Question about Electrolux EL5020 Vacuum
Electrolux EL5020A VacuumCleaner - taking apart
We were given one of these vacuum cleaners and it
stoppen working completely. I suspect the electrical
cord and want to take it apart. There seem to be some
things holding it together besides all of the star head
screws that I've taken out. Is there a repair manual for them?
Thank you for any help you can provide.
    Problem Solver:
There are more star screws than you think. Under the cover over both wheels there are two on one side and one at the rear of the other. Getting the covers over the wheels off is a task. They are only snapped in but getting them out is a fluster. Also under the brush assembly are several screws. This thing is secured better than a tank. Good luck..Took me an hour to figure out where all the screws were located...
Posted on Jun 19, 2010
  • 1,075 Answers
These[ things] you talk about are called lock clips.with a little force and a small screwdriver they open be careful not to snap them, take your time as you move along; the lock clips will start to reveal themselves more openly again take your time ,after the casing is opened it should reveal the electrical cord.;before you start this procedure make sure the electrical cord is unpluged from the power supply hope this helps you.adrian
Posted on Feb 16, 2009
Electrolux el7020a brush motor wont run
take the cleaner apart and make sure that the wires are all hooked to the on and off switch that got to the beater bar that is the main part of the problem improper wireing
Mar 22, 2014 | Electrolux EL7020A Oxygen 3 Ultra Canister...
HOW TO TAKE APART THE electrolux el8502 vACUUM
go to the next web and proceed according:
God bless you
May 09, 2012 | Electrolux EL8502 Versatility Bagless...
Electrolux EL7020 SHUTS OFF Constantly!
That problem have 2 causes..#1 is loose electrical connection inside or on the power cord..#2 is worn out carbon brush inside of vacuum motor..
Carbon brush is the one of the most serviceable parts of a vacuum cleaner because our vacuum cleaner motor is very hard working parts so the brush inside will possible worn or not connected to the armature of rotor...
Jan 12, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Took apart my electrolux 6500 sr. How do I get my fan shroud off to clean the blades? Thank you.
Oops. Don't. First blow it out with another canister vacuum or air hose. That's usually sufficient for removing dirt and dust. For dust/dirt in the motor, use a motor cleaning spray that can be picked up at most auto parts stores. One that evaporates quickly and doesn't leave a sticky residue. One's called Electric Motor Contact Cleaner by Gunk ( There are others.
Hobby shops may also have one available called Dynamite Magnum Force 2 Motor Spray.
It shouldn't be that dirty unless someone has been using generic "made to fit" Electrolux bags. Or if water or other liquid has been vacuumed, resulting in rust, etc.
Keep in mind that reassembling the vacuum is more difficult than taking it apart. If not done so correctly, various problems may result. While you have it apart, it would probably be a good idea to use pipe cleaners to clean out the tubes connectiong the "control valve assembly" to other parts of the vacuum. Also, unscrew the knob at the top of the "cva" to check for wear and breaks. Clean dust thoroughly from all interior parts.
Oct 05, 2010 | Electrolux Epic 6500 Vacuum
I have an Electrolux Oxygen 3 Ultra Canister Model No Rel7020. I am having problems with the On/Off Button and the Bare floor/Carpet Brushroll On/off button. The Carpet On/Off will not work at all. In...
You have a problem with the electrical switches. If you are comfortable with this, take apart and double check internal wiring to make sure nothing was frayed, or disconnected. Make sure it is unplugged. If you know how to operate a multimeter, you can use it to check continuity in each switch.
Jan 27, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Brushroll in electrolux oxygen+ deluxe
Is the brush roll not working at all? Check the teeth at the sides of the brush roll by opening up the electric head. If it has completely been destroyed you may have to buy another new head for it. Separate brush rolls are difficult to obtain and work out more expensive sometimes than the electric heads themselves.
You may have to contact the Electrolux cust services in your own country. Check by
Jul 24, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux 2100
Call your local Aerus Electrolux office. If there is a problem in the electrical system you should get that checked before you continue with the machine. As for the cord replacement- Any Aerus service dept. can do that for you. I say an Aerus office because should you let a non-Electrolux employee work on it you will void your warranty.
Dec 08, 2007 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux canister vacuum
The easiest solution would be to call your local Aerus/ Electrolux representative, because the corporation doesnt publish diagrams.
Sep 15, 2007 | Electrolux Lux 5500 Canister Vacuum
Electrolux EL5020 Vacuum Logo
581 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
