Question about Samsung SGH-E251 Mobile Phone - Black
How to connect blue tooth from pc to samsung cameramobile?
How to connect bluetooth from pc to samsung cameramobile?
  • 1 more comment
  • Anonymous Mar 29, 2009
    i cant connect my blue tooth
  • ejvictoria04 Apr 08, 2009
    i can't connect my blue tooth to the pc. i can't transfer my photos to the pc and i can't decode my phone. waht is the default code for samsung e250?
  • Anonymous Mar 15, 2014
    how to connect nokia blue tooth headset to samsung SIII GT i9300
    Guru:
  • 832 Answers
Hi there!
While the specific user interfaces implemented by manufacturers may differ from device to device, there are still some very basic steps to go through in connecting two devices for the first time. Users should always conduct the pairing process in a secure environment.
Charge the Devices
If the devices are new Bluetooth devices, often they must be charged before they can connect or turn on. This is particularly true of new Bluetooth headsets, which must be charged before use.
Power Up the Devices
Power up the devices you are trying to pair. With some devices, like Bluetooth wireless headsets, powering up the device also initiates the pairing process.
Turn the Bluetooth Functionality On
The Bluetooth functionality in a device may or may not be turned on when you receive the device. For many computers, users will need to turn the Bluetooth radio on from the control panel or system preferences.
Make the Devices Visible
As a security measure, some devices allow the Bluetooth functionality to be off, hidden, or visible. When trying to connect devices, users should make the devices visible so the devices can discover one another. After the devices are paired, users can set the devices to hidden if they have concerns about their devices being discovered by others.
Place Both Devices in the Connection Mode
After both devices are charged, powered up, and the Bluetooth functionality is turned on, each device needs to initiate a communication session. Typically, in a connection between two devices, one device acts as the “host” and the other device acts as the ”guest.” The device in the host role is the one with the user interface from which most of the connection setup will take place. A device can be in the host role with one device and in the guest role with another device. For example, in a phone and wireless headset pairing, the phone is the host. However, in a phone and laptop pairing, the laptop is the host.
Enter the Passcode
After the two devices have discovered one another, the user will be asked to enter in a passcode in one if not both of the devices. In some cases, like with wireless headsets, the passcode is a fixed passcode assigned to the headset by the manufacturer. In those cases, the user enters the assigned passcode into the host device. The user will find this passcode in the user manual. In other cases, the user will be able to enter in his/her own passcode. In these cases, the user will enter the passcode once into each device. It is highly recommended that users employ an eight character alphanumeric passcode for the one-time pairing process. After the passcode is entered, the devices will validate one another and complete the establishment of a trusted connection.
Deleting or Disconnecting Trusted Devices
When should a user delete or disconnect a trusted device? If one of your Bluetooth enabled devices is lost or stolen, you should unpair that device with all the devices to which it was previously paired.
How do you unpair or delete a trusted device? For devices like a mobile phone or computer, the user should go into the device connectivity settings and find the list of trusted devices. The user should then have the option of adding a new device or deleting a trusted device. Highlight the device you want to delete and push the delete button. A device like a keyboard or mouse, which only has a button or switch as a user interface, can only connect to one device at a time. To delete its previous trusted device, the mouse or keyboard just needs to be connected to a new device
Or you can try this:
Bluetooth Mobile Phone to Bluetooth Personal Computer
  1. Power up both the mobile phone and the personal computer.
  2. On the PC, open up the control panel and find the Bluetooth Device Wizard. This will assist the user in setting up a Bluetooth connection between the PC and trusted devices.
  3. Ensure the Bluetooth connectivity is turned on in the PC.
  4. Find the connectivity settings of the phone. Make sure Bluetooth connectivity is on and visible.
  5. On the PC, choose to find and add a specific Bluetooth device.
  6. Of the devices found, pick the mobile phone with which to pair.
  7. PC will generate a PIN code.
  8. Mobile phone will ask if you wish to be connected to the PC.
  9. After the user answers in the affirmative, the user will be prompted for the PIN code on the mobile phone. Enter the PIN code into the mobile phone, which the PC generated.
