Question about Dryers
Gas doesn't come on
The igniter comes on ( glows red ) but the gas doesn't turn on. The drum is turning and the igniter glows & thats it.
  • 1 more comment
  • Stephen Shorma Feb 16, 2009
    Sorry
    I had posted the model then it was at the bottom so I deleted it from the story
    Model DG482
    Serial 376627TT
    Series 5
    Thanks Steve
  • Stephen Shorma Feb 18, 2009
    I have a Maytag model DG482 gas clothes dryer. Serial #376627TT. The original complaint was the dryer turns, igniter glows but doesn't heat. I called my local appliance parts store & told me it needed a solenoid kit. I replaced the solenoid & thought it was working. Now the gas does kick in but the dry (control) switch doesn't seem to move. Also at times I can see the igniter glowing without the gas coming on. The dryer is drying but seems to run constant. Are there humidity sensor that once the clothes dry to a point the dryer control moves to cool down? Wondering if I have multiple problems. So my 2 questions are does clothes dryness regulate the control switch & is it normal for the igniter to glow without the gas coming on? Hate to keep throwing parts at it. Right now not sure what to do. So far have not received any help but sure could use some.
    Thanks
    Steve
    What should the voltages be? Also there are 2 wires going to the one solenoid & 3 wires to the other. How do you check the control panel. Humidity is not a factor? I do think this may be getting over my head.
    thanks
    Steve
  • Dryers Master
  • 8,205 Answers
The fuse is ok because the power is going into the gas assembly and the ignitor is working so why won't the gas come out and ignite? Well the ignitor uses so much power is robs the coils of enough energy to open. The flame sensor shuts down the ignitor at 1800 F. The power surges through those coils and that opens the valve. The raw gas hits the ignitor and the flame stays on UNTIL the control thermostat (mounted on the blower next to the skinny white fuse) shuts down the power to the assembly. The dryer still runs tumbling the clothes till the drum cools down and the thermostat again powers up the gas assembly.If the fuse is blown in this model the unit will keep running. On these models the coils will get hot and quit, cool off and maybe work again. Sometimes not at all. I would say you needs to replace these puppys. Part number 279834
gas doesn't come on - 0b055d4.jpgLess than $30 Easy to replace.
Posted on Feb 18, 2009
  • 6,784 Answers
Hi there, your gas shut off valve may be in the off position or, the manifold may be clogged with mineral participates. you can disassemble the manifold assembly and, blow it out with pressured air. this will clear all blockages that may exist.
  • Michael Masters
    Michael Masters Feb 18, 2009
    the dryer doesn't regulate the clothes dryness by sensors, the actual control panel uses time to assume the dryness. if you set it for 10 min, it will run for 10mins.Secondly, the igniton may have some issues with timing. it should cut off immediately after the flame is ignited. being that it is a glow ignition, it takes half a min for the glow ignition to reach a cool state, considering the fact that, its temperature is well above 300 when in lighting mode.
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason to this problem may be the coil.
so replace the coil on the gas valve.It is a
common problem that occurs.
try this out..
thank u..
Posted on Feb 16, 2009
  • Hariharanath V Feb 17, 2009
    hi..replacing the coil on the gas valve will
    solve the issue.
    check this out..
    thanks..
    Master:
  • 848 Answers
Hi
model details please......
  • Dryers Master
  • 19,396 Answers
Check and eventiually replace the valve assembly or the termocouple that controls the valve.
  • Ginko
    Ginko Feb 16, 2009
    Either the valve is faulty and does not open, or the termocouple that keeps the valve closed untill full flame temperature is reached is faulty.
    To test a termocouple you use a multimeter, and read continuity (impedance), that at room temperature is about 1K ohms.
    to test the valve, if it is electrically controlled (normally it is) you check voltages in, if the valve gets no power then test wiring harness and control board.
    If the valve is controlled normally, and termocouple is fine, then try energizing the valve, if it is stuck , replace it.
Frigidaire oven FGB24L2ASA. Igniter glows red, gas turns on, but does not light.
I appreciate your inquiry, K Ogle!
From what you have described about your Frigidaire range the igniter glows red and the gas turns on but it will not light. It sounds like it could be a faulty burner or igniter and I would recommend having a professional come out to properly assess your range. This does not sound like a simple DIY job. Good luck. -Matt
Feb 17, 2015 | Frigidaire Kitchen Ranges
The electronic ignition on a gas water heater will not heat up and glow red to ignite the gas to heat the water atwood r/v water heater
You won't see any red glow until the burner ignites and burns for a while. Its only an ignitor and flame sensor, not a glow plug style.The ignitor has to provide spark for gas to ignite, then it also senses the flame and keeps gas flow coming. What exactly is happening when you turn it to on?
