Question about HP DeskJet 3650 InkJet Printer
Paper Jam The papers are stack in the printer and i cannot remove it. I tried turning off the printer but it wont get off. The power button light just keep on blinking.
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Feb 16, 2009
4 Suggested Answers
EPIJAB
  • 89 Answers
SOURCE: paper jam
If you have pulled out paper that was stuck before you may have flipped a sensor flag out of position. I have found in the past small pieces of paper left under the plate at the very bottom of the toner catridges where the paper comes in.
Posted on Jan 04, 2008
  • 15 Answers
SOURCE: middle light blinking message says paper
Look for any small rips of paper caught in a sensor back there. There are little "fingers" that the paper runs over and its all timed. if one of those sensors are jammed with something or sticky, error messages.
Posted on Sep 22, 2009
Testimonial: "Excellant feedback! Great solution...Timely also. I highly recommend your site for anyone having a technical hardware or software issue!!"
professor_sc
  • 180 Answers
SOURCE: Removed paper jam but not able to turn off
unplug the power cord of the printer for 60 seconds and plug it back in
Posted on Oct 28, 2009
Alarm light
Paper Jam:
Clear the paper jam.
If the printer does not automatically resume printing, press the control panel button.
No Paper/ Misfeed:
  • The paper cassette may be out of paper or not properly installed.
    If it is empty, load a new stack of paper into the paper cassette.
    If there is paper in the paper cassette, make sure it is straight.
    If the paper is curled, straighten it before printing. Sometimes it is helpful to remove the paper, turn the stack over and put it back in the paper cassette.
  • Reduce the amount of paper in the paper cassette, and then try again.
  • Make sure you use paper that meets Brother's recommended paper specifications.
  • Re-install the paper properly, and then press the control panel button. The printer will start printing again.
May 06, 2013 | Canon PIXMA MP495 InkJet Printer
Says paper jam, but there is no paper jam
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 20, 2012 | Kodak ESP 5 Printer
Paper jam - I can see the jam, but don't know how to remove the paper.
Hello
Open the top cover of the printer.
If you can see the jammed paper, take one or more sheets of paper and pull them toward you.
While pulling the paper, press the RESUME button to turn the paper feed rollers.
If the paper needs to be fed in the opposite direction, release the RESUME button and then press it again.
If the paper is still jammed, turn the printer off or remove the power cord from the printer. Then turn the printer back on or plug the power cord in.
The printer will run through a reset cycle, which may clear the paper jam.
If the paper is still jammed or if several (8 to 10) sheets are jammed, take hold of a sheet in the middle of the stack using both hands.
With firm, even pressure, pull the sheet toward you.
Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
Make sure no scraps of paper are left in the printer.
Close the top cover of the printer.
Try printing again.
Apr 16, 2011 | HP PSC 750 All-In-One InkJet Printer
Wont print ready light and alarm light flashing
When the printer "Ready" and "Alarm" LEDs flash as shown, please check the following points:
1.Paper Jam: Clear the paper jam referring to "How do I clear paper jams?"
2.No Paper/ Misfeed:
-The paper cassette may be out of paper or not properly installed.
-If it is empty, load a new stack of paper into the paper cassette.
-If there is paper in the paper cassette, make sure it is straight.
-If the paper is curled, straighten it before printing. Sometimes it is helpful to remove the paper, turn the stack over and put it back in the paper cassette.
-Reduce the amount of paper in the paper cassette, and then try again.
-Make sure you use paper that meets Brother's recommended paper specifications.
-Reinstall the paper properly, and then press the control panel button. The printer will start printing again.
Dec 06, 2010 | Brother HL 1430 Laser Printer
A single sheet of paper has jamed, can not release it.
Clearing a paper jam
If the paper jams in the printer, follow the steps below to clear the jam:
Remove the paper stack from both paper trays.
Press the POWER button. Instead of turning off, the printer will try to eject the jammed sheet.
If the printer cannot eject the paper, unplug the power cord from the back of the printer.
NOTE: Do not press the POWER button again before unplugging the power cord.
Open the rear access door at the back of the printer. To do this, press the handle to the right and then pull out the door.
Remove the jammed paper. Make sure no small pieces or obstructions remain.
