Question about Whirlpool RBS275PD Electric Single Oven
Display is in LOC but door is not locked. Can't set temp. to bake
After a power outage I tried to start oven. When I pushed Bake, the Loc display came on and the start light came on. When I push the temp. display arrow I get a shrill beeping. The bake, Broil, & Self Clean will not do anything; however, the door is not locked. My husband attempted to reset the clock while I was gone and we don't know if he did something there that locked. When I came home I was however able to set the clock successfully. We have no manuel for this oven, it came with the house and previous owner did not leave the appliance manuels. The Model # is F368LXQP, below that #, SERMG 531267, and something about 3 wire is printed on the Whirlpool sticker. Hope you can solve our problem.
  • sherih Feb 16, 2009
    We unplugged the electric stove and found a diagnostic pamphlet attached to the back. In reading it, they said the same thing you had suggested, but only to wait 30 seconds not minutes. It Worked!!! I am preheating and will be baking my peach lattice pie any minute now!
    THANK YOU
    Fix Ya Team
    (You're Great!)
    Sheri H.
  • 1,800 Answers
Check if u can find any reset procedure.
alsio u can let it with no power for 30mi that will reset it Int.Memory.
Posted on Feb 16, 2009
What does LOC mean where the temperature is supposed to be ?
LOC is normally the Control Lock Out feature to stop kids playing with it. This explains how to come out of it.
. Range LOC message on Display
Nov 13, 2016 | Ovens
I tried to press bake which turns the oven on usually and got LOC in white letters instead of a temperature
Perhaps indicating the oven door is locked.
Look for an unlock button.
my Fridgaire oven has a led to indicate door lock
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
MY OVEN WON'T HEAT
Hello - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failur
Oct 26, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven doesn't heat
Hi Sharon Knight - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
Sep 17, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Take GE Profile Oven LOC from pannel
the control board is bad,replace it there is no sequence to rectify this problem the board is bad
Jun 17, 2012 | GE Ovens
The loc on light comes on when i push any button on my stove i do not know how to get it off
The LOC light indicates the front panel lock is on. This keeps you from starting the oven when cleaning the panel; it also keeps children from turning on the oven. To disable the lock, press and hold Bake and Broil Hi/Lo together for 2+ seconds until SF appears on the display. Then press Self Clean. Then press Start to exit the Special Functions menu.
GE appliance manuals are available from their site. Go to http://www.geappliances.com/service_and_support/literature/ and enter the model number of the appliance. Then click Search.
I hope this helps.
Jun 26, 2011 | GE Profile JTP18 Electric Single Oven
The oven is stuck at LOC.
The locking motor has gone bad on the range. Common for this to happen after self clean. You will have to replace or have the lock assembly replaced for the stove to work again
Mar 06, 2010 | GE JKP45 Electric Double Oven
Touch pad does not work and flashed FO
FO- the touch pad is faulty. replace the eoc(electronic oven control)
May 17, 2009 | Kenmore Ovens
Kenmore Ultra Bake GAs oven
Here's a link: http://www3.sears.com/ put in your make and model and you can order a manual. Good luck!
Jul 19, 2008 | Ovens
Whirlpool RBS275PD Electric Single Oven Logo
331 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
