Garden Logo
Javier Delgado Posted on Feb 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cub cadet 22 hp zeroturn wont start after storing for winter. Replaced battery, it looks like its not getting enough power to start. It will not turnover all the way.
Kelly Buxton
Level 2:
Sergeant:
  • Expert 322 Answers
  • Posted on Feb 22, 2013
Kelly Buxton
Expert
Level 2:
Sergeant:
Answers
322
Questions
Helped
137273
Points
509
Charge and test the battery. the battery may be no good after sitting all winter and may need to be replaced.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
5 Related Answers
Anonymous
  • 86 Answers
  • Posted on Apr 10, 2010
SOURCE: Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Anonymous
  • 109 Answers
  • Posted on Apr 16, 2009
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Anonymous
  • 162 Answers
  • Posted on Jul 30, 2009
SOURCE: cub cadet 2135 wont start
check for a fuse behind the ignition
it might be blown
then i would check the starter solenoid
if you put a screwdriver accross the bolts that hold the wire from the starter and ignition switch and it tries to start there's ur problem.
Testimonial: "So after borrowing the neighbor's tractor for a month, I finally checked the fuse and YOU WERE ABSOLUTELY RIGHT!!!! Blown fuse! You're BRILLIANT! Tnx!"
Anonymous
  • 4 Answers
  • Posted on Jul 02, 2010
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Anonymous
  • 3 Answers
  • Posted on Jul 13, 2010
SOURCE: my cub cadet stops running 5-10 minuts
check the bowl for dirt or try putting in some stable
5answers
Cub cadet LTX 1045 Has no electrical power
Hi Charles.
this is all i can find on the net.
Start at the red (+) battery post and follow the battery cable to the starter solenoid. On the same top post of the solenoid where the battery is hooked there is another smaller red wire. Follow this small red wire and it will lead you directly to the fuse.
A Cub Cadet lawn mower won't turn over when it isn't getting power to the starter motor to spin the engine. This can be due to a bad battery; loose or corroded wiring; corroded terminals; bad ignition key switch; faulty safety switch; blown fuse; bad starter solenoid; or faulty starter motor.
7 Reasons Your Cub Cadet Lawn Mower Won't Turn Over or Crank You have finally found time in your busy schedule to mow your lawn. You're happy to be able to get it done and out of the way. However, this time your mower won't turn over. I have put together a list of items to check when you run into this problem.
Make sure you are following all safety precautions as shown in your owner's manual. If you are uncomfortable working on your Cub Cadet's starting system, contact your local Cub Cadet dealer or a knowledgable mechanic.
Dead or Bad Battery in Your Cub Cadet
A dead battery won't provide the power you need to turn over your Cub Cadet. Keep your battery charged, especially during storage, to extend your battery's life. Test your battery using the steps in the article "5 Things That Are Draining the Life of Your Lawn Mower Battery".
Charging a Battery: Use a battery charger to charge your 12-volt battery. Before you continue, wear protective gear to protect your eyes and skin from electrical shock. Follow these steps to charge your lawn mower battery with a charger:
  • Access the battery and terminals. You may need to use a screwdriver to uncover the battery. Do not remove the battery from the casing.
  • Connect the charging cables beginning with the positive cable first. This is the red cable or the one with the plus sign. Place the cable on the positive battery terminal.
  • Attach the negative cable to the negative battery terminal. This is the black cable or the one with the negative sign.
  • Do not touch anything that doesn't have a rubber coating to prevent electrocution.
  • Set the charger's voltage and amperage level to the desired level. The average volt level for lawn mower batteries is usually 12 volts. More amperage charges the battery faster. Start with two camps and work up to no more than 10 amps. A slow charge is best.
If the battery fails to hold a charge it must be replaced with a new battery. You can purchase a new battery at your location lawn mower dealership, hardware store or automotive store. Bring your old battery with you. Most places will charge you a core fee unless you provide them with your old battery.
Loose or Wires and Connections in Your Cub Cadet
Wires and connections can become loose with the constant vibration of your Cub Cadet. Make sure they are secure. While checking the connections and verifying the continuity is good, make sure the terminals are free of corrosion.
The outdoor elements can cause moisture around the connections causing corrosions. Try to remove this corrosion using a wire brush and a baking sold solution (2 cups water to 3 heaping tablespoons of baking soda). Replace the terminals if the corrosion is too severe.
Bad Fuse on Your Cub Cadet Lawn Mower
A fuse is installed to protect your Cub Cadet's electrical system. Check your mower to make sure you don't have a blown fuse. If you're unsure if the fuse is blown, you can check it by placing a multimeter probe on each prong of the fuse to measure resistance.
A resistance reading near 0 means your fuse is good. An infinity resistance reading indicates a bad fuse.