  10. Allow devices to complete the establishment of a trusted link.
  11. If prompted on the PC to choose the Bluetooth services, the user may have several services available. The user may be able to sync the phone and PC. The user may be able to set up dial-up networking (DUN) preferences so that the user can use the mobile phone as a modem for the PC over the Bluetooth connection. The user may be able to transfer files, like pictures or business contacts, between the mobile phone and the laptop.
  12. After choosing which services the user wishes to enable, the user can then finish the connection and exit the setup on the PC.
better yet go to this website: http://www.bluetooth.com/Bluetooth/Products/Devices/Generic_Pairing_Instructions.htm
Posted on Feb 16, 2009
  • Dennis Jambalos
    Dennis Jambalos Feb 16, 2009
    hi there!
    Charge the Devices
    Enter the Passcode
    better yet go to this website: http://www.bluetooth.com/Bluetooth/Produ...
  • 43 Answers
Turn on the your pc bluetooth and device bluetooth.
than pair it with each other.
now you can use the blurtooth connection.
Posted on Apr 15, 2009
How do I connect an sbt-105 bluetooth headset to my computer(or is it even possible)?
Does your PC have blue tooth enabled? It may need a blue tooth dongle in order to see the headset
Aug 21, 2014 | Samsung Att Captivate Glide Over The Head...
I dont have data cable of nokia 1209 then, how i connect my mobile to my pc ?
you could connect using your bluetooth, just turn on your bluetooth and connect.
Jul 15, 2011 | Cell Phones
How to connect samsung gt c3200 to pc through bluetooth
yu need to install samsung pc suite on yo pc , when yu open the pc suite it will ask you the method yu want to use to connet yo 4ne ,cable or bluetooth.if yo pc don"t have blue tooth yu can buy a blue tooth dongle
Mar 20, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Hi, My WEP460 samsung Bluetooth head set will not connect to my PS3. What do I do?
You have to make sure your blue tooth device is in discovery mode .most blue tooth manufactures use the power button by holding it down for 6 to 10 seconds while turning your bt device on ,once in discovery mode they should pair but you will need a pin or pairing code.Most blue tooth device manufactures use a factory 4 digit pin they are as follows 0000,1234,1111, or 9999 i hope this helps
Feb 19, 2011 | Samsung WEP460 Bluetooth Headset
Please describe your how to connect samsung metro3500 mobile to pc problem:
you can connect in two ways one by blue tooth and other by usb cable if you are connecting by Bluetooth you need Bluetooth for your pc its a usb module you can buy it in the shops connect the usb module to the PC and download the driver then pair your blue tooth with PC the other way i mentioned is usb cable you have to download the mobile office for the mobile so mobile can interact with you pc
Oct 30, 2010 | Computers & Internet
Not working Bluetooth in my Samsung Mobile Model No.SGH-X820
try an antivirus called net protector . load net protector on your main pc, use a cable to connect your mobile to pc using a compatible software for data transfer.
mobile will get detected in the antivirus software,SCAN YOUR MOBILE may be u are lucky to get blue tooth woking , if the file has come through blue tooth netwoking , pushed by some one when blue tooth was on some time. OTHER WISE do a factory reset and save all data first.
if this too fails then the blue tooth hardware/software has to be rectified.
Sep 20, 2009 | Samsung SGH-X820 Phone
Having trouble connecting Explorer 320 to Samsung Blackjack II
Push And Hold The On Off Switch On The Blue Tooth Till It Flashes Blue And Red. Then Search For The BlueTooth When Found Push The Button On The Blue Tooth Again. Hope This Helps
Jan 04, 2009 | Plantronics Explorer 320 Wireless Headset
How to connect between blue tooth with samsung phone ?
With a samsung cell phone press the MENU button then scroll to SETTINGS then scroll to BLUETOOTH. Once there select the option ENABLE and turn on bluetooth then sync and your set. Also make sure that your blue tooth is compatible with your phone.
Dec 07, 2008 | Lands Phones
I do not have data cable I want to connect to PC via blue tooth
GAME DIDNT TRANSFER. PLEASE CHECK BLUETOOTH CONNECTION
Nov 12, 2008 | Nokia 6233 Cellular Phone
Bluetooth conection
you have to activate blue tooth connectivity on your phone
Dec 02, 2007 | Toshiba Tecra A8-S8514 Notebook
Samsung SGH-E251 Mobile Phone - Black Logo
493 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
