Question about Zyxel P660HW-D1 Router
Wireless network not showing
The wlan light is on but the when the macbook "airport" scans it does not find the network.
  • 36 Answers
Turn the router off and wait for a minute or three...turn it on again and scan for the wireless network in range. if it doesnt find it again, reset the router, by reseting you clearout all statistics saved on the router, and therefor more easy to find. you also have to reprogram the router(put in the adresses,DNS,
Posted on Mar 08, 2009
My d-link DAP-1320 connects to my wireless airport extreme but not internet
REINSTALL THE DRIVERS AND SOFTWARE FOR DLINK. TRY A DIFFERENT TYPE OF USB WLAN.
Mar 14, 2014 | D-Link DAP-1320 Wireless Range Extender
Apple Macbook Pro does not connect to wireless network
The antennas in the Macbook Pros have had an issue with reception due to the aluminum housing of the laptop but, should still receive decent reception just not as much as a plastic Macbook or plastic PC laptop. It could be possible that the antenna's cables have become disconnected from the Airport Extreme card inside your Macbook Pro, that the card itself is faulty or damaged or that the Antennas themselves have been damaged in some way. As always make sure you have the latest updates and have installed any driver updates from Apple regarding your Airport Extreme card. Here's an article that may help eliminate any wireless interference that may be affecting your signal strength. Apple - Wireless Interference hope this helps, if so don't forget to comment, vote, etc. Thank you.
May 28, 2010 | Apple MacBook Mac Notebook
Cannot see wireless network in airport icon list
Open your airport utility (Applications/Utilities/Airport Utility). See if anything comes up on the left. If not, reset your airport and network.
Also, in System Preferences, click Network. See what it shows for airport, and delete your current network, and set up a new one. Do you have bars on your airport on the tool bar?
May 15, 2010 | Apple MacBook Pro Laptop Computer with...
Macbook and wireless n setup how do you set it up????!!!!!
Can you clarify the problem for me:
1. Mac Type = Macbook
2. Operating System = Mac OS ?
3. What are you trying to connect to?
For example are you trying to set up a Wireless Home network, meaning that iPhones, iPods or other macs can share the one Internet Connection. This is called a Computer-to-Computer Network.
OR are you trying to configure a Wireless Modem to work with your MacBook?
Setting up a Computer-to-Computer Network is done by:
1. Select System Preferences from the Apple Menu.
2. Select Network from the Internet & Wireless section.
3. Select Airport from the list of devices.
4. Click the Turn Airport On button, located next to Status. NOTE: If it is already turned on then this button will read Turn Airport Off.
5. Select Create Network from the drop down menu adjacent Network Name.
6. Type in the preferred name that you wish to call your network in the Name field. (ie., MacBookHomeNetwork or something)
7. Select the Channel (Channel 11) is an OK one to select.
8. Choose whether you want the user to type in a password to gain access to your network. (This is recommended.) If you do, then click the check box beside Require Password.
8.1 Type in the Password into the Password field.
8.2 Type the Password again into the Verify field.
8.3 Select the type of encryption you want to use, 40bit or 128bit.
9. Click the Show Airport status in Menu Bar check box.
NOTE: If you require advanced settings, then click the Advanced ... button.
10. Apply and then go back to the System Preferences window (using the Left Arrow located top/left of window). If you get stuck, get back using Instruction No.1 above.)
11. Click the Sharing Icon in the Internet & Wireless section.
12. Select from the list each item you wish to share (i.e, File, Printer, Bluetooth, Internet, DVD or CD etc...).
NOW : From your other device, you need to locate the new Wireless Network Connection.
If it is an iPhone or iPod then go to the Settings menu and select Wi-Fi from the list. The new network should be picked up automatically. Log in to it (if you set up passwords).
I hope this helps. Regards,
Feb 05, 2010 | Computers & Internet
What is the best software on Mac to detect wireless network?
The simplest wifi detection software is already in Mac OS and is pretty easy to use. Open your System Preferences via your dock and then open the network connections icon. Then open your airport control. Look for the check box to put Airport control in the menu bar. After that, you can simply open the screen of your macbook and the antenna bars will show you available signal and if you click on the antenna icon (top right corner of screen), you can select the name of the available network... Pretty cool and you already own it!
Dec 15, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook 13.3" won't log in to wireless
is it a airport used or a router? if so, have you tried to reset it?
Feb 18, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Reply: What wireless card does your macbook have?
AirPort Card Information:
Wireless Card Type: AirPort Extreme (0x168C, 0x86)
Wireless Card Locale: USA
Wireless Card Firmware Version: 1.4.8.0
this info can be found in apple/about this mac/more info/system profile/airport card
Jan 23, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
New Apple Airport Express Base station blinking amber light
Using the Airport utility on your macbook (located in your Utilities folder) will tell you what the conflict is.....most likely you have DHCP issue or the network is at the incorrect setting.
The wizard in the utility will tell you what you should fix.
Jan 05, 2009 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Macbook Airport Problems
You should check to see if you have the connection set to static or to scan. Your computer could be set to scan, and so when it recieves a stronger signal, even if it is for a second, it will disconnect from the signal you have current. You can go to system preferences , select NETWORK, go to show, then AIRPORT, make sure your signal of choice is at the top of the list.
Aug 24, 2008 | Apple MacBook Mac Notebook
Wireless and multi function printers
I'm sorry to say that the answer to your question is no.  You can print wirelessly with most printers using either an Airport Extreme Base station or an Airport Express, but for scanning, you will need to be physically connected to the scanner.
If you wanted to, you might be able to set up that old desktop to be permanently (and physically) connected to the scanner, and then you could either connect to that PC over your home network to access the scanned files, or you could potentially email them to yourself from the PC.  That might be your best bet.
Hope this helps!
Oct 06, 2007 | Apple MacBook Pro Laptop Computer with...
Zyxel P660HW-D1 Router Logo
218 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
