Question about Microsoft Windows XP Professional
CD BOOT: MEMORY OVERFLOW ERROR
I am trying to re install xp on to a pc it runs through the main setup section and then says system needs to reboot and will continue with process afterwards. I have been told i will need to go into BIOS again and change it back to boot from the HDD, i have done this once the system restarts it says CD BOOT: MEMORY OVERFLOW ERROR
What does this mean and how do i resolve it?
  • Ray Lang Feb 16, 2009
    sorry for my ignorance but what is cmos?
  • 61 Answers
Did you overclock you cmos? go to cmos again and load factory default. and try to install xp again.
Posted on Feb 16, 2009
  • morey dumo
    morey dumo Feb 16, 2009
    cmos set up is the same as bios setup. try to load it on factory default settings.and do the xp installation again.
When i switch my computer on, windows profession window appears and say press ctrl+alt_delete to begin, I do that but nothing happens. My laptop i'm using is a Dell Latitude D630
Step 1 - Remove non bootable media
Remove any floppy disks, CD's or USB sticks from your computer and restart.
If NTLDR is missing error appears again, Do the Next Step.
Ensure you boot the system from the CD. The system will then boot into the Windows XP Setup.
At the welcome screen press 'R' to enter the Recovery Console
At the recovery console, select your Windows XP installation and enter your Administrator password if requested
At the command prompt issue the following commands and press ENTER after each command:
fixboot
fixmbr
Remove your Windows XP CD and restart the computer
If the NTLDR is missing error appears again after reboot, Try the Next Step.
It is sometimes necessary to run or re-run the Windows XP Setup repair process
If it did not solve your issue re-insert your Windows XP CD and run Windows Setup again
Good Luck!!!!
Sep 20, 2011 | Computers & Internet
Tip
Windows XP failed to start because of a recent hardware or software change?
You have corrupt or deleted windows files or possibly a hardware error. The first thing is to try a repair using a Windows XP CD that came with your system.
XP REPAIR INSTALL
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below. This portion of the Setup program prepares Microsoft Windows XP to run on your computer: To setup Windows XP now, press ENTER.
  • To repair a Windows XP installation using Recovery Console, press R.
  • To quit Setup without installing Windows XP, press F3.
3. Press Enter to start the Windows Setup: do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you do not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair.
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
7. You will need to apply Windows updates after this procedure.
Not a trivial task but it will work. I do this for fun & feedback so 4 thumbs would be nice.
Jim
on Sep 21, 2010 | Computers & Internet
Boots up but goes to the xp screen and then shuts down and restarts. what do i do?
You will need your XP CD to run a Repair install.
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will need to press enter to setup Windows XP.
3. To setup Windows XP now and Repair Install, press ENTER. DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R".
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read the fix at the end of this post.
If you don't have an option to repair, try this:
1. Boot with XP CD.
2. Press R to load the Recovery Console.
3. Login to the Recovery Console using your Admin password if needed.
4. Type bootcfg
5. This should fix any boot.ini errors causing setup not to see the XP installation.
6. Try the repair install again.
If the Repair is still not an option, try the following:
1. Boot with XP CD.
4. If the CD letter is K: give these commands
* copy K:\i386\ntldr C:\
* copy K:\i386\ntdetect.com C:\
While still in the Recovery Console, try this as well:
1. Type: attrib -h -r -s C:\boot.ini del C:\boot.ini
2. Type: BootCfg /Rebuild
3. Now Restart and try the Repair Install again.
Feb 23, 2011 | Gateway 704GE PC Desktop
Blue Screen c000021a
Next step is remove hard drive and see if it is recognized in another computer. The Hard Drive could just be bad, but you need to rule out the motherboard drive controllers that could also be bad. Also try a known good drive in your system.
Char S.
May 27, 2009 | Dell Vostro 1510 Laptop Computer PC...
Error 7 xp reboot
That's strange because that is how you install xp, from the operating system disk, maybe it is a bad disk, let me look up those errors, http://forums.techguy.org/hardware/620187-solved-cannot-boot-cd-code.html
check this out it's the same as you describe
Dec 21, 2008 | Dell Dimension 8400 PC Desktop
Os keep restarting. on boothing the laptop, the windows starts and the user interface loads. when ask for username and password, on entering the username and password, the laptop restarts.
From my point of view I think the Operating system needs to be Repaired and below is a guide on how to repair
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
  3. Press ENTER to start the Windows Setup. DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R", (you DO NOT want to load Recovery Console). I repeat, DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R".
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read WARNINNG #2
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact. After the installation is over the system will reboot.
Enjoy
If This Solution has Worked Please RATE ME!!!!!!!!!!!!!!!!!!!!
Oct 22, 2008 | HP Compaq Presario 2200 Notebook
My laptop is not switching on
  3. Press Enter to start the Windows Setup. note.gifTo Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" border="0" height="21" width="15" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read Warning#2!
Oct 22, 2008 | Toshiba Computers & Internet
Will not boot to XP
these are some following procedure
do it carefully
XP Repair install Please read carefully and make sure you followed the warning links before initiating the Repair Install. You can print a text version for reference. repair.txt
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" border="0" width="15" height="21" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact. If you get files not found during the copying stage.
    Blaster worm warning: Do not immediately activate over the internet when asked, enable the XP firewall before connecting to the internet. You can activate after the firewall is enabled. Control Panel - Network Connections. Right click the connection you use, Properties and there is a check box on the Advanced page.
    KB 833330u Blaster removal
    What You Should Know About the Sasser Worm and Its Variants
    Microsoft Security Bulletin MS04-011
  7. Reapply updates or service packs applied since initial Windows XP installation. Please note that a Repair Install using an Original pre service pack 1 or 2 XP CD used as the install media will remove SP1/SP2 respectively and service packs plus updates issued after the service packs will need to be reapplied.
Oct 13, 2008 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional Logo
2,451 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
