Question about Kenwood KDC-MP4028 CD Player
Mitone MP4 Player 4GB MITMP22 - software disck empty
Greetings!
I bought a Mitone MP4 Player 4GB MITMP22 and the mini CD which is supposed to contain the software (I assume) is blank. Any ideas on where I could obtain the software. Also I am on windows XP - is the software compatible?
  • Anonymous Apr 15, 2009
    J HAVE THE SAME PROBLEM!! DID YOU FIND A SOLUTION YET? IF YES COULD YOU NOTICE TO kandba@tin.it Thank you
  • Anonymous May 05, 2009
    can not read the files on mp4 and on sdcard too. the mesage is "no file!"
  • 3 Answers
MITONE MITMP22 4GB MEDIA PLAYER PLAYS RMVB FILES
TO CONVERT TO RMVB FILE USE WIN AVI (AVI TO RMVB)
ONCE YOU HAVE THE WIN AVI PROGRAMME THEN YOU WILL NEED THIS EXTENSION FILE (HelixSDK0715 win avi rm extention file) AND CHOOSE THE SIZE OF FILE TO SUIT YOUR SELF IN ADVANCED ONCE YOU HAVE SELECTED RM
Posted on Sep 22, 2010
I recently bought a Mitone Digital MP4 Player MITMP29, but the box did not contain the CD needed to install the software. Where do I get the necessary software?
It looks like this has come up 7 times with other people on FixYa...unfortunately I was unable to find the software either...sorry!
Jun 20, 2011 | Computers & Internet
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
I have just bought a new sansa clip. i have successfully uploaded music to the the player and i can hear it well. now when i try to access the player through the computer i cannot access the music and...
Hi, are you sure the computer is recognizing your player?...if not....
4. Power issue.
- Run the hotfix.
Hope it helped ..
Have a nice day..
Feb 19, 2011 | SanDisk Sansa Clip MP3 Player
Mitone Mitac100 S/No : Mitac 100 BK 00174, purchased at Frankfurt International Airport Taxfree zone on 19 november 2010 with 2 year worldwide guarantee. Connected to my Hi-Fi system but never...
hi there, i also bought my MiTone MP4 player from Frankfurt Airport, and definitely it was the worst product i have ever purchased, from the first day i was defected, it was blinking power ON/OFF as i touch it, i had to keep it fixed beside me to keep it working, after repairing it, i found out it is not charging the battery...
Dec 29, 2010 | Audio Players & Recorders
I have a tevion mp4 player and have downloaded music on it using a software called iMeash. I wanted to dowload videos too but everytime I did my mp4 player wouldn't accept it. SO i tried researching and i...
Every file (that contains video or sound etc) has something called file extension like mp3,mp4, mtv and avi etc. This MP player "Tevion MP4 player"needs to be in in MTV file format. If you have purchased it you will get a CD with it. and this CD contains the converter to convert the MP4 file format to mtv so you can run it. If you do not have the CD than you can download it from here.
http://www.fascin8.co.uk/support/8198.exe
I recommend that you watch the following video related with this product
http://www.fascin8.co.uk/f8/tevion/mp4/4gb-mp4-4701
Be confident and do not be hesitant, If you still have problems with tevion. Change your media player to VLC. Plays all sorts of video and sound files even mp4 and flv and above all its free.
Good Luck!
Aug 09, 2010 | Computers & Internet
I have mitone mitmp25 mp4 player When i connect it to pc, it shows 3 folders sls.dir playlist & mic.dir Where ould i copy mp4 files in thesefolders? I tried copying in every folder but the player...
Mitone MITMP25 plays only videos in MTV format, so you should use the software included to convert all videos into MTV format before you can play those. See page 21 in user manual :-)
Jul 02, 2009 | Yifang Digital Easy Mp3 EM01 MP3 Player
I need firmware
dgtdthfuit87rtrsxfgdx y98 to8 cydty 7 8 87685 8 87 hte65wytdfjyygloyieyrdh
Sep 07, 2008 | Computers & Internet
MP3
I bought a MITONE FLASH MP4 DIGITAL PLAYER. I am downloading files from internet sites in mp3 format but am not managing to listen to them on my Mitone though it seems to be playing them. maybe i dont know how to use it yet. any suggestions please?
Jul 29, 2008 | Sony Write-Once Recordable, 30 spindle...
MITONE MP3 player software files are formatted
If a player like this http://www.szimp3.com/product_show.asp?BigClassName=MP4&SmallClassName=MP2610 , there are several clones of the Chinese goods. Firmware on the Russian here (English supports) http://ftp.roverbook.com/RoverMedia/Aria_Q7  there two different versions of firmware for the assembly player (one can work with bugs)
Methodology firmware:
1. Disable USB cable, turn off player.
2. Holding down "M" connect the USB cable.
3. The menu select 3 - y para (other then USB disk), clicking the right analog stick.
4. The system will appear logical disk 2. First at 16 mb, second - remaining FLASH memory.
5. Copy invested in this archive 5 files on 16 - MB removable disk (all except reame.txt).
6. Turn off the player through the safe extraction devices.
Jan 08, 2008 | Yifang Digital Easy Mp3 EM02 MP3 Player
Kenwood KDC-MP4028 CD Player Logo
2,693 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
