Question about Tascam US-144 Sound Card
Tascam US-144 Sound Card - no valid signal
I'v updated driver and firmware, but the panel says no valid signal, could it be a hadware problem?
  • primebrit Mar 11, 2009
    Same here. Digital Input Status = no valid signal?
SOURCE: Tascam US-144
If I'm reading this correctly you may be having the same issue I was having a few weeks ago.  When the US-144 is plugged into your computer while running a program like Cubase your onboard sound card is totally bypassed and the US-144 takes its position.  So the output of your normal sound card is not going to produce anything while you are recording.  Use the LINE OUT or PHONES connector on the US-144 itself as the connection for your speakers. Of course that may not be your issue at all, but it was driving me mad for a few weeks until I realized the simplicity of my error.
Posted on Dec 08, 2008
SOURCE: Us 144 firmware not updating with Lepord
Try going to Add/Remove software and removing tascam software. Then, unpack your new drivers.
Posted on Dec 29, 2008
SOURCE: Can't get a signal with my Tascam US-144
Make sure the Tascam is has updated drivers. The latest driver is Version 1.12. Something that helped me as well was to re-route my sound card to the Tascam. Meaning to have Windows, use the Tascam as the sound card for the computer.
This is the advice I followed from a forum it helped me alot!
I eventually disabled all other sound cards on my PC. In my case it was simply the integrated soundcard on my motherboard. I did this in the bios setting. I also uninstalled the drivers for it, just in case. I was having problems hearing anything in Cubase before I did this.
I set the US-144 as my default sound device in Windows (Control Panel>Sounds and Audio Devices>Audio)
I'm not sure what you are trying to record so I will give you a guitar example.
Guitar plugged directly into LINE/GUITAR IN R using the 1/4" jack with the switch above it in the GUITAR position. You can use the INPUT R dial to adjust the input volume for this channel. The SIG/OL light should turn green when you strum the guitar.
The US-144 is plugged into a USB 2.0 port on the PC.
Speakers are plugged into the LINE OUT jacks on the back of the US-144. The MON MIX dial will adjust what goes out through these jacks. If you move the dial all the way to the left, you will hear the input from the guitar directly from the US-144. If you move the dial all the way to the right, the signal goes through the US-144, into the PC via the USB connection, then back to the US-144 through the USB cable, and then out through the line out jacks. You may not hear anything when it is all the way to the right until you have Cubase open and configured properly. IMPORTANT NOTE: If you have MON MIX dial turned all the way to INPUT, you will not hear anything being output from your computer.
The LINE OUT dial adjusts the volume through the LINE OUT jacks. Make sure this isn't turned all the way down.
At this point, you should be able to turn the MON MIX dial all the way to INPUT and hear your guitar. It will probably only be coming out of the Right speaker, which is what it should be doing. Now turn the MON MIX dial back to somewhere in the middle so you can hear both the input from the guitar and your PC.
I downloaded and installed any updates that were available for Cubase LE 4 (I think all I needed was the 4.1.3 hotfix).
In Cubase goto Devices>Device Setup>VST Audio System and choose the US-122L /US-144 ASIO driver from the pull down menu. I'm not sure how important the "Relase Driver when Application is in Background" checkbox is, but mine is unchecked. If you click on the US-122L / US-144 section, you will see a button for the Control Panel. It will tell you what your driver and firmware are and what USB mode you are operationg in, etc. I didn't mess with any of these settings, but it is good to know how to get there. You should also see all your in's and outs. I have 2 analog in's and out's and 2 digital in's and out's. I am only using the analog in's and out's. Hit OK to close out this menu.
Now goto Devices>VST Connections and you should get a new window. There is an "Inputs" tab and an "Outputs" tab. Under Outputs, you should have a Bus for Stereo Out using the US-144 as your Audio Device and the US-144 Analog outs for the device ports. Make sure the "CLICK" colum is checked if you want to hear your Cubase metronome through your speakers. If you don't have a bus, add one and set it up as I have described.
Now goto the Inputs tab and add a mono input using the US-144 analog in R as the Device Port.
