SOURCE: Rear headphone jack is not working!
Go into the case and unplug the frount headphone jack to enable the rear, some motherboards are particular on this issue.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: To my HP Pavilion Media Center A1430N, I lost ALL video signal
Hi:
One quick thing to check is to see if your Video card is fully seated down in the motherboard? Sometimes they can pop up a bit, and you lose your output.
If that doesnt help, you could remove your memory, one stick at a time, to see if that helps. This could be the cause if you added memory from the old computer.
SOURCE: HP Media Center m7250n - How to hear audio steamefrom panel input
You need to unmute the line-in and adjust its level as necessary. Usually you can just double click on the speaker icon in the system tray and the Line In is by default muted and it is on the far right column (depending on your setup). If it is not displayed, click on Options and Properties and put a check mark by Line-in so that it will display.
SOURCE: My Packard Bell I-Media has a N1996 motherboard.
find a serial or parallel port to connect it
Testimonial: "I cannot get access to the I-Media computer until late July. How do I connect the black Firewire plug - that multicable from the front board - to a serial or parallel port?"
use your hdmi connection on your pc
Problem solved. The loose cable and the headphone problem were unrelated.The cable was for a removable hard drive that I could buy and slide in hte case from the front. The headphone problem was a bad jack on some new Bose headphones.
How do I mark this solved?
