Question about Xerox WorkCentre PE16 All-In-One Laser Printer
Motherboard problem In our machine there is problem when we on the machine some nusence sound comes which last for a long time until the machine is turn off. We had been informed the Xerox company in Pune (Aishwaraya Automation) Bund Garden Road in Pune. They had in reply told that the machine is having problem in motherboard which cannot be solved. Please guide us in this matter. Waiting for reply. Sharma
    President:
  • 2,072 Answers
Does the noise come from the right side? There is a cooling fan in that machine that makes a horrible noise.
It could also be a noise genereted from the board to the fax speaker,which could just be disconnected.
If it is on the right side let me know, I can tell you how to resolve that.
Posted on Feb 16, 2009
Coffe does not come out, it starts sounding that it will then it stops
If you remove the porta filter, will water come out when you turn on the pump? If so, your porta filter is clogged and soaking it in white venigar will unclog it. To keep it from clogging, after each use, put it back on the machine and run hot water thru it until the water runs clear. (Remove grounds first)
Does water come out the steam wand?
When was the last time you ran a cleaner thru it? The Saeco de scaler cleaner is designed specifically for your machine. Purchase from Amazon for about $10.00 and use every six months.
if it still won't work,melt me know.
Feb 28, 2015 | Saeco VIA Venezia
My e-machine t5010 wouldn't come on. Replaced power supply. Now when turned on, it will run for about 5 seconds, then shuts off. Will not come on again until unplugged and power is drained. Plug...
Sounds like you have motherboard damage. Visually check the motherboard capacitors ( they look similar to this http://www.kpcomponents.ca/images/35V-Capacitor.jpg) and see if any of them have a crust on them or are popping upward. If you do find any that are popping up or leaking, then you will need to either take the chance and replace them or replace the motherboard as a whole. If you do not find any bad capacitors then remove the memory from the unit and see if it will stay on and give you sounds for more than 5 seconds. If it does not then you have one of two things. The onboard video is damaged or cpu is bad.
Sep 19, 2011 | E-Machines eMachines Desktop PC
I am unable to hear sound after getting windows reinstalled. Can anyone help me?
you need to install sound driver
go to device manager
at device manager there are yellow mark (?) or (!)
insert your motherboard cd driver
and install sound driver
the other way is at device manager right click at yellow mark and chose update drive, then follow instruction until finish and the yellow mark at device manager disappear
try to play sound
i hope this helpful
thank you for using fixya
Feb 23, 2011 | ASUS P5RD2-VM Motherboard
My dell vostro 1500 laptop doesn't boot up the battery and ac power source is fine, what happens is that the only light or noise that comes form it is that the caps lock blue light indicator flashes for...
it sounds like your ac adapter has burned out and won't charge anymore. That's very common... that's why they are so cheap on ebay. Either that or your power plug on the motherboard is cracked or loose at the motherboard (2nd most common) and last bad motherboard (don't assume this unless last resort.)
Jan 12, 2011 | Dell Vostro 1500 Notebook
I push the power button and all the lights come on and it sounds like it is turning on but nothing comes onto the screen. Then the lights go off and then tries to come back on again. this repeats itself...
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately.
Sep 21, 2010 | HP Pavilion dv9000z Notebook
Dell 8400 is not starting
Check if the RAM is seated properly and clean too. Check your power supply(SMPS) for the 3 voltages it should generate. RAM will not need any replacement however your SMPS may require replacement...sodeep
May 12, 2009 | Dell Dimension 8400 PC Desktop
Asus A8N-VM CSM wont boot, no fans come on or anything, green light comes on the motherboard, is the CPU dead? tried different ram still the same. any help would be great!
CHECK ALL JUMPER ON THE BOARD AND MAKE SURE THE BOIS RESET JUMPER IS ON JUMPER 1-2, SOUND LIKE A POWER SUPPLY PROBLEM NOT ENOUGH WATT TO RUN THE SYSTEM
2ND OPTION, REMOVE ALL WIRE AND ADDTIONAL CARDS, MIN. MEMORY, LEAVING 1 STICK OF RAM, VEDOI CONNECTION , AND THE POWER TO THE BOARD, CONNECT ONE WIRE AT A TIME AND RESTARTING THE MACHINE EVERY TIME UNTIL YOU FIND THE PROBLEM.
CANDYMANGANDY
Feb 05, 2009 | ASUS A8N-VM CSM (00610839133826)...
Kenmore oasis he, ld flashing at 8min.
Sounds like a bad lid switch. Many times you can test these by using a small jumper wire to connect the two wires on the switch it's self.
Jul 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Seek Help
Sounds like the Power Supply may be going.
Dec 19, 2007 | Intel D845EPI (INTELKD845EPILPAK10)...
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
125 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