Replace a blown fuse with a fuse with the same amperage of the fuse you are replacing. If you continue to blow fuses, you should bring your Cub Cadet to your lawn mower dealership or lawn mower repair shop to troubleshoot the root cause.
Bad Ignition Switch on Your Cub Cadet Lawn Mower
The ignition key switch can be the culprit if you insert the key and turn it to find nothing happens. Your Cub Cadet will fail to turn over and start.
Check the switch using a multimeter to check continuity to determine if the ignition switch is the problem. To do this, look for the prongs mark B for Battery and S for Starter Solenoid.
Insert the key and turn it to the start position. With the multimeter set to measure resistance, touch one probe to the B prong and the other probe to the S prong.
A good ignition key switch will measure resistance near 0 ohms. A bad ignition key switch will measure infinite resistance and will need to be replaced.
Bad Safety Switch on Your Cub Cadet Lawn Mower
Your Cub Cadet has an operator presence control system installed to keep you safe. A safety switch can be defective and cause your Cub Cadet to fail to turn over.
Test your switch using a multimeter. You can also temporarily bypass the safety switch to identify a bad switch, but only do this for troubleshooting purposes.
Never operate a mower without the safety switch. Never run a mower when a safety switch is bypassed. A safety switch can save you from serious injury and you never know when you're going to need it.
Bad Starter Solenoid in Your Cub Cadet Lawn Mower
A starter solenoid is an electromagnetic switch that, when engaged, initiates the starter motor to turn over your Cub Cadet's engine.
The starter solenoid can go bad when the spring becomes weak or the copper plate begins to corrode. A weak starter, bad battery or bad ground can also cause the solenoid to fail.
Before you test your starter solenoid, you must have a fully charged battery. Continue testing the solenoid by using the steps to diagnose a bad starter solenoid in "How to Tell Your Lawn Mower Solenoid is Bad".
Bad Starter Motor on Your Cub Cadet Lawn Mower
Once you have ruled out the battery, cables, wiring, ground and starter solenoid as being the reason for your Cub Cadet won't turn over, it's time to look at the starter. The starter can be removed and tested.
I recommend having your local repair shop that specializes in starter and alternator repairs test your starter and rebuild it if possible before just throwing a pricey new starter at your Cub Cadet mower.
Still Having Problems with Your Cub Cadet Mower? If the above list did not resolve your problems, I put together a guide of common mower problems and solutions. You will find links to more in depth articles for each of these common issues. You can find the article at "Common Cub Cadet Lawn Mower Problems".
If none of this helps you out i dont know what you are going to do.
Cub cadet gtx 1054 cutting grass and the tractor stop running. Will not start
check wires and connectors--check the inline fuse --seat switch -battery look over the wiring possible wire damaged or disconnected
I got a 50in cub cadet ZT came with a Briggs on it . I'm putting a 22 hp Kohler command motor on it. I need the specs for all the wiring from the Kolher command motor to the Cub Cadet
Look at the wiring color codes and their purpose in the Briggs manual, Compare to the wiring color codes and purpose for the Kohler engine in manual, connect accordingly.
My cub cadet lt1050 lawn tractor mower starts when cold fine, but wont even turn over when hot.
you have bad valves it needs a valve job this is because the hatter it get it looses power and will shut down when to hot
1helpful
I have a 2007 model 2544 cub cadet with a 22 hp kohler was working fine,now it is acting up,starts fine but will quit after using it for about 15 to 20 minutes,she will start right up but will quit again...
2007 is old enough that over years the carburetor needs to be cleaned. trash and debris will collect in the carb causing it to do as you are saying. be sure the fuel lines are off the engine. you tube videos can show you how to clean a carb.
I have a z force s cub cadet. The battery is good. Tested and passed. the engine/started must work hard to turn over, but still won't catch. I will jump the tractor and it will start and run.
You may want to try to find a battery with a stronger amperage rating. Even if the battery passes if it is borderline for starting it new it may not be strong enough even if it's still okay for it's battery type.
Other causes:
A worn starter can cause this issue. If a few of the coils shorted the starter will work but require much more current to do the job
A bad relay/solenoid to the starter that doesn't allow enough current to go through can cause this.
Valves out of adjustment... especially on some Briggs and Stratton engines, it's a known issue that if the valves need adjustment the motor can require a lot of energy to turn over and can cause constant hard starts.
I have a cub cadet 2146 riding mower. I've changed the battery and replaced the fuses, still no power. What else could the problem be?
check the battery connections and also the earth cable if no luck their then check the fuses with a test light or similar and look for a feed to the fuses as the connections at the back of the fuses could be corroded
Cub Cadet 1641 won't start....
sounds like the battery doesn't have enough power to crank the engine
Top Garden Experts
Jay Finke
Jay Finke
john h
