Question about Sapphire RADEON™ HD 2600 Pro, Graphic Card
About TV-out.. its ok to use the tv-out to any Television seT?..
  • 77 Answers
It all depends on if you plan to use a HD TV or standard CRT TV.
HDTV's have either component connectors whuch are Red, Blue And Green or via HDMI
Standard TV's have a composite video or svhs connector, which is rather like a ps2 connector
Posted on Feb 16, 2009
HOW TO GET FULL SCREEN ON KONKA TV
Change the aspect settings to fit your TV:
  1. Press MENU on your remote control.
  2. Use the down arrow button to highlight Settings, press OK.
  3. Use the down arrow button to highlight Television, press OK.
  4. Select Screen Aspect ratio and high definition, press OK.
  5. Use the arrow buttons to select 4:3 standard definition, widescreen standard definition, 720p on high-definition screens, or 1080i on high-definition screens.
  6. Press OK.
Apr 24, 2017 | Miscellaneous
How do I connect a Phillips t v to the internet
Either with an Ethernet cable from your home internet router to the TV, or wirelessly. The 4200 series require an optional wireless dongle (PTA127) to enable wireless functionality.
You can use a 3rd party wireless or Ethernet over Power devices (Homeplugs) to bring an internet connection to the TV that can then be connected to the TV's Ethernet port.
Sep 09, 2014 | Televison & Video
My philips 32PF5531D/10 TV Wont Work
i have same problem.. please if you had found solution help me help me!!
Mar 14, 2012 | Televison & Video
How do i reset my toshiba tv 32bv500b so i can get back to initial auto install ?
Hello
Before switching on the television put your decoder and media recorder to Standby if they are connected
and ensure the aerial is connected to your television
Select APS from Menu.
When the APS feature is selected all channels and
settings will be lost, the television will return to factory
settings and then re-tune.
* Press MENU and using the Left or Right button
select Program Table tab
** The Program screen will appear on the screen.
Press the BLUE button to start APS
*** Press the Left or Right button to set the country
**** Press the BLUE button to cancel APS or the RED
or OK button to start.
You must allow the television to complete the
search
OK.
Jun 14, 2011 | Televison & Video
Hit the reset button on remote and now tv is not finding any input signal sources. I have checked the connections and everything is the same as before so tv will not do anything. Also not finding any...
hi,
when you press the reset button the tv has gone to factory setting. All the settings made by you have been erased when you rested the tv. you have to set all channels by auto tinning your tv. also you have to set picture setting according to your preference, because the tv is now in factory default setting.
ok
Feb 14, 2011 | Sanyo DP32746 32 in. LCD Television
TV no sound but pictures ok, changed channels ok
The mts/sap function on your television might be enabled. Locate the audio settings on your television and make sure you are set for either stereo or mono. You may have an audio or mts button on your remote. If not this should be in the menu.
The cable company may have made a recent change and the tv may need to be channel buffered or you may need to complete another channel scan.
Aug 18, 2010 | LG 37LH55 37 in. LCD TV
Television will not come on. Power light flashing red.
Hello Debbie ok the problem that your tv set is having is coming from the convergence board which is faulty and has to be replaced, you can find one at partstore.com or by contacting the manufactuer of the tv set they should have one in stock, change out the board and you should be seeing tv in no time thank you hope this helps.
Aug 27, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Don't store tv setting LCD40F86BD
im having the same problem, i have had this television for 16 months now. its not just happening when i turn it off but also when im changing the source
Jun 12, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Ps3 trouble
ok, i got it working... Ok...your problem is probably that when you're using it on the HDTV...you have the resolution set to an HD one (720p, 1080i, 1080P). A normal TV cannot display these. While it's connected to the HDTV,Before you connect it to your normal tv, you have to switch it back to 480i or 480p otherwise, your regular tv wont show a picture. So go to settings, display settings, and uncheck 720p, 1080i, 1080p. It will ask you if these are the settings you choose (and it's going to look funny on your HDTV) Accept the settings and turn it off. When you connect it to your Regular TV, you should now see a picture. Hope this helps!
Dec 13, 2007 | ViewSonic N2060w 20 in. LCD Television
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Sapphire RADEON™ HD 2600 Pro, Graphic Card Logo
Top Sapphire Computers & Internet Experts
John Hong
John Hong
Martin Clarke
Martin Clarke
dhnguyen
Are you a Sapphire Computer and Internet Expert? Answer questions, earn points and help others
