Question about Kodak Dock Series 3 Laser Photo Printer
Camera dock can not charge camera battery
When i plug my camera into the printer dock to charge....the charge indicating lights would just be flashing continuously without stopping . I left the camera plugged in all night and when i woke up the camera batteries were not charged. Does anyone know what to do to fix this problem
  • billf948 Mar 06, 2009
    I have similar problem....No lights on dock...
    Camera turns on must be getting power thr..
  • 2,120 Answers
It sounds like defective batteries if the printer unit works otherwise,
Posted on Feb 16, 2009
When I plug the printer in, the center light and the right light start to flash. What does that mean?
If you are having Ascending steady green lights for the center and the right light it means that the battery is charging all you need to do is to leave the camera on the dock to continue charging or maintain charge.
You may click here if you want to see more information about the light status of your machine.
Should you have any more questions just please leave a comment.
Sep 09, 2010 | Kodak EasyShare Printer Dock Series 3
My kodak eastyshare z760 flashes red when on the battery charger but yet, the battery never shows fully charged.
I had the same problem. I needed to take the clear plastic insert off but then I had to put a rubber band around the dock and camera (more on the left of the camera and dock) to hold it evenly on there since the camera was leaning on the right and wasn't charging for me. Now it charges as soon as I put it on there with the rubber band with no blinking red light anymore! Hope this helps!
Jun 10, 2010 | Kodak EasyShare Z760 Digital Camera
Camera dock does'nt work
If the light indicating the charging status is off, remove the batteries from the camera and make sure that you are using the Kodak Ni-MH Rechargeable Battery Pack KAA2HR. THis is the only battery that will charge on the dock. If you are using the correct battery and it still does work, better to get a rapid charger instead.
Item # 1717610
Jun 22, 2009 | Kodak EasyShare DX4330 Digital Camera
Charge batteries while camera is docked
what is the model of your camera and what specific battery are you using( what is on the label of the battery?)
when the camera is docked on the printer, you should get a little light indicating the charging status. Once it is fully charged, all 3 green lights would come on.
But, we need to know what is the model of your camera and what type of batteries are being used in order to determine if they are compatible or not.
Apr 10, 2009 | Kodak Easyshare G600 (1633379) Dock /...
Red flashing light on battery indicator on the loading dock.
My Z760 does the same thing. When that happens I run the battery completely down by taking pictures until it shuts down. Then when I put it on the dock it charges properly. Don't leave your camera on the dock all the time and don't try to always keep the battery fully charged--instead it will develop memory and think it needs to be fully charged to run and will give you a low battery signal earlier than it should. Wait until you actually get a low battery signal before charging and it should help, but mine will still give me the red light sometimes. Then I run the battery out like I said before. I hope this information helps. :-)
Mar 14, 2009 | Kodak EasyShare Z760 Digital Camera
Charging...Red Light
This happened to me. The cause was the battery did not fit into the case, This led to poor connection of the battery. After I fixed the loose battery , it worked perfectly till today.
Oct 05, 2008 | Kodak EasyShare Z760 Digital Camera
My Kodak V1003 will not charge.
  1. Make sure the Ni-MH rechargeable battery is in the camera.
  2. Place your camera on the printer dock.
  3. Press and hold the Battery charging lights/Refresh button, until the Battery charging lights begin flashing green (approximately 5 seconds).
Aug 05, 2008 | Kodak Cameras
Battery won't charge on printer dock any more?
I had a similar problem. If you look in the battery compatment you will see a small switch in the keyway that gets pressed down by the key (the plastic rectagualr bump out) on the side of the battery, if the battery is loose the switch does not get pushed down and the dock does not recognize the battery as a Kodak Batery that it should charge. I solved the prblem by taping a singe piece of paper on the opposite side of the battery so that when it slides into the slot it pushes the switch down, I've nver had a problem since.
May 13, 2008 | Kodak EasyShare DX6340 Zoom Digital Camera
Casio ex-s600
Hello Gery, Try with the new battery. Best regards, Arpad
Jan 10, 2007 | Casio Exilim EX-S600 Digital Camera
Kodak Dock Series 3 Laser Photo Printer Logo
142 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
