Hello!
I am using a DOS word processor under WinXP home and it works excellent.
The problem lays in printing the files out. All new printers are
"windows only" printer and run with USB port. (DOS programs use serial
or parallel port)
It would be nice to have an Epson-printer-code-converter that converts
from ESC/P2 to the windows printing system.
The printing problem should be pretty big, because it still gives
thousands of DOS word processor users. The ESC/P2 was under DOS a
widespread printercode that every of the old programs would have a
printer driver for.
Anybody knows of such a converter? Or does anybody knows a different
solution to the printing problem?
Thanks for your help!
Helmut
Rating: 0%, 0 votes
and #
Kind regards,
Davide Guolo
aSwIt s.r.l.
Printfil - Windows Printing System for Applications
Odbc4All - Connection to ODBC Data Sources for any Application
@Kill - Batch Close Windows Applications - Freeware
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
My word processor is LocoScript PC V. 2.52
You are right, I found by Epson laser printer with par. Port and ESC/P2
emulator. But all of the inkjet printer are GDI printer without emulator.
Thanks!
Rating: 0%, 0 votes
Which?
You're wrong. There are still printers (mostly laser printers) with
parallel port, but these are more expensive.
Robert Riebisch
Bitte NUR in der Newsgroup antworten!
Please reply to the Newsgroup ONLY!
Rating: 0%, 0 votes
yes I know...
that's why I suggested *saving* the file.
then from Windows open the file and select "print"
Wordpad should probably do the trick
Rating: 0%, 0 votes
Would be to nice, but doesn't work. "Only-Windows-printers" will ignore
DOS-Commands and Printing codes like the Epson ESC/P2. The file is a
file of a DOS programm, not windows.
Helmut
Post a New problem for Olivetti JP 192 InkJet Printer
Email this problem
