Question about Sabrent TV Tuner / Video Capture Box USB 2.0 with Remote Control (TVUSB20)
How can I record from VHS to Computer with Sabrent TV Tuner?
Hello - I can play the VHS and it shows up on the monitor but I don't hear anything and I can't figure out how I record it onto the hard drive. I press record on the Sabrent TV Tuner remote and the big red dot appears in the top left hand corner but once the tape is finished running, I can't find anything anywhere.
I appreciate any help.
Thank you.
Dena
Did you install the driver for the remote control?
In either case, the video will automatically start playing on your computer but not recording. You can just click on the record icon without using the remote.
It sets up a folder under your Documents. It should then show you the icon so you can name the file.
I am having the same issue with the sound though. Haven't yet solved it. Will post the solution if found
Posted on Mar 11, 2009
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
Can you record dvd from vhs on a go video DV2130
no its just dvd player you can not record.If still need record on dvd then first input in your computer via tv/tuner card as a audio and video in put.then play vhs and record dvd from computer.
Oct 17, 2010 | GoVideo Go Video DVD/VCR Combo
HOW I CAN USE M-15N MONITOR AS A TV?
Two choices: 1) get a tuner for your computer and watch the live or recorded show the monitor (Similar to watching a download from the networks or HULU.com)
2) get a set top tuner with an s-video out. Connect an S-video cable to a video cable signal adapter (Mini-dim 8-pin connector to S-VHS and CVBS jack) and connect that to the monitor. Then hook up speakers to the set top box.
I hope this helps.
Jun 24, 2010 | Neovo S 15V 15 in. Flat Panel LCD Monitor
Sabrent PCI TV Tuner card won't work on dual monitors
yes it is not possible vew to duel monitoring system it is only single devise
Jul 13, 2009 | Sabrent TV-PCIRC (TVPCIRC) Video Capture
No sound from my Sabrent TV Tuner / Video Capture
What he means, is that you should get a cable to connect your VHS player with the soundcard. Presumably your TV card doesn't have integral sound. Look at the connections. Your VHS player probably takes phono cable, while your soundcard probably takes mini-jack. So a cable that has a single stereo mini-jack in one end and two (red and white or occasionally black) phone connections in the other end. Those are easy to come by if you go to an electronics store.
Jun 25, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
MONITOR
You will need a TV Tuner expansion card for your computer. If you buy a TV Tuner expansion card and install it, and connect an antenna or cable TV cable, you will be able to watch TV shows on your computer monitor while using your computer. With some TV tuner cards, you can also record TV for watching it later, or even hook up your VCR and record VHS tapes and home videos to put on DVD. This is a more complicated topic and instructions should come with the TV Tuner expansion card you purchase.
TV tuner cards usually run in the range of $20-75 and will fit in most computers. You can buy them online and at computer or electronics stores. Installation is fairly simple and the instructions and software are included (unless you buy a used one)
Jun 10, 2008 | Sharp LL173C 17" Flat Panel LCD Monitor
Sabrent TV-USB20 USB 2.0 TV Tuner/Video Capture Box with Remote Control
Try check your your cable or try use 3rd party recorder software. If green screen was appear it means your recorder software didn't receive signal.
Best regards
May 25, 2008 | Sabrent TV Tuner / Video Capture Box USB...
Recording from one vhs recorder to another.
If your plan is to copy a VHS movie to a blank VHS tape, the connections would require a 3 wire RCA connector/cable. The unit where the original movie will be played will be the player. Connect the yellow video RCA cable to the VIDEO OUT, the red & white to the AUDIO L/R OUT. On the 2nd unit designated as recorder, slip in the blank VHS tape. Connect the other end of the RCA 3 wire cable to yellow VIDEO IN, the red & white to the AUDIO L/R IN. Connect the RF OUT of the 2nd unit (recorder to the ANT IN of a TV set. Set the TV to either Channel 3 or 4 as the case may be.
If the recorder has a manual selector or via remote, pls verify that it is set to Video and not tuner (or channels) input.
Press Record on the recorder (2nd unit), press play on the 1st unit (player). The TV will serve as monitor to your copying progress.
Hope that this be of some help/idea. Pls post back how things turned out or shoould you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Televison & Video
Sabrent TV Tuner / Video Capture Box USB 2.0 with Remote Control (TVUSB20) Logo
203 people viewed this question
Top Sabrent Televison & Video Experts
Brian Sullivan
Brian Sullivan
Barbat Nae
Barbat Nae
Are you a Sabrent Televison and Video Expert? Answer questions, earn points and help others
