Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
TOP RACK DOESN'T RINSE
Hi. There is always soap residue left on the top rack of glasses, dishes, etc. It doesn't seem to get clean and rinse. The bottom rack is perfect and shiny. HELP!!!!!!! GE Profile Owner
  • 837 Answers
I would suggest you buy some CLR and run it through a full heavy cycle with the washer empty. Be sure to put it in all dispenser areas and sprinkle about 1/4 cup into the washer before starting.
Posted on Feb 16, 2009
I have a KitchenAid Dishwasher Model KUDT03FTSS0. I am having a problem with the glasses on the top rack not being fully cleaned. There seems to be an amount of residue left on the glasses. I have...
Check that the arms spin freely when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
Jun 25, 2011 | KitchenAid Dishwashers
Top wond (rack) doesn't clean. Dishes are very dirty at the end of the cycle. However, the bottom rack is fine......please respond asap if possible. Thanking you in advance. Connie
Connie,, make sure in loading the dishwasher you have room for the soap and water to make it to the top rack, (older models) on newer models you have a sprayer just under the rack make sure the sprayers are working fully,, to clean them you can use a hard brush and vinegar,, let stand for 5 minutes and rinse off, also, you can run vinegar ( white) through your machine,, to help clean the jets,, use in place of the soap , then run a couple of times empty to remove and let over odor
May 17, 2011 | Dishwashers
I have a hotpoint built in automatic dishwasher model HDA3740G02SA. When my dishwasher runs all the cups on the top shelf seem to have dishwashing soap powder left in the bottom of the cups. I do not...
make sure the arm on top isnt hitting something, each time you load it each in there and spin it to be sure it moves freely, also make sure your rinse agent container is full of rinse agent.
Oct 29, 2010 | Hotpoint 24 in. HDA3740G Built-in...
Food residue left behind on my dishes on the top rack. The addition of a rinse agent doesn't seem to help. Suggestions?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Oct 17, 2010 | GE Nautilus 24" Built-in Dishwasher
The dishwasher is not cleaning. It has left a residue all over the dishes especially colored plastic ware glasses. like it doesn't rinse but i have ran the extra rinse cycle and residue is still there. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
The items on the top rack never come out clean. there is always food residue left. it seems that the final rinse doesn't get to the glasses. we need to rinse them all out before the drying cycle starts...
heatman101
Jan 04, 2010 | Amana 24 in. ADB2500AW Built-in Dishwasher
After wash cycle and rinsed cycle there were suds
Make certain you do not use dish soap when rinsing the dishes. Make sure you only use DISHWASHER soap when running the DW.
In fact,there is no need to rinse dishes. Remove visible scraps and put them in the DW. If it is a quality DW it will clean your dishes. Do not crowd the dishes in the DW. Most JennAir DW's are quality. Make sure the top rack can get washing action from the bottom spray arm. No pots or other water stopping utensils on the bottom rack.
Oct 06, 2009 | Jenn-Air 24 in. JDB1080AWS Built-in...
GE Potscrubber 650 does not drain and top rack not washed
your not draining the washed dirty water out. its leaving crud on dishes. check drain pump and drain line for restrictions
Jun 22, 2009 | Dishwashers
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
389 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