Reattach the rear access door and plug the power cord back into the printer.
The printer will turn on automatically and be ready for printing again.
Reload the paper in the IN tray.
Try printing again.
Nov 25, 2010 | HP LaserJet 1010 Printer
Paper jammed - how do I get it out?
  • Follow the below steps to clear the paper jam
  • To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
  • For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
  • Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
  • Try printing another document.
  • Nov 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    I have an epson stylus photo 1400, and i did somethign stupid and jammed some paper, and i would like to know how to remove it. i can see it, but i can't grab it, and i don't know if there's any way i can...
    Well first of all you can try to reset your printer -
    Turn off printer
    Press and hold 'stop' 'maintenance' and 'power'
    buttons for about 10 seconds.
    A message will appear on the screen.
    power off and back on for reset.
    Try the following steps to clear any jam -
    1. Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
    2. To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
    3. For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
    4. Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
    5. Try printing another document.
    Good Luck!!
    Thanks
    Oct 06, 2009 | Office Equipment & Supplies
    How can i remove the paper inside the printer
    For the paper jam issue turn around the printer and open the back door to pull the paper.
    and for the power issue unplug power cord from wall and from the printer side too,plug everything back and ready to work.
    Aug 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    HP deskjet F380 - 'status: paper jam'. There is no paper jam!
    Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
    Jul 21, 2009 | HP DeskJet F380 All-In-One Printer
    Using HP 1100d Office Inkjet printer. Can't get 'out of paper' light to turn off. I have added paper, pressed the reset button, but light stays on, and printer will not operate.
    Please read over the following information and follow step by step.
    Issue Either before or during a print job, the message ' Paper Jam ' appears on the product control panel display. The product does not output paper or complete the print job. Solution Follow these steps to resolve the issue. Step one: Remove any loose paper
    1. Remove any loose paper from the paper tray and output tray. CAUTION: Do not remove jammed paper at this stage.
    2. Press the Cancel/No button on the product control panel to clear the paper jam message.
    3. If the paper jam message cleared, try the print job again.
    • If these steps resolved the issue , there is no need to continue troubleshooting.
    • If the issue persists , continue to the next step.
    Step two: Clear the jam from the back of the printer
    1. Press the Power button (c01345237.gif ) to turn off the product.
    2. Unplug the power cord from the back of the product.
    3. Remove the rear access door: Turn the knob one-quarter turn to the left and pull the door away from the product. Figure 1: Remove the rear access door c01489996.gif
    4. Gently pull the paper out of the rollers. CAUTION: If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If any torn pieces of paper remain inside the device, then more paper jams are likely to occur.
    Step three: Clean the rollers While the rear door is removed from the product and the power cord is disconnected, clean the paper rollers.
    1. Wipe the paper rollers with a lint-free cloth that is lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. Figure 2: Clean the paper rollers c00246512.jpg
    2. Allow the rollers to dry completely.
    3. Replace the rear access door. Gently push the door toward the product, and then lock it in place by turning the knob one-quarter turn to the right or locked position.
    4. Reconnect the power cord to the back of the product.
    5. Press the Power button (c01345237.gif ) to turn on the product.
    Step four: Reload paper and test the printer Load a stack of plain white paper in the paper tray and try the print job again.
    1. Press the Cancel/No button on the product control panel to clear the paper jam message.
    2. Lift the output tray.
    3. Pull out the front paper guide on the paper tray and slide the side paper guide as far to the left as it will go. Figure 3: Slide out paper guides c01489992.gif 1 - Front paper guide 2 - Side paper guide
    4. Load a stack of plain white paper, print-side down into the paper tray. Make sure the paper stack is no higher than the top of the front paper guide.
    5. Adjust the side and front paper guides to fit snugly against the paper stack. Figure 4: Adjust the side and front paper guides c01489993.gif
    6. Lower the output tray.
    7. Disengage the photo tray: On the output tray, pull the slider (visible through the output tray) away from the product until it stops. Figure 5: Disengage the photo tray c01489994.gif
    8. Try the print job again.
    Step five: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product. Have a good day,
    Jun 18, 2009 | HP Inkjet 1100d Printer
    HP DeskJet 3650 InkJet Printer Logo
    177 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