Jul 18, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have gas dryer that igniter glows but gas does not ignite drum turns vent is clear
Likely you have a bad gas valve coil set. There are two small black cylinders on top of the gas valve... if these are bad they will not open the valve to let gas come in.
Jan 28, 2010 | Kenmore Dryers
Gas dryer does not make heat.
You may have a simple matter of a weak igniter. Just because an igniter glows, does not mean it is good. They do wear with age and eventually require replacement. The way the ignition system is supposed to work is like this:
1. Select the dryer cycle and press start.
2. The drum begins to spin and the igniter begins to glow.
3. Once the igniter reaches a certain current potential, the gas safety valve opens.
4. Gas is introduced into the manifold and you have ignition.
  1. NOTE: It can take roughly 30 – 90 seconds from the time you start the dryer to the time it takes for the gas to ignite.
NOTE: This is a designed safety feature of the appliance that prevents free flowing gas from accumulating in your home without ignition. That’s why you typically don’t hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
TWO BASIC IGNITER TYPES:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
The igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn’t produce enough current to open the gas safety valve (in this case the igniter will still glow but the manifold still won’t light). Longer ignition times can be another symptom of an igniter possibly going bad.
You can purchase a replacement at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also offer some excellent exploded view diagrams of the appliance.
If your replacement igniter comes with a connector plug that does not match your appliance, you will be instructed to cut the old plug off and splice the wires together using ceramic wire lugs included in the kit. Do not use standard wire lugs as they will melt.
If the model number is correct, the part number for a replacement igniter on this dryer is either 4391996 or 33002789. The part number depends on your SERIAL NUMBER. If you need assistance determining which one to use, post back with your serial number and I can confirm it for you.
I hope this helps you.
Dec 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer works, but does not heat
Hello there:
here is a discriptive way of trouble shooting the dryer and it lists the common components that will normally fail if the element has not failed first
Gas Dryer Diagnosticsgasdryerguts.gifThis picture shows the main parts of a gas dryer's burner systemthat can fail. Understanding each component and it's failure mode canreally help diagnose a problem with a gas dryer.
Ignitor failure: The drum turns but the igniter doesn't glow, thereis no clacking sound as the gas valves open and there is no flameignition sound.
Radiant Sensor failure: The drum turns but the igniter doesn't glow,there is no clacking sound as the gas valves open and there is no flameignition sound.
Gas Valve Solenoid failure: The drum turns and the igniter glows andgets turned off but there is no clacking sound as the gas valves openand there is no flame ignition sound.
And another component failure to be aware of, but that's not shown here, is the operating thermostat:
Operating Thermostat failure: The drum turns but the igniter doesn'tglow, the gas valves don't open (there is no clacking sound) and thereis no flame ignition sound.
And here's a picture of other components to ohm out if you're getting no heating at all:
Nov 21, 2009 | Hotpoint Dryers
Flame will come on at first start then will run for a few mins then turn off then ignition will come on but gas will not turn on
cool you recognize the fact that the igniter is turning on you are obvisouly tech savy so I will dispense with the usual amenities and give you a technicians answere.. igniter gets power and when it reaches max current opens gas valve as time goes on igniter still glows red but doesn,t generate enough current to open gas valve change the igniter first (cheap) if it doesent work check your gas pressure ( need a guy with a special meter) if pressure is too high ( not very common) valve has trouble over comming pressure to open if pressure is ok then time to change out main gas valve Good Luck
Oct 26, 2009 | Dryers
The dryers does not light
I will be happy to assit you with this issue
I have a web side that will help you.
http://www.youtube.com/watch?v=f1rebeCMVsk&feature=fvw
was this helpful?
your rating is very important so I can help others.
thank you
Oct 18, 2009 | Kenmore Dryers
My oven doesn't work but the burners do, what's up with that?
I was looking for a solution to my problem. In reading the comments, I can probably provide more information than is given here. My Kenmore gas oven won't ignite. I have over 25 years as an electronics techincian so I am very aware of lethal voltages. I unplugged my stove, it is a 120 volt model. After pulling the panel off so I could get to the thermostat which is the piece the knob goes on, I plugged the stove in and checked to make sure I have 120VAC to the thermostat. I have a red wire which has 120Vac, the thermostat probe wires, and a yellow wire which goes down to the back of the oven.
My red wire had 120Vac. I then unplugged the stove, very important at this point, and meaured with an ohmmeter across the yellow and red wires. When the oven is in the off position this is open. When I turn the oven on it is shorted. That should confirm the thermostat switch works. The next thing that has to happen is the glow bar/igniter has to glow. This is like all gas appliances, it has to glow to heat the gas valve and turn the gas on. My igniter doesn't glow so I ordered a new igniter. If your glow bar glows, it could still be the glow bar/igniter or the gas valve is not allowing gas to flow even after it is heated up.
If anyone sees a problem with this procedure, please let me know.
Nov 19, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Dryers Logo
35 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
