Question about HP LaserJet 3330MFP All-In-One Printer
Scanner says waiting for pc
When I push the scanner button it says waiting for pc, everything else works copier and printer
  • Anonymous Mar 05, 2009
    same thing here, change the usb cable, reset the printer configuration, uninstall and reinstal driver. the problem still persists. need help on this please
SOURCE: HP All-in-one will not scan
Had the exact same problem - All-in-one would not scan with the same error message. Found the solution. Go to my computer (in XP) -> Control Panel -> Printers and Other Hardware -> View Installed Printers. Look at the bottom left in the side column of the window, you'll see "Scanners and Cameras". Click that option and it will walk you through the process. It works perfectly! Good luck!!
Posted on Aug 20, 2007
SOURCE: Hi i pushed the scanner
Hi it was very easy afterall. I just unplugged the unit and plugged her in after 15 seconds.
Bingo...It re configured itself and i'm printing again.
Posted on Feb 04, 2009
SOURCE: i have a hp deskjet 380 printer three in one
Dear Sir,
I want to install a hp deskjet printer (F380 All-in-one) on my lap top, but I don't have the CD anymore.
Please help me.
Thanks....Deng Wan (Msia)
Posted on Mar 25, 2009
SOURCE: Scanner does not work message Waiting for PC
my hp laserjet 3050 prints but i need the driver to scan a document.
Posted on Apr 27, 2009
SOURCE: scanning
Same thing happened with me. I just went to hp's website and downloaded the new driversdrivers.
My scanner works perfectly fine now. (i have c3180 and macosx)
Posted on Apr 03, 2010
My cannon scanner MP240 is getting an error E5 please help to find out the solution
Error ink cartridges are not installed properly (Error E5)
First power off the printer. Next, while holding STOP/RESET button, power on the printer.
While holding POWER button, release STOP/RESET button. Then push STOP/RESET button twice.
Wait about 20-30 second until the LED shows "0?. Then push STOP/RESET button four times.
Finally push POWER button twice. Last step is to turn off the printer by pressing the POWER button one last time.
Jul 07, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Push scanner button slected computer to scann from and then it cannot access application list
Check Spool for waiting command ..Reset Printer... unplug printer and restard PC with out printer ..then plug printer to PC then start printer...If not Re-Install Printer Software and drivers then re-start PC then check for application ...
Sep 30, 2010 | Lexmark X5470 All-In-One InkJet Printer
Ink light of my tx101 keeps blinking
Hello, Amit.
From FixYa, give this a try:
Lift up the scanner bed (top part) of the printer to expose the cartridges.
Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
Hope this helps.
Oct 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I can't manage to scan directly from the scanner
Have you installed full software from the CD that came with the printer?
if not do that first, do you mean that you cant push printer button and automatic scan to computer?
Jul 02, 2009 | HP OfficeJet J4580 All-In-One Laser...
Scanner will not scan
If it worked before try pulling all the plugs in the back and waiting at least one minute then replugging!
Have you installed any new software lately?
Feb 11, 2009 | HP PSC 500 All-In-One Printer
Canon Pixma MP160
there is a problem with your scanner, neither scanner is working there is a problem in scanner cable and also there is a problem in copy button or panel problem one of them has to be replaced and to be checked
Apr 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
How to change the ink cartridge?
1: Turn printer on
2: Lift up front panal (below scanner)
3: Wait for print head to appear
4: Remove old cartridge (push down & towards you)
5: Push new cartridge into position
6: Close panal & wait for the Printer to prime the cartridge.
If you are using a PC with check it works in the printer section of Control Panal
Mar 31, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP officejet D135 scanner and copyer
if the scanner bulb is not moving, then its an hardware problem.
We can try by resetting the printer.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK/ENTER and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Please let me know after resetting.
Thank U!!
Feb 10, 2008 | HP OfficeJet D135 All-In-One InkJet...
Hp 3380 scanner issue
Feb 02, 2008 | HP LaserJet 3380 All-In-One Printer
You can also attempt to reset the AIO:
For the Mac (possibly):
Jan 23, 2008 | HP DeskJet F380 All-In-One Printer
HP LaserJet 3330MFP All-In-One Printer Logo
770 people viewed this question
Ben Johnson
