 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
Servis Washing machine clothes wet
I don't know the specific machine, but this is a fairly generic problem, so I hope the following helps: The empty pump cycle is a timed operation, the fact that there is still water in the drum after the time allowed for the pump to drain it has run out means that the water isn't clearing out fast enough.
In order of probability, the problem is usually caused by:
1. A blocked filter
2. An obstruction in the empty pipe or drain
3. A Faulty pump
1 Blocked Filter: Many machines have a small door in the bottom of the chassis. Behind this door (Usually about 5 inches square) is a filter, which will usually unscrew. In this filter you will find fluff, string, coins, the odd small sock and all sorts of nasty stuff if you haven't had the filter out before. If the filter is blocked then the pump is having to draw water through all that gunk and it will run out of time and leave water in the drum. Clean the filter in the sink, pocket the coins you find and make a note to clean it regularly in the future Most manufactures will suggest you check it every 2 months or so, depends how often you are using the machine of course.
Unfortunately, other machines do not have filters so easily accessible. If there is no door or obvious access to the filter, some manufacturers put a trap in the rubber hose that feeds the pump. The pain here is that the access to these traps is gained by dragging the bachine out of its place under the work surface and tipping it on to its back. Track the waste pipe back to locate the pump. On the other side of the pump will be a thicker (usually black rubber) pipe and built into this pipe is usually a little bucket that stuff can fall into before it gets to the pump. You can usually squeeze the pipe and feel if there is stuff in it. If there is, then depending on the machine again, some of these traps will have a plug in the bottom that is held in place by a spring clip (Pliers to compress the spring to get it off) or a screw clip (Unscrew with a screwdriver). Enev if there is no trap as such, squeeze the rubber delivery pipe and feel for obstructions (Often a sock!), if necessary, disconnect the pipe from the pump to gain access to the blockage. WARNING!: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, to the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend butting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
2. An obstruction in the empty pipe or drain: Start at the point that the pipe enters the household drain pipe, pull out the empty pipe and check that water will flow freely into the drain (Stuffing the garden hose down there and turning it on (but not TOO FAST) will usually demonstrate if there is a blockage. If this is free, check the pipe that runs from the pump to the drain (This will need the machine tipping as described above, and possibly the pipe removing from the pump to check it.
3. A Faulty Pump:If you have done everything described so far, then you have checked for obstructions in the pipe leading to the pump, the pipe leading away and you have cleaned out any filters or traps... If you still have a problem, you have a faulty pump. This is highly unlikely. These pumps have induction motors (no brushes to fail) and in my experience, they either work, or they don't. They very seldom "work a bit". If SOME water is being pumped (check by putting the empty hose in the sink and watching) then you really need to double check your work before replacing the pump. Good news is, if you do have to they are usually reasonably priced.
Feb 09, 2009 | Select Brands Washing Machines
Washing machine
check your filter and or pump
Jun 05, 2008 | Haier Washing Machines
Indesit W 123 Front Load Washer Logo
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
