Question about Kenneth Cole KC1346 Watch for Men
Losing TIme and Stopping completely!
I have Model No KC1348 S301-07 and have the same issue with losing 10-15 mins daily and then completely stopping. Only have this watch for just over a year. Any ideas out there?
I think you may need to change the battery!
Posted on Feb 16, 2009
Watch losing time
sounds like there is dirt in the movement that is blocking the train and stopping the watch a service should sort it out
Apr 20, 2014 | Omega Watches
My Rolex Explorer (black face, hacking model) is suddenly losing time and briefly stopping. Something inside rattles when I shake the watch. Can you suggest a likely diagnosis and rough price to hav
It's a very small timing gear, will roughly cost about 60.00 to fix it, has to be taken down part of the way to be put back into place, very common for them to pop loose
Sep 27, 2017 | Rolex Watches
My WAF2110 will ocassionally lose about 20 mins for no reason,also does this watch have an internal battery.
Automatic watches are spring driven and therefore do not have a battery.
Automatic watches thrive on being used and if you do not wear them sufficiently, they will run down and stop (or perhaps they run slowly before stopping).
Your watch should run for 38 hours before stopping.
Mar 31, 2011 | Tag Heuer WAF2110.BA0806 Aquaracer...
I recently bought a Mossimo watch with the analog and digital faces and the analog runs like ****. It keeps stopping and losing minutes. Like won't go accurate for more than an hour. Worse if it's being...
Quite often the battery can be the cause. But note that on some ana/digi watches there will be two batteries. The battery for the analog is usually buried quite deep in the watch and may be best for an expert to replace this. That expert will be able to test the battery first. If the battery is still good then I would suspect that the movement is faulty and may need replacing (although sometimes a bit of de-greaser expertly administered can solve the issue). Good luck.
Sep 20, 2010 | Watches
Watch has started
We had the same issue. Replaced new batteries etc. Since it was an expensive Invicta watch and less than a year old we assumed it was perfect. However, you need to take it into a upper end service center and have it "serviced" they will oil, align, etc and it will probably solve your issues.
May 05, 2010 | Invicta Extreme II 9982 Wrist Watch
Gevril automatic watch (model AO11R5) can't hold charge
If you have had it for some time then it could be that it needs a clean.
I have seen manufacturers recommendations suggesting every two years for cleaning to maintain accuracy.
Feb 09, 2010 | Gevril First Generation Automatic Watch...
My wifes recently repaired Rolex loses about an
Is it an automatic self wind or wind up? An automatic watch has a weight that winds the main spring and if you wind it by the crown it will not stop. If its one that you wind by hand then the watch should be wound daily at the same time...like right before bed or when she wakes up. Wind gently until it stops. That costly repair should come with a warranty so if she consistently winds daily and still loses time you need to send it back!
If the watch is an automatic then she can gently hold the watch in her hand and rock it back and forth a good 20 times or so and that will give it a good winding! This is a common issue we see at our watch repair business. Some people do not move enough during the day to keep an automatic movement wound. If thats the case then there is nothing ong with the repair, just make sure it gets a good daily wind! :-)
Jan 10, 2010 | Rolex Watches
Looks like battery problem...
Take it to a local Jeweler or closes retail store and asked them to test your battery.  If its not that there could be a glitch in the watch itself.
May 26, 2009 | Watches
Luminox 3001 watch not keeping time
Because of the way they work, it's quite hard for quartz movements to run consistently slow - so if you find one getting behind, it's usually a sign that it's stopping intermittently. It would do no harm to check that the crown is properly pushed in after you've reset it, but my guess is that the watch will benefit from a new battery. A.
Apr 08, 2007 | Luminox Navy Seal Dive 3001 Wrist Watch
Kenneth Cole KC1346 Watch for Men Logo
297 people viewed this question
Top Kenneth Cole Watches Experts
Ansel Alberto
Ansel Alberto
Robby Otts
Robby Otts
Level 1 Expert
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
