Question about Toshiba Televison & Video
Screen only displays 1/3
Hi i have a toshiba regza 32" 32c3031db lcd and the top 1/3 of the screen is working but the rest is blurred no picture is being displayed
the screen is not damaged and suggestions?
cheers
Gary
How do you get rid of side panels on the screen - I want to watch a DVD and for it to fill the whole screen but it doesn't! It's so frustrating.
Posted on Aug 27, 2009
Toshiba regza repair
It certainly appears to be a major component failure or the LCD/LED panel is failing, recommend a local engineer to inspect.
Dec 17, 2013 | Televison & Video
Half screen is blurred
if as it appears a LCD and problem is half screen is "blurred" the set uses two (or one large) boards and each drives the picture on half the screen---could be one bad, poor connection or worst case defect in screen unit (display panel) which would be fatal.
Aug 27, 2012 | Toshiba Regza 52XF550U 52 in. LCD HDTV
I have a Toshiba Regza 32lv 703G lcd tv. I switched it on and I have lost my colour. It only displays in black and white although the menu screen is till displaying in colour. Kindly advise. Thanks!
It is pretty much junk, sorry to say it but your picture tube went out and it is cheaper to buy a new t.v. My grandpa use to fix them for us for free but he passed:( If you call some where see how much they would charge for a picture tube, I bet it's expensive???
Jan 15, 2012 | Toshiba REGZA Televison & Video
Recently I purchased Toshiba REGZA 47 XL 700 E is LED. Is this TV LED ?
Yes and NO your tv is a LED. To be exact it is a LED Backlight LCD TV. An LED-backlight LCD television is an LCD TV that uses LED backlighting instead of the CCFLs used in traditional LCD televisions. It is not a true LED display but is called "LED TV" by some manufacturers.[1] The use of LED backlighting has a dramatic impact, resulting in a thinner panel, less power consumption and heat dissipation, and a brighter display with better contrast levels. You can go to http://www.regza-asia.com/pdf/LEDTV/XL700/47XL700SPEC.pdf and look at the complete specs for your tv
Mar 07, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Only top one tenth of screen works. the rest of it is grey.
Screen fault I'm afraid - seen this a fair bit, LCD screen expensive so hopefully you are covered by warranty. If you could find one the lvds pcb which is situated top center on the screen (the one with the drive lead plugged into) can be replaced if you are careful.
Feb 03, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba regza 32hl67 losing its' picture and motion is slow
I have a toshiba regza 32hl67 LCD tv which is only 2 1/2 years old. The picture on this unit just started to go the other day (screen darkens but images are still visible and the motion/movement is very slow). I contacted Toshiba and they just said to unplug the tv for 3 minutes to reset the tv. This doesnt work. I am VERY upset with Toshiba, after paying $800 for a tv that only lasted 2 1/2 years. If anyone has had similar issues and know how to fix it, please let me know. Thanks
Apr 26, 2010 | Televison & Video
My question concerns a Toshiba Regza model 52HL167 which displays a perfectly normal picture on the right half of the screen and a blurred and streaked image on the left half of the screen. The lcd...
This will most likely be down to your screen controller board, Take the back of the tv and look towards the top middle, You will see your screen cable go into a rectangular board this is sometimes covered by a metal plate, remove this and check Ebay or Google for a replacement, there will be a part number on the board
Hope this helps?
Mar 05, 2010 | Toshiba 52HL167 52 in. LCD HDTV
Toshiba Regza 42R530U Overheating?
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc. http://www.abctay.com/
Oct 16, 2017 | Televison & Video
I have a toshiba 32hl67u lcd tv
I had same thing happen recently on same model. Turned it on one night, light came on in screen, briefly saw info bar at top, then nothing. Cannot get picture, volume or menu. Each time I turn off and turn on the same thing.
Any solution to this appreciated.
Dec 20, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Poor picture quality on Toshiba Regza 32AV555DB LCD TV
i had the same problem! i just changed my scart leads to some quality gold ones, this made the picture a lot crisper . hope this helps :0)
Dec 14, 2008 | Toshiba REGZA 32WLG66 32 in. Television
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
