Question about Northstar 951XD GPS Receiver
Looking for a mounting brackett and thumb tighteners for a 951 x
The unit is a Northstar
Thank you for your effort. I resolved my problem at a local marine shop.
Posted on Feb 17, 2009
Need more friction on movements. The slightest touch moves off target
Remove the 3 screws holding the black cover on the mounting arm. Gently tighten the lock nut until you achieve the required resistance but not too much that motor won't function. I found less that 1/8th of a turn was enough.
Feb 17, 2012 | Bushnell NorthStar 78-8831 (525 x 76mm)...
My dryer stopped tumbling so i got a belt for it im trying to put it on but the pulley is off how can i easily and cheaply fix this myself
Hi kelleyhar25
You did not say what the manufacturer of your dryer was, so it is hard to tell you where to place the idler pulley brackett...
The idler pulley should be attached to a piece of metal, that piece of metal will slip into a slot at the bottom of the dryer. Look for a small worn spot on the bottom of the dryer and that is where the idler arm brackett will connect to.
I will send you to a webpage to show you how to route your dryer belt and also show the position of the brackett in many different dryers.
Please take time to rate me
http://www.expertappliance.com/dryerbeltconfiguration.html
Aug 24, 2011 | KitchenAid Dryers
Water pump is leaking on my 2001 Chevy Malibu need instructions on how to relace
water pumps are preaty easy to replace just need to remove the belt and maby a mounting brackett but its straight forward from there. if you need to see this done i find youtube videos are helpfull just type in what you are looking for in this case you want how to change a water pump chevy malibu.. i hope this helps..
Jul 24, 2011 | 2001 Chevrolet Malibu
The needle is hitting the base plate
I am sorry, I am not sure what you have already tried...
Your needle may be mounted incorrectly, it may not be mounted all the way into the channel before the thumb-screw was tightened. Or, the needle may be bent. Try a new needle and carefully mount it and make sure it is all the way up the channel and straight before tightening the thumb screw.
Make sure your base plate is closed all the way and positioned correctly. If you have the feed-dogs covered for machine embroidery, make sure it is set correctly or remove it if not needed.
good luck
Jun 24, 2011 | Kenmore 15358
Looking to replace triger (leaks)
NorthStar brand equipment comes from Northern Tool. You can't replace the trigger, but they sell the replacement spray wand here and it's only $11.99. There are other wands, some longer, etc. They are pretty universal -- you just slide them onto the hose and tighten the band clamp. Good luck! If this is helpful, please rate my answer, thanks!
Jun 02, 2010 | Northstar ATV Tree Sprayer 16 Gallon, 1...
Need a northstar 951 X power cable
I may have one, as my screen is dead, like MANY others!
Oct 24, 2009 | Northstar 951XD GPS Receiver
Found top motor pivot mount broken off of plastic tub. Got belt back on and unit is functional but mount still broken and motor leans.Is a repair brackett available. ty
Hey overman,
Sorry to hear that, I think you may have to look at an Outer Tub replacement.
You may have these links but I will post them just in case.
The Service Manual for reference. Sears Parts Direct for reference.
Outer Tub P/N 25001199
I would call Maytag the outer Tub is warranted for 10 yrs per the the Service Manual.
Good luck Rich.
Jul 18, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Northstar 951 GPS shows boat moving & @ high speeds (over 100)
RE: Northstar 951 GPS Receiver
Contact & Support @ http://www.northstarnav.com/en/Support/
jack
0501102.jpgPlease Rate This Now or Later!
Feb 22, 2009 | Northstar 951XD GPS Receiver
Waypoints and nav log
Based on your description I would suspect that the internal memory battery is depleted and needs to be replaced. This battery is required to retain waypoint and route information when the input power is low or turned off. The battery is soldered onto the main circuit board and needs to be replaced by a technician having good soldering skills and access to instructions for the disassembly and reassembly of the unit. There is a list of dealers on the Northstar website. Review the list and make a couple of phone calls to see which ones will do bench work on this unit.
Mar 23, 2008 | Northstar 951XW GPS Receiver
Gps loses signal
It would be good to make sure that the 951 software is up to date. The most recent software upgrade includes new code required due to changes that have been made to the GPS system. You can download the software for free from the Northstar web site but it requires a loader cable, power supply and a Windows based PC to perform the update. Most Noprthstar dealers know how to do this but they will charge for their time. The GPS antenna should be mounted where it has a 360 degree uninhibited view of the sky right down to the horizon to get best performance. Basicially any conductive material including pigmented paint, tinted glass or wet canvas can block the signal. Inspect the GPS coaxial cable and it's connections for any signs of corrosion or contamination. Sometimes just removing and reinstalling the connections is enough to remove contamination and get better performance. If in doubt concerning the coax and it's connections, temporaily substitute a new coax assy by-passing the existing cable to see if this makes a difference. You can monitor changes from the GPS status page. See the user manual for information concerning how to understand the numbers being presented. You should be tracking at least 4 SATs with signal levels higher than 30. Generally 95% of all GPS signal issues are related to the coax or its connections.
coax assy to v
Jul 26, 2007 | Northstar 951XW GPS Receiver
Northstar 951XD GPS Receiver Logo
65 people viewed this question
Top Northstar GPS Experts
Will Halftowaite
Are you a Northstar GPS Expert? Answer questions, earn points and help others