Now start a new project and add an Audio track using the Mono in and stereo output. Use the Edit Channel Setting button if you have to change your input and output.
Now with the MON MIX dial all the way to the right and with the Monitor button enabled on your audio track, you should be able to hear your guitar through Cubase.
Now if you turn on the Record Enable Button on your track and then press the Transport Record button, you should be able to record your guitar. Hit stop and then go to the beginning of the track and hit play. You should be able to hear what you just recorded. Don't forget that if the MON MIX dial is all the way to the left, you won't hear anything from your computer.
Well that is my Cubase LE / Tascam US-144 Getting started guide written by a newbie for newbies. May my pain and suffering alleviate some of yours. Good luck.
Posted on Jan 06, 2009
prodcali
  • 198 Answers
SOURCE: TASCAM US 144 and Mac incompatible???
A lot of the Audio drivers or Tascam and m-audio devices really only work for windows 32 bit reason i tried installing the same stuff for windows 64bit won't work in less u have vista 64bit But regular windows 32 bit works with every program out there. The mac if it did work it should pick up a signal if it worked properly but it sounds like the mac don't read it even with drivers .
This also could be a problem with your device if you had the same problem with it last time. replace it with a new one and try the install again on your computer and see if it works after that.
Posted on Aug 21, 2009
SOURCE: Do I have to have a sound card or module hooked up
Yes all the things which are connected with sound,they want to start first sound to achieve our sound.
In this condition please reset or install your sound driver.
If you have had then try with your sound card edited in your motherboard.
If these condition may not work to cooperate then try with the new sound card by editing.
Posted on Nov 27, 2009
I just switched computers to a "Satellite" by Toshiba. On my old computer (windows XP) my TASCAM us 144 worked perfectly on a free program called WavePad. My new laptop runs Windows 7 64bit. I...
It sounds like it maybe an asio problem or latencey issue. You need to increase the latencey in the control panel of your tascam soundcard and this should hopefully cure you .
Jan 07, 2011 | Tascam US-144 Sound Card
Mac drivers
Hello there. a quick google dive pulled up thefollowing page on TASCAM's website
http://tascam.com/product/us-144/downloads/
The second catergory listed would be drivers for MacOS. From that list,the 2.00 driver, which would be the second in the list, would be the most updated driver.
I hope this helps.
Oct 22, 2010 | Tascam US-144 Sound Card
I have been given a 144mk2 but it has no driver disc can you tell me where I can download/purchase the driver. Thanks.Alex. Ps I live in the UK
Here is a link to the US-144 drivers:-
http://www.tascam.com/products/us-144;9,15,70,19.html
Apparently there have been problems with this device - it is recommneded to use the lastest firmware.
Nov 02, 2009 | Tascam US-144 Sound Card
Aug 14, 2009 | Tascam US-144 Sound Card
144 drops out
To see if it's your hardware, up your latency settings to "highest" via the tascam control panel. Also, be sure you are familiar with the various ways to up latency in your recording package: in cubase it's under device settings, vst bay. If this works, you know it's some setting somewhere. Try disabling your internet connections and setting pc performance to "background services" Also, read a pc optimization guide for daws - they are everywhere. Tascam will email one to you if you ask.
Lastly - try the asio4all driver. This fixed my pops, but when I understood all the various latency settings and set the tascam to highest latency, I could use the tascam driver. Highest latency on my p4 3.0 2gb ram pc means 12ms input and my output is 61ms.
If the asio4all driver works - it's a likely latency issue.
Jan 25, 2009 | Tascam US-144 Sound Card
Dec 26, 2008 | Tascam US-144 Sound Card
Nov 27, 2008 | Tascam US-144 Sound Card
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
Cubase software does not recognize my TASCAM US-144
do u have usb 2.0 prts in back use not front of pc those 1.1 ports ok cheak drivers on all tell your master sound drivers defult to tascam see what happends
Jan 15, 2008 | Tascam US-144 Sound Card
Tascam US-144 Sound Card Logo
1,344 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Chris Larocque
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
